naki
Dec 15, 2011 13:08:18 GMT
its great to see one of these old dears back from the grave. its an epic task to restore one of these, as am sure you know. the word "Weldathon" doesn't come close! if only cars of this era were better protected against rust, we wouldn't be in this mess. its a harsh reality for these cars, but they will become very rare sometime soon, as the number of optimists willing the spend time and money on them is dwindling. good on you.
90 Range Rover Vogue SE 3.9 V8 LPG, Lifted & modified for Off Road 93 XJ40 3.2s- awaiting 4.0 Manual conversion 91 XJ40 3.2 Sport Pack MANUAL (project) 93 XJ40 4.0 Sovereign- Daily Driver 91 XJ40 4.0 Manual 92 XJ40 4.0 XJR Manual 93 XJ81 6.0 Daimler Double Six
foxy99
Thanks for comments again guys. The good thing about doing this in retrospect is that the updates come much quicker Tali The previous owner.....I kept him up to date at the start and he was a real gent. I live for the day I drive it back through to show him it Anyway. Back to the story....... IIRC my original plan was - patch up the sills using only new outers
- refurb the calipers
- refurb the carbs & fuel pumps
- replace water pump & any burst hoses etc
- bodge the rear arches with filler
- tart up the wheels
- replace missing/damaged exhaust parts
- paint repaired areas with any paint available
- drive - with thrash punk blaring out sound system
So looking back at the pictures and the receipts that is basically the plan I stuck to. I have a sandblaster and used it extensively on the Polo project but didn't bother on the VDP inner sills. I didn't buy a new panel for the inner sill and made up my own for the front jack-point. I did buy one for the rear as this is a pretty crucial area and I wanted a safe part. I got an old one of Ebay (which was nowhere near as good as the ones you can by from all the recognised outlets and not much cheaper) I stripped the front calipers down and got seal kits and same for the carbs, fuel pumps and exhaust (all drivers side to start with). The receipts I have are as follows: Rossleigh, Perth 04/05/2001- C43397 front RH downpipe
- C35402 olive for downpipe to exhaust pipe long section
- C43429 exhaust pipe long section RH
- BEC9888 2 x downpipe to manifold sealing rings
Total £88.92I rememeber driving up to Perth for these before work one morning and my Polo broke down at Cumbernauld or somewhere on the way back. The reason I chose the Perth dealer is that they were one of the dealers appointed to run the new JDHT Trust Classic Parts scheme. The guy was extremely helpful actually. next one is Burlen Fuel Systems Ltd, Salisbury 29/06/2001- EPK 300 2 x fuel pump repair kit
- BDR125S carb damper oil
- B20379 carb needle adjusting tool
- CDSK14 carb service kit
- 019654P new screws for carb tops
- B20767 carb bowl plug and sealing ring
Total £109.64Looking at this receipt now it looks like I only had enough cash to refurb one carb and both halves of one twin fuel pump a couple of months later it was Rossleigh, Perth 06/08/2001- C41353 4 x hoses for induction manifold
- C25321 6 x exhaust manifold studs
- C30787 12 nuts for above
- EBC10199 6 exhaust manifold gaskets
- C2369 8 manifold to downpipe studs
- C17916 8 x nuts for studs above
- C34112 2 x gaskets for induction manifold
- C33281 2 x thermostat gaskets
- EBC35762 x thermostats
- C34063 3 x water gallery gaskets
Total £78.30I don't remember driving to Perth for these but I think but that's maybe because I didn't break down that time. I must've been scrimping to only replace 6 of the exhaust manifold studs instead of 12 and god know why there is an odd number for the last gaskets. next up were a parcel of fuel & brake parts from established dealer David Manners, Oldbury 29/08/2001- ARA1502J* 2 x fuel tank sealing rings
- AAU3380# 1 x rear caliper seal kit
- C28080* fuel filter element
- RTC1116# 1 x front caliper seal kit
- JLM536* 1x front pad set
- JLM1539# 1 x brake pad pin/clip set
Total £67.45Again it looks like I could only afford single kits but maybe they were axle sets. I remember sand blasting the calipers and painting them in silver caliper paint but haven't bought the new pistons yet. next up were a couple more fuel system parts and 'The Bible' XK Engineering, Coventry 03/10/2001 - XKPUB88 S2 XJ12 parts catalogue
- C44665 1 x fuel tank sump
- CBC5649 1 x internal fuel tank filter
Total £73.17It was £50 for the part book photocopy and another £8.50 for delivery so an expensive read but it is a great item. Not sure what the sump is. Maybe I lost one of the fuel tank drain plugs and I do remember one of the filters being knackered. Probably the one on the pipe mentioned before that took the beast off the road effectively. Next purchase was years later. I reckon everything stopped in early 2002 when I got the unit and started restoring the black Polo. I then recommenced on the VDP as shown above. Martin Robey, Nuneaton 24/08/2005- JH AKP381 inner sill LHS
- MS 12136RP left hand rear box section
Total £118.09I reckon by this time I had done the drivers side inner sill and box-section and was planning ahead for the passenger side. I went for the pukka box section because of the reasons mentioned earlier. It is a really good heavy duty part incidentally. I think I decided on a full sill to compare if that was better or worse than repairing the old one. The answer to that will come later. Next buy was probably to finish of the drivers side Martin Robey, Nuneaton 07/04/2006- MS MRXJ26RH drivers side outer arch repair panel
- MS 12510* sill end cap
Total £28.32 Despite what I said earlier about filling the rear arches with filler I gave in on this because when I was working on the sill I kept catching on the twisted remains of the outer arch and it came off. Why I only bought one sill end cap is a mystery as they were only £3.10 So that summarises all the work done and parts bought prior to moving onto the next premises. That will be next instalment.... getting ready to leave Uddinston unit with one side's repairs done and primed
Last Edit: Jan 24, 2018 23:17:01 GMT by foxy99
foxy99
Ok, so the last post brought us up to summer 2006 roughly. I was working away on the Daimler driver's side and preparing for doing a similar job on the passenger sill area. I have a 'pipeline status' print out from David Manners Ltd dated 06/06/2006 saying JS593 outer RH sill had been on back order for 60 days and remember now that I couldn't get an outer sill anywhere from any of the dealers which explains perhaps why I was moving onto the LH side inner before finishing the RH side fully. Then everything changed again.... My friend's father has an old property with 2 barns which were always rented out by someone or other and I never dreamed I'd be the next tenant but I was at his place around May 2006 and noticed one of the barns was empty apart from 2 cars some fly-by-night valeters had left behind, after paying no rent. I asked my friend to put a word in with me with his Dad, who was on holiday, and about a week later he said 'the barn's yours'. This was ideal because it was 50' long and a bit wider than the old unit and also only 4 miles from my flat. During 2005 and early 2006 I'd had no transport and at one time there were 3 cars in the old unit (Polo, Daimler and my brother's Tipo) so things were pretty cramped. I'd managed to get to the unit throughout that time by cadging lifts, borrowing cars and occasionally bussing it, cycling or walking. The barn was much better as it was bigger and nearer so it was then time for more expense with a truck to move the cars and a van hired to move all my stuff. For a couple of months I had to pay rent on both places which, coupled with the moving expenses, nearly bankrupted me. magnificent shot of the old VDP on its 3rd (and final?) piggyback ride pics like this inspire me to keep goingarriving at current destination in June 2006
Last Edit: Feb 16, 2018 2:07:55 GMT by foxy99
Cumbernauld, now that's a place that brings back a few memories Cracking work on the car, I keep meaning to throw some time at my long term love affair but room normally depicts other wise as mums tiny tin garage is just to small
Some days you just need to take a grinder to an inanimate object, just to make your day a tiny bit better!!
Adz
Dec 17, 2011 10:37:34 GMT
nice project
foxy99
Dec 17, 2011 19:54:00 GMT
Ok. This is the last of the 'archive' era - before I had a digital camera. We're in summer 2006 and in the barn and I started by removing the badly rusted outer sill from the passenger side and have a couple of pics of that possibly only shot I have of passenger sill before rotten outer removedpassenger side sill front after outer cut awayrotten box-section/radius arm mount panel revealed From here on I have quite detailed pictures etc so will post all that up over the festive period and hopefully be up to date come January
Last Edit: Feb 14, 2012 1:43:31 GMT by foxy99
foxy99
Last Edit: Nov 16, 2012 1:54:15 GMT by foxy99
Dec 19, 2011 17:33:52 GMT
I've been reading through this thread, enjoying the car a LOT and also your determination to see this through despite the lack of space/facilities/money/time at various stages. You impart a real passion for this car where others would have given up a long time ago. I've loved looking at the old pictures, the film ones (pre-digital)...they have a very endearing quality to them. The car is just lovely, the colour is sublime, the interior superb. A brilliant story for a brilliant car in the hands of a brilliant owner. WELL DONE! I believe this was in May 2005. I know it was a Saturday and Celtic got beat and I had put £10 on them to lose and got about £80 back which paid for the truck. It was an emotional moment for me. I remember as I drove through the leafy main street of Bothwell towards Viewpark/Uddingston, with the truck behind with the old beast on the back. It was a lovely day and that song Somewhere Over The Rainbow/What a Wonderfull World by Isreal Ikumboweyo (or whatever his name was) playing on the radio it did seem like a wonderful world. ^ THIS ^ however, nearly brought a tear to my eye. Even though I wasn't there, I feel like I was. A true moment captured without pictures, but still very clear. I can see it perfectly, I can hear the song and I can feel the emotion.....we've all been there I'm sure, but you really summed it all up so well right there
foxy99
Naki, Mystery Machine thanks for your interest. I know it is only a lump of metal but, to me, old cars are intertwined with ppl's lives, hopes & memories and that's what makes them more than metal I guess. You obviously feel similar I was planning on an update tonight but have been busy shrinking all my picture to one size which takes ages on my PC. I also found out (from an old email) that it was 2/4/05 that I moved the Daimler to the Uddingston unit courtesy of Hearts beating Celtic 2-0. It was 12/1 odds and I put £8 on and got £96 back. I can't remember how much the move was but I do remember being so elated about getting the car to the workshop finally that I gave the guy a £5 tip.......and later found out I'd actually gave him a £20.....as I had none of my winnings left I also remember that I had a lot of trouble getting the car into the unit as the driver's side tie rod or something became disconnected and the wheel was pointing the wrong way. I think this was caused by the fact I'd taken the front caliper off to refurbish and with that removed the steering mounts etc aren't supported and it all came loose. All I remember is my arms were rather grazed as I had to manually steer the wheel in whilst the truck operator pushed. The guy was only about 18 and didn't know what the hell I was up to. Maybe that's why I gave him the tip. Anyway...probably out of sequence, but here is a random pic passenger side sill assembly removed with B post apparently floating in mid air. new floor edge requiredinner sill removed. bracing in. let repairs commence
Last Edit: Feb 14, 2012 1:47:58 GMT by foxy99
foxy99
Last Edit: Feb 14, 2012 1:48:54 GMT by foxy99
Dec 22, 2011 14:37:30 GMT
Looking at the pictures above has got me wondering what order the car was put together in. I reckon the inner sill was welded to the floor and front & rear of body then the outer sill with outer shell of B post was added then the top of the sills were spotted together and finally the inner part of the B post was put on. Please feel free to disagree. Before you think about it ask yourself how the spot welds were made connecting the B post to outer sill On the Series 3 and XJS , I'm guessing the pressing holes in the inner sills may have something to do with how the B post got welded to the sill. As for the 1, 2 and Coupe... short of finding someone that welded them together its anybodies guess! They have solid sills, so my thoughts are the last weld would have been outer sill - floor. The panel is flexible enough along the door step to be able to get spotweld probes up and inside.
"You're about as likely to come across a fully functioning old Jag, as you are a taxicab that smells agreeable." - James May
foxy99
Last Edit: Dec 23, 2011 2:16:29 GMT by foxy99
mclellanmac
Hand me the hammer and the WD40
Dec 23, 2011 11:49:19 GMT
This is Epic, BookMarked
Mercedes 190e, Lovely
MK4 Golf GTi 20v Turbo, Dull, but always works!
Dec 23, 2011 13:09:17 GMT
Last time I did a series 3 I found it difficult to get the floor, toeboard, and jacking point to all meet up at the front. How did you find it on this car?
foxy99
richw82 I don't remember any problems there but my toeboards (sloping panel inside car?) were fine apart from a small piece on the driver's side one and my floors were totally sound apart from the outer inch or so where they weld to the inner sill. I'll be revisiting pictures of that area soon tho as I tackled that before fitting the passenger inner sill. I used half a jacking point panel here. I did however have problems where the inner sill met the floor at the 'intermediate panel' between the floorpan rear edge and the rear seat face retrorides.proboards.com/index.cgi?action=display&board=techni&thread=114197&page=1Any pics of the job you did on the Series 3?
Last Edit: Dec 24, 2011 4:36:24 GMT by foxy99
Dec 24, 2011 11:17:54 GMT
I've been looking to see if I have any pictures kicking about, but it seems I have precious few of the car, let alone the work! A722 JRW, a Series 3 in Cobalt Blue and my first car.
I rebuilt it, had a crash in it, scrapped it. The sill job was the passenger side, the drivers side was fine.
The inner sill, floor edge and outer sill had gone along the point where it all joins together... I'd also lost most of the toeboard and jacking point at the front. The corrosion was caused by water getting in around the windscreen edges, then wicking along where the sound deadening foam was placed.
I replaced the floor panel in its entirity, inner sill, and outer sill. Problems I had were the outer sill panel didn't have a sharp enough fold front the doorstep onto the curved face, and the jacking point panel I had didn't quite meet up where the floor and toeboard come together.
I didn't have any panel issues at the rear. Looking at how these cars are built it appears they vary quite a bit from one to the next, for a mass production car...
I'll keep looking, if I find any photo's I'll post them.
Regards,
foxy99
Last Edit: Dec 28, 2011 4:07:03 GMT by foxy99
foxy99
Although I have no pictures of the outer sill when it was still in place I still have the old outer sill I kept it for reference and recently dug it out to check where the holes originally were for brackets that the aluminium 'Daimler' tread plates screw on to. This was an ideal photo opportunity and I clamped it up to the inner sill and took a few pitures of the 'unit' I will throw them away one day....honest! I'd like a picture of the finished car with the pile of scrap cut out of it. A bit like those weightwatcher ones where the slim guy re-visits his old slacks view from under the sills. was there really this much metal missing?old inner sill retains most of its bitumen sound deadening(?) pads. valuable reference point for getting OEM look with new stuff tread plate brackets on top of old outer sill in their original locations. reference for transferring to new outer sill. welds on step show where cover sills were fitted at one time
Last Edit: Dec 29, 2011 3:46:37 GMT by foxy99
bstardchild
Club RR Member Number: 71
The only thing I would say about this job is that I now don't use a spotweld drill for the following reasons - no matter how carefull or slow/fast I use the drill the tool seems to jump out of place skidding all over the area you are trying to cut and it takes ages to do 40 or so in one go
- even if you drill a little pilot hole on the spot weld the pin on the spotweld cutter tool seems to jump out and it is pretty shaky anyway
- the hole it leaves behind is much bigger then the original spotweld and does not lend itself to succesfull plug welds when re-assembling
- they are a good idea on paper but in reality...a pain in the ass
Interested in what you do use now?
gn3dr
