Onne
Nov 14, 2011 12:51:46 GMT
Hello all,
My good lady has bought a (newish) car (Citroen DS3), but sadly it hasn't got a spare wheel.
Does anyone have any kicking about is reasonable nick? Ideally after 2, as the parents have the same car too...
Much obliged Onne
Last Edit: Nov 15, 2011 9:33:01 GMT by Onne
Nov 14, 2011 17:47:08 GMT
got VAG ones. tenner each collected. i think i have a pair.
Onne
Nov 14, 2011 18:12:24 GMT
Should they fit ok? Off set clearance etc?
Nov 14, 2011 18:14:08 GMT
no idea, i aint gotta clue on hondas.
keithrg
Dame they destroyed 6 mk1 escorts making Fast and furious 6 :(
Nov 14, 2011 20:21:47 GMT
vag WONT FIT CENTRE Bore will be to small ? Honda's
Nov 14, 2011 20:34:22 GMT
Surely Citroen are 4x108? If that's the case, then I think VAG centre bore/offset will be the least of your worries.
Onne
Nov 14, 2011 21:41:57 GMT
I'd best look that up first then... Cheers for the heads up.
And yes for (a pair of) Citroens
Onne
Nov 14, 2011 21:45:53 GMT
Just looked it up, indeed 4x108, 65.1mm centre bore
Do these share it with anything else?
Nov 14, 2011 23:50:53 GMT
ford,peugeot,citreon,audi are all 4x108 but you'llhave to check centre bore,
theres more to life than mpg & to much power is just enough.
Onne
Looks like I might be having a trip to the scrappies at the weekend then... Any excuse lol
Nov 17, 2011 23:17:07 GMT
I have a couple of 4x108 steels (possibly with tyres too) but they're not spacesavers. Can't remember the exact width, but nothing too wide. Standard fit Citroen ZX ones. Any good?
Nov 17, 2011 23:27:15 GMT
I've got 2 106 Rallye space savers, one even has the anti theft device on.
Make me an offer??
Some days you just need to take a grinder to an inanimate object, just to make your day a tiny bit better!!
Onne
Nov 18, 2011 14:44:48 GMT
Cheers chaps, Wichard, they are probably too wide, can't fit anything much wider than 135 I think.
I am going past the scrappies tomorrow to have a look round, if I have no luck I'll let you know. Whereabouts in Lincs are you Loudandproud205?
Nov 18, 2011 15:30:26 GMT
only certain audi's are 108, wrong centre bore and offset most likely anyway.
which model DS3? as the brake sizes vary most need 15" minimum, you need to make sure the overall diameter is the same too.
standard original equipment is 3.5x15 ET15, cost £35 inc vat.
tyre size is 125 80 r15 and from a dealer will cost you 85 or 105, choice of michelin or conitnental.
Last Edit: Nov 18, 2011 15:32:14 GMT by welshpug
Onne
Nov 18, 2011 17:30:26 GMT
Fairly standard DS3, on 17" optional wheels (like on the sport) The car in question
Nov 18, 2011 17:35:47 GMT
Am in Market Rasen.
If you happen to be round this area feel free to try one to make sure.
I'll try find out what size brakes they will cover.
Nov 18, 2011 17:59:52 GMT
Came to conclusion there either 266s or 283s.
As a rule of thumb on other 4x108 cit/pug cars 14" will fit over 266s but require 15" for 283s
I'd try one see if they fit
Onne
Nov 18, 2011 18:06:50 GMT
I'd love to try them, but you're nearly 70 miles away What do the numbers mean?
Nov 18, 2011 20:26:59 GMT
They're the size of the brake calipers - 266mm and 283mm.
Onne
Nov 18, 2011 21:02:37 GMT
I'll have a measure tomorrow. I'd be very surprised if it they are the bigger ones though. Only a 1.6 NA
Can't get used to the over assisted brakes though, prefer the ones on the Benz!
