kee
love the look of this gti, and that bucket seat is fully droolworthy. i'm hoping to be owning one very soon. What car does the XU10 head come from and is it a direct replacement? I'm new to peugeots so picking up all these engine codes is hardwork
VND
That looks highly awesome mate. Well played.
Aug 11, 2012 16:42:19 GMT
What car does the XU10 head come from and is it a direct replacement? I'm new to peugeots so picking up all these engine codes is hardwork Thanks a lot guys, the head is from a 406 as it has larger ('big') valves. It should bolt straight onto the XU block.
Aug 15, 2012 14:28:02 GMT
Nearly got the tank running on pure 97RON now so was able to advance the timing and gain that missing power. Hoping that once this tank has flushed through any pinking issues will have disappeared.
Aug 17, 2012 10:28:43 GMT
Still having pinking issues, and if I retard the ignition enough to stop it I lose too much power. I have a feeling it may be to do with the 1.6 dizzy (I've been told it has a better curve), and will have to wait until RRG before testing a 1.9 dizzy. I guess I should be ok if I drive there nicely
Aug 20, 2012 17:54:05 GMT
1.9 dizzy now fitted and its running 50x better than before. The last one must have been knackered and not just an issue with the different ignition curve! Here's a pic from RRG courtesy of Brian Damaged:
Aug 23, 2012 18:20:27 GMT
Got the driving lamps wired in (some fool removed half of the loom in the past for no obvious reason). Fitted a new relay and all the appropriate wiring, then soldered the switch wire to the high beam terminal on the back of the headlamp: Also sorted the oil pressure gauge as it wasn't reading accurately due to the thread size offset. The engine block is M10x1 and the aftermarket sender is 1/8 NPT, it did fit OK this way but wasn't giving an accurate reading. To fix this I fitted a male (M10x1) to female (1/8 NPT) adapter and used the supplied seal at the block end. It now gives the correct reading. Old sender: Adapter: New sender fitted with adapter: Oil pressure + voltage gauge:
Mine has a shot dizzy ATM. Play ahoy currently. It is on the to do list when I start driving it again .
luckygti
I need to try harder!
Looking good at RRG mate, good to meet you (and Chasr) and thanks for the offer of assistance on mine. Managed to get it running obviously, new rotor arm and dizzy cap cured it! Random.
Aug 27, 2012 12:46:20 GMT
No worries, glad it was only those parts that failed. I could have pulled the ignition amp off for you but without the heat paste and fragile pins I would have been stuffed if I couldn't drive home
Aug 28, 2012 18:40:11 GMT
Like this alot
Oct 17, 2012 15:43:30 GMT
Oct 17, 2012 16:33:33 GMT
Love it
Had a dizzy refurbed by H&H Ignition Solutions. Phil was very helpful on the phone and they have also recurved it to suit my engine spec. Just waiting for a cap to turn up and it'll be ready to fit
Nov 15, 2012 13:53:17 GMT
Cap finally turned up so will be fitting this tonight!
Nov 15, 2012 22:43:19 GMT
Fitted and works great! Just waiting for the vacuum advance to turn up now. No more pinking...finally!
Dec 18, 2012 22:40:43 GMT
Apr 23, 2013 10:42:00 GMT
Apr 23, 2013 17:07:57 GMT
It is looking sweet!
A fresh dizzy makes all the difference eh? Mine runs much better on the recon dizzy (again from H&H). I am sure (not that it matters) that my fuel mileage has improved as well, quite a handy thing when I am using it on the daily commute over the daily as it is repaired.
