This picture show's the passenger side, but it's the drivers side that needs doing on my 1970 Mini Clubman Estate. I can't open the drivers door without the risk of it falling off so took a pic of the other side!
The bit shaded white is the rusty bit - basically it has rotted through where the top door hinge is bolted to it, so the top hinge is now not attached to the car!
It only seems to be rusted around the top hinge, but I guess it's best to replace the whole of that bit - it's the inside of the A post I guess?
Anyone know what it's called or if anyone sells a repair panel for it? I assume I'll also have to cut the A panel off to get at it properly and replace that as well afterwards?
Any advice or suggestions or recommened panel suppliers?
Thanks!
Thanks!
