Sept 20, 2011 11:14:09 GMT
Looks very nice and a lucky find, the rust was virtually nothing for one of those Are you tempted to fit the orange RS2000 decals? Looks like it has a lot of original RS stuff, ie. the sump, bellhousing, engine mounts & the Type E gearbox etc.. And I bet those IDF's sound nice too
totti
Sept 20, 2011 16:46:08 GMT
Thanks! In retrospect it was a very good shell,only minor rot in the most typical area's. The donor Escort was "re-shelled" and an Original RS car.As the previous owner crashed the car he buy a bog standart 4 door and fit all the RS stuff...... And there was much of the very expensive stuff in.... ....alone the Atlas axle is a genuine RS item and cost now a fortune The noise from the IDF's is awesome....i love it so much The spec of the engine is very driveable with only a mild cam. Greet Totti
65 'Ford Taunus 17m 66' Ford Taunus 17m Turnier 73' Ford Taunus 63' Ford Taunus Transit 1250 72'Ford Escort 2000cc 71'Ford Escort 1700 4 door 89'Ford Escort Express 87'Ford Fiesta Diesel 64'Ford Cortina 1500 deluxe 57'Volvo PV 444 Califonia 54'Peugeot 203 Commerciale 2004 Harley Davidson Fat Boy 78'Zündapp ZR 20 88'MZ ETZ 250
Sept 20, 2011 17:18:31 GMT
Thanks! In retrospect it was a very good shell,only minor rot in the most typical area's. The donor Escort was "re-shelled" and an Original RS car.As the previous owner crashed the car he buy a bog standart 4 door and fit all the RS stuff...... And there was much of the very expensive stuff in.... ....alone the Atlas axle is a genuine RS item and cost now a fortune The noise from the IDF's is awesome....i love it so much The spec of the engine is very driveable with only a mild cam. Greet Totti RS stuff is a fortune here aswell Did you buy your turrets & bits from the UK or is there a supplier in Germany?
Sept 20, 2011 17:57:18 GMT
Wow very nice ! thats one of my dream cars only i would choose a other color
if sparks don't fly you're ridin too high !
luckygti
I need to try harder!
Sept 20, 2011 21:17:35 GMT
Now that is a beautiful Mark 1. A real credit to you, it's been beautifully finished. And the 4 door?
hak074
Sept 22, 2011 1:24:03 GMT
That is a great looking mk1, good work! I love the stance on it, its perfect for me too And you've got some tasty bits and pieces under the skin too. Bet it drives nice and makes all the right noises
totti
Sept 22, 2011 9:59:19 GMT
Hi! Thanks ;D I love the sound of the car .....and it goes like nothing i ever had ;D My wife don't like it.... she said it' sooo horrible loud and when i give it the beans it's like a drive in a rollercoaster..... And...Yes it is LOUD and rough ....for long distance it is not my first choice So,the Donor Escort become a own thread... Cheers Totti
Pid363!
Madness is all in the mind!
Sept 22, 2011 20:10:02 GMT
That makes me want another mk1. That just looks so right not an out and out racer like so many over here.
Stupid is as stupid does!
Sept 24, 2011 5:30:31 GMT
I guess that it is all about purpose.
One car for shopping, one for racing.
b7
Sept 24, 2011 6:02:21 GMT
THAT, is nice! One of the nicest Mk1's in a long time. Whats happening to the evergreen shell???
2012 BMW 520d Touring MSport 2006 Golf GTI TSI Previous 1965 Triumph Herald 12/50 in Royal Blue 1989 BMW 325i Convertible (C2.7 powered)
totti
Sept 24, 2011 14:28:20 GMT
Tach! grizz You know i have a car for EVERY single purpose @retrofication The most stuff is from the UK....i bend the limit of the credit card more thon once.... ...The RS- Stripes....i thougt about it.....No. Cheers
Sept 24, 2011 16:19:41 GMT
Great job,the stance is perfect. ;D
totti
Jan 28, 2012 16:55:54 GMT
Hi! Years ago i thought about a Zetec-conversion.....i buy all the stuff for a lot of money,but than:The Oilpan does not fit on a LHD car!And some other stuff too.... So i drive the Pinto .... But i think it's time now for a secound try! Today i pull the 2 liter block out of the shed ... The Flywheel is always machined to get the Pinto clutch.... I don't like the new style V-ribbed belt so i make my own belt system that look oldskool. If the engine is in the car;later;and it's running i will go the BDA lookalike route with the Camcover etc. So i search in my workshop for the right pulley and found one from a Fiesta 1,6 Diesel.I change the flange...same diameter from the shaft! The old Zetec flange.... The new hybrid pulley.... lining up ....... My mate has got a lathe and will machine the crank pulley to take the belt.... More to follow.... cheers
totti
Hi! Last week i startet the "dry fit" to have a look. When there is to much changes to make i will stay with the Pinto... So,first get out the old lump.... For the Zetec i will go back to the 4 speed Rocket-Box....better gear ratio's and the Gearchange is much better. Here we go.... Looks not to bad!The battery can stay!And enough space for the Brake servo.... The Alternator will fit without hassle.... So,no major changes!I can get back to the Pinto without problems any time. But there is one problem with the Manifold and the Steering column... I have to change the pipe route on 3 pipes.... This took alone 3 days of fettling..... To this... Next was to relocate the gearlever hole... Kindergeburtstag! Thanks for looking! Cheers
lotdave
only one gerry
Love the car and what you have done with it i had a daytona yellow mexico back in the day and wish i had it now !! The only thing i want to point out is that each of the manifold branches should be of equal length from manifold to collector this being the reason they look like a bunch of bananas, I don't want to P on your chips especially after spending 3 days on it ive just spent the weekend doing my own manifold so i know what a pain it can be
Great work
totti
Thanks!! ;D Yes,you are right!I know about the equal lenght of the pipes....but for now it's the only way for me.There is a LHD manifold from Retro Ford but than i have to bin the brake servo......and 428 quid I don't know how much hp the engine lost with my manifold....i will see The Zetec will stay OEM,no plans for big power,cams etc so i hope it will make 160 hp. Cheers
As always Totti, I am impressed.
luckygti
Now this is something I'd like to do to mine. One day When I've got everything else done How's the cortina going, can just see it in the background there?
totti
Tach! Yes,the Cortina............ it's now finally stripped. It's soooo rotten......i can't be bothered to do something at the moment Soon! For now i hope the Zetec will run nice....still waiting to order the LHD sump and other parts from Retro Ford.Since weeks i try to order....but they moving premises at the moment.And the online shop doesn't work Cheers
