Sept 23, 2011 7:35:15 GMT
Hi! Found this on the interwebs... It's a space framed racing Metro with a weird cylinderhead on a A-Series(?) engine. Looks very interessting! Can someone ID the cylinder head by looking at it? It's non of the verious A-Series crossflow heads. So I suspect it's from something else - which might proofe to be a cheap donor for a cross flow head conversion for a Mini ;D Cheers, Jan
Sept 23, 2011 7:43:28 GMT
I think it is a ford cross flow, but rather than just the head it may be the entire engine, I don't know how but I know that some of the 70's racing minis used a ford crossflow on a modified mini gearbox. Google found this for inspiration.
Sept 23, 2011 8:21:22 GMT
Now that you say it - it looks indeed a bit wider than an A-Series! I knew about the Manx Lotus conversions... Didn't think of a cross flow I think you'r right! Thanks!! Cheers, Jan
Sept 23, 2011 20:57:30 GMT
didn't they call them the 7 port head?
Sept 23, 2011 21:21:43 GMT
i seem to recall ron datson hillclimbing a maguire metro with a kent 1300 crossflow on a mini box back in the 80s.
muttley racing ftmfwmf
Sept 23, 2011 21:43:27 GMT
Surely that's an alloy head, crossflows are iron. It looks like an eight port A series head to me.
R.S. Autotech. Servicing/Repairs/Diagnostics.
Anglia68
Powered By Boredom.
Sept 23, 2011 22:35:29 GMT
Hi! Found this on the interwebs... It's a space framed racing Metro with a weird cylinderhead on a A-Series(?) engine. Looks very interessting! Can someone ID the cylinder head by looking at it? It's non of the verious A-Series crossflow heads. So I suspect it's from something else - which might proofe to be a cheap donor for a cross flow head conversion for a Mini ;D Cheers, Jan It is definately a Ford crossflow head. You can tell by the end shape and the core-plug as well as the positioning of the sparkplugs and leads,the dry-sump rocker cover and the thermostat position at the other end and also the inlet manifold is for a 1100/1300 engine.Hths.
Sept 24, 2011 0:01:25 GMT
Google found this for inspiration. I remember a guy from Harrow who had a blue clubman estate with a Ford based 711m Lotus lump in it, that was back in the early 80's and NOTHING could touch it
Sept 24, 2011 7:07:34 GMT
The David Vizard book "How to modifiy your Mini" has a section on fitting Kent engines into Mini's.
Paul H
Sept 24, 2011 8:14:06 GMT
it looks like an elder 8 port alloy head to me it was a bolt on conversion for the a series not a ford
97 volvo 940 turbo wagon 87 fiat strada abarth 78 gs1000 82 katana 1100 84 gsx1100 efe
Sept 24, 2011 8:19:56 GMT
Sept 24, 2011 8:44:56 GMT
No! It's NOT an A-Series head! Neither of them hast the spark plugs on the exhaust side, nor do they have that alignment of exhaust ports (except for the 7 port heads, but these have only ONE center exhaust port). It's not: - Arden - Alexander - Weslake - AKM/Minisport - Pierce - Allen/Pinion - Russel 7 or 8 port - non of the known twin cam heads, obviously If there was a Space-Framed Metro with a 1300 Kent crossflow, it's good chance that this is it! I just didn't think about the Crossflow OHV heads, I had only the twin cams in my mind... Manx amongst others sold conversions to fit a Ford/Lotus engine into a Mini. Or better a kit to put a Mini Gearbox in a Ford/Lotus engine's sump ;D Looking like this: And another one, not sure if it is a Manx, I think not: And yet another one made in Germany by a privateer, IIRC. And not sure if it's a Ford engine!? And some more random pictures of such conversions....
Sept 24, 2011 9:05:43 GMT
my mate had a X flow OHV head on a Mini years ago, said it originally came off a car that had done the Monte Carlo rally although i don't know if it was a works car or a privately entered one, he had twin carbs sticking out the front of the bonnet and i remember him detroying my other mates tuned RS1600i down the lanes.
tontoe
Enter your message here...
Sept 24, 2011 10:41:19 GMT
Hi! Found this on the interwebs... It's a space framed racing Metro with a weird cylinderhead on a A-Series(?) engine. Looks very interessting! Can someone ID the cylinder head by looking at it? It's non of the verious A-Series crossflow heads. So I suspect it's from something else - which might proofe to be a cheap donor for a cross flow head conversion for a Mini ;D Cheers, Jan That is an Arden 8 port head you can still buy them from mini specialists now very expensive it could never bee a ford crossflow head as they are cast iron this one is alloy
life is just a game we play
Sept 24, 2011 11:03:57 GMT
Last Edit: Sept 24, 2011 11:06:04 GMT by damien4884
1977 datsun 810 180b estate
Sept 24, 2011 11:04:17 GMT
tontoe
Sept 24, 2011 11:19:26 GMT
see what you mean now about it being painted and not alloy and the rocker cover now i look at it more obviously Ford , it was just the alloy look that threw me ;D ;D ;D
Sept 24, 2011 11:27:08 GMT
see what you mean now about it being painted and not alloy and the rocker cover now I look at it more obviously Ford , it was just the alloy look that threw me ;D ;D ;D Yeah. If I'd had known they'r cast iron, I would've probably fallen into the same trap That said... Pierce Manifold are making alloy Ford crossflow heads nowadays www.piercemanifolds.com/product_p/99003.845.htm
Sept 24, 2011 11:36:55 GMT
^ I was just about to mention that, also Burton Power list alloy crossflow heads.
I think the black engine is a pinto.
bortaf
Sept 24, 2011 12:55:53 GMT
^ I was just about to mention that, also Burton Power list alloy crossflow heads. I think the black engine is a pinto. with a wierd dizzy position? lucky it's not painted silver or we'd be here all day
R.I.P photobucket
