I have a stack of Genuine 15" Compomotive and Revolution rolled lips and barrels for 3 piece wheels. They also fit Schmidt 20 bolt wheels and Image 20 bolt wheels. The rolled lips are no longer made and so are getting rare and hard to get hold of nowadays!
So this is what I have for sale:
4x matching set of 5J outer shallow rolled lips in reasonably good condition, all 4 rims are straight, without buckles, bents or flat spots. 2x Lips have absolutely no kerb rash although are dull and oxidised in places and so will require polishing. The other 2x lips are polished, but could do with being re polished and have very minor kerb rash that should polish out fine. All 4 lips would definitely benefit from being re polished but are 100% sound and a full matching set!
Although the 4 lips are lips they can be used as barrels if you plug the valve holes in the rims. They can also be re drilled to fit Compomotive, Revolution, Schmidt and Image 30 Bolt 3 piece split rims.
£240 for all 4 lips
2x 5J outer lips in reasonably good condition. The rims are both straight, without buckles, bends, flat spots, dings or kerb rash. They will both require re polishing! Both the rims are the same style although one rim has a deep rolled lip and the valve hole in the flat barrel section of the rim and one has a shallow rolled lip and the valve hole in the step in size of the rim.
Again although the 2 lips are lips they can be used as barrels if you plug the valve holes in the rims. They can also be re drilled to fit Compomotive, Revolution, Schmit and Image 30 Bolt 3 piece split rims.
£120 for both lips or I will split these 2 rims and sell them separately for £60 each
1x 6J deep rolled lip in Reasonable Condition. It is straight without buckles, bends, flat spots, dings or kerb rash. The rim is in good condition although again will require re polishing. £60
1x 6-1/4J Barrel in Good condition, Its Anodised straight without flat spots, dings, dents, buckles or kerb rash. £60
2x 6Jx15" Compomotive 20 Bolt Rims designed for 2 piece wheels. They will also fit both 2 and 3 piece Compomotive, Revolution, Schmidt and Image 20 Bolt centers. The rims have no kerb rash, flat spot, buckles, dings or dents and are both straight. The paint has seen better days in places and the rims could do with either being stripped and polished or re painted, but in all honesty there not too bad. You can mount your centers to either the front or back of the mounting face of the rim to give you different off sets/ET. But obvisously the ET/Off set will depend on what center you use.
Although the rims are 6J the overall width from edge to edge is 7". The rear section of rim (barrel) from the outer edge of the rim to the rear mounting face is 5-1/4" deep. The mounting face/flange is around 1/4" deep and the front lip from the front mounting face to the edge of the rim is about 1-1/2" deep.
£60 the pair.
If you start pricing up lips and barrels to fit 20 bolt Compomotive, Revolution, Schmidt and Image Wheels you'll probably start crying! I know for a fact that if you have rims made similar to these you'll be paying between double and triple what I'm asking for each section and none with be the genuine roll lip (rolled for strength).
All parts are in Bristol although I'm happy to post at the buyers expense and I'm happy to forward people pictures if you pm me your email address.
Cheers Andy
areyouopenyeti@hotmail.com
I AM PREPARED TO TRADE OR PX ANY OF THE ABOVE FOR 1X 2J LIP AND 1X2.5J LIP IN GOOD OR SIMILAR CONDITION... MUST BE 20 BOLT!
£240 for all 4 lips
£60 the pair.
Cheers Andy
