bl1300
Nov 26, 2011 15:40:27 GMT
but why only have four ;D what about 5 as on this 1920 Briggs and stratton. This car the red flyer is apparently listed as the worlds first sports car. Another 5 wheeled briggs and stratton cycle car or perhaps 8 Like this car but why stop at 8 wheels lets have two engines and to make even more different two mazda rotarys. heres an electric car that I actually like although I think that 8 wheels might slow this lithium ion car down. But it looks cool anyway 6 wheels you say? How about the six pack rat. A six wheeled Opel Manta I throw you a six wheeled Porsche 928 pick up 7 wheels oh yes I found one. 10 wheels ok now I'm getting silly so ok a nice sensible 4 wheeled car or is it
Current fleet.
xlexx
BMW`s garage / Zaz 965a V4 1968 / Leyland 400
Nov 26, 2011 18:45:06 GMT
7 wheels oh yes I found one. This is "Oka". It is the development of Daihatsu Cuore)) Funniest photo
maymotors.ru
I like wheels.manta73
@GUEST
Nov 26, 2011 18:49:44 GMT
Love the '6 pack rat' AMAZING!!!!!
I like wheels.Deleted
@Deleted
Nov 26, 2011 19:32:31 GMT
If that electric car has one motor per wheel hub then I suspect that the multiple wheels will do quite the opposite to slowing it down, at least until you flatten the batteries.
damask
Nov 26, 2011 19:34:27 GMT
volksangyl... the motors can only go so fast though...
Nov 26, 2011 19:46:22 GMT
volksangyl... the motors can only go so fast though... I'm no expert on electric cars, but I think what VA is getting at is that a motor per wheel is more effecient, and therefore capable of being quicker than if one bigger motor were used I may have missed the point entirely
bl1300
Nov 26, 2011 20:08:42 GMT
Well the way I looked at it is this.
Extra wheels = extra weight which = more energy required for motion.
and Extra wheels mean more rolling resistance which once again requires more energy to overcome. This is the reason those lorrys you see on the motorways often have an axle lifted when empty. Less rolling resistance so less fuel used.
Current fleet.
@Deleted
Nov 26, 2011 21:39:14 GMT
ben got what I meant. I don't know much about electric cars, but it does seem that the ones with one wheel per hub rather than one centralised engine are the most efficient in their distribution of power to weight.
robg2
Nov 26, 2011 22:00:33 GMT
Cracking thread! Well done. Love the Manta - but why on earth...?
Last Edit: Nov 26, 2011 22:01:10 GMT by robg2
Nov 26, 2011 23:21:59 GMT
The 8 wheeled electric car has 640hp and a top speed of 370kmph
ben got what I meant. I don't know much about electric cars, but it does seem that the ones with one wheel per hub rather than one centralised engine are the most efficient in their distribution of power to weight. +1 - no drivetrain losses, as no gearboxes, driveshafts, CV joints, etc. OTOH, the motors run slower, so doesn't produce as much power for a given weight: in very rough terms, torque per weight is constant for a given motor technology. Spin it faster, and you get more power for the same weight. As an example, the motor in the Tesla runs up to 14,000 rpm @125mph, so can be lighter for a given power. If it were wheel mounted, the motor would run at ~1682 rpm at 125mph given the tyres being used. Thus, to produce the same power, the motors combined would need to produce ~10x the torque, so would have to be ~10x heavier. In addition, wheel-mounted motors add a fair amount of unsprung weight - not ideal for handling on bumpy surfaces. Finally, more wheels with motors means more torque - but that will only result in a higher top speed if the motor is designed to be able to spin faster too, which will require more supply voltage. It's a balancing act.
stuey
ram thruster 4000
wolfrace sonic I choose you!
1987 fiat 126-nearly actually done! 1972 beetle - lawn art 2003 z4 daily-new wheels a comin! 2008 R56 Mini cooper "mental Mickey"
Nov 28, 2011 18:36:05 GMT
I see your Wolfrace Sonic and raise you Ray Christopher's C-men-T As it is now In it's 1979 heyday.
