Time for a bit of a clearout, before I break my neck in my office at work and my spare room! Prices are for collection, PM for postage!
NEW STUFF ADDED TO THE BOTTOM!
Next, 4 Team Dynamics Diablo wheels.
Vital stats are 5X110 (Vauxhall and Saab) ET37 16X7.5J. They have just under 2" of lip and are hi-powah silver. Come with a bag of bolts, and are nearly new. They look like they have had tires fitted, have been put on a car, driven round the block then stripped and boxed up. Few tiny tiny marks on very close inspection but nothing worse than buying a set of 'showroom' wheels from Halfords.
£200?
JBL GTO 75.2 amp
"JBL GTO-75.2 Description:
The GTO 75.2's high-output MOSFET power supply ensures optimum power delivery into numerous impedances with low distortion.
The 75.2 comes outfitted with a variable 12dB per octave electronic crossover allowing you to optimize system tuning based on speaker location and accompanying loudspeaker components.
Full range preamp outputs are provided facilitating multiple amplifier hookups without the need for high-loss Y-adapters or signal splitters.
JBL GTO-75.2 Features:
* 97 watts RMS x 2 channel at 4 ohms
* 260W RMS bridged mono (approx 500W max)
* Ratings at 14.4V supply
* Variable cross-over. Variable Bass Boost.
* Speaker Level Input
* Overload protection
* Dimensions (H x W x D): 2-3/8" x 11-5/8" x 12-5/16""
Thats the specs. Now, its a wee bit scruffy (plastic mount is marked) but it works fine. If you took the massive gash silver stuff off anyway, it'd look a whole lot classier. I like the smoked acrilic panel showing off the gubbins inside!
£35
IPF spot/fog lamp wiring kit.
This is awesome. I got this with the intent of using it for my SJ, but I feel that a good old fashioned switch and relay will suffice as this is a bit pimp. Its an IPF wiring kit from the land of the rising sun that allows you to choose between 2 different sets of lights via the dash-mounted control unit. comes complete, with all relay modules and wiring. Its been tested and works fine. Its a great bit of kit for anyone with a tidy 4X4 with lots of lights.
£25
NEW STUFFS BELOW!
ICE! ;D
Blaupunt London. I have 2 of these, aftermarket VW radios. One is this one which would clean up nice, £10, and another with an iffy screen that although works, has a little ink bleed. £5 for that one. GR8 for OEMing your Golf 2, ect.
VW Ignition module
Looks quite new. Worked when removed, no reason whu it wouldn't now. £5
Coffee maker
Boxed retro coffee maker thing, never used. £10
Ally polished gauge holder
Does not include the gauges. Mounting tabs slightly naff but hidden when fitted and perfectly useable. £10
Gauges
Electric temp gauge. £3
Ammeter (choice of 2, both very similar, other photo has gone AWOL??) £3
switch panel
Looks very Mini-ish but universal. One switch included. £5
SEV Marshal beacon
Chrome base, red reflector. In good Working order. Has a lovely sweep and sounds like a nciely made lego technics model. £30
Polo Mk2 (maybe Mk1 too?) stalks
Were in working order when removed.. £5
Feista Mk2 haynes
Rubbish non-terry davies manul sadly. £3
Heater valve
No idea on application. Looks new. £3
Thatcham immobliser.
Ignore the fact that the box says alarm, its not, its just an immobiliser. But its a good one, had 2, fitted one to my works BMW. Comes with instructions. Would fit this to my truck but that has a factory one so no need. £15 takes it!
7" angel eye headlamps
Have been fitted to a mini, but are in good nick. Are not EEC or E marked, are DOT approved (lol) but have passed several MOT tests and are a massive improvement on stock headlights in a mini or other 7" headlighted car as these take H4 bulbs. £20
RING driving lamps
£10, very good condition
PAIR of Merc wheels
2 mercedes steelies, were on the back of my transporter. Hence red. 15X6 with an ofset of 49. PCD is 112X5. £10
All for now, more soon!
£200?
JBL GTO 75.2 amp
£35
£25
NEW STUFFS BELOW!
ICE! ;D
VW Ignition module
Coffee maker
Gauges
switch panel
SEV Marshal beacon
Feista Mk2 haynes
Heater valve
RING driving lamps
PAIR of Merc wheels
