Beautiful work Tony, as always! What do you make of the Gravitex stonechip? I've been looking at the kits on the 'bay that come with a gun as I want to replicate the textured factory finish on my sills. Thanks James
James It's the closest I've been able to get to the look of the original, but I do hope to get one of those spray able seam sealer guns soon and see if that's any better
Thanks Tony, I will order a kit now.
James
May 13, 2015 18:53:39 GMT
Tony,
You said before that you use 20swg on body and 16swg chassis. Just to clarify does that mean you are using 16swg on the floor repairs?
Thanks
May 13, 2015 19:23:16 GMT
Tony, You said before that you use 20swg on body and 16swg chassis. Just to clarify does that mean you are using 16swg on the floor repairs? Thanks wacko Floor pans I use 20swg, chassis legs themselves I use 16swg
May 13, 2015 19:28:53 GMT
So this weekend applied the Shultz and new gas bottle had arrived from "Barnett Welding", so cracked on with the floor repair and started to clean off, still bit to finish but ran out of time
May 13, 2015 19:32:55 GMT
top work. what POR15 are you using, is the chassis black coat, or 2k hardnose ?
May 15, 2015 20:01:37 GMT
May 31, 2015 17:24:03 GMT
small update Got the welding to the floor complete and cleaned off Then stonechipped and primered and Brian started to build the back end up
cjn11
Jun 12, 2015 14:05:47 GMT
Kudos to you and Brian, looks like this will be a minter when she's finished! Thanks for replying to my email, hopefully we'll be able to get an E12 M535 sorted at some point!
Charlie
dbdb
Jun 14, 2015 11:11:09 GMT
Beautiful work as ever - this thread never disappoints. You are truly a master of metal work, Tony. It is a pleasure to see your work.
David
amin
Wow tony your workmanship is second to none.just superb.
1972 Mercedes 250 1973 Mercedes 280 1987 Vauxhall cavalier cdi 1991 Toyota mr2 turbo 1993 Vauxhall Cavalier CDX
Jun 27, 2015 23:26:02 GMT
I've just read this thread for the first time, right through, marvellous work, I will be following progress for sure.
Edit to add -
I was interested to note the sunroof drains, I'm working on a Vauxhall Carlton at the minute and was surprised to find its sunroof drains exit into the sills too and coincidentally I went for much the same solution of taking them out into the wheel well. Its a mystery to me why so many car designers did that, it seems completely bonkers.
I was also interested to see you using some Bilt Hamber products, I'm using several of them myself and rate them quite highly, I'm using Deox gel, Hydrate 80 converter and Electrox zinc primer, good stuff.
Last Edit: Jun 28, 2015 23:33:39 GMT by chris y
I think the reason they put the sunroof drains into the sills is that the manufacturer didn't plan for these cars to stay alive for 30+ years Since 1991, I have BMW E12 520 European model with 4cyl M10, manual, which I am trying to restore now. Seeing the quality of work Tony does, I am amazed and at the same time worried. Worried because now I know this level of work can be done and the welder/painter who is working on my car will not be doing the job to the Tony's standards. By the way, may be I can invite Tony to Baku, Azerbaijan to do a brilliant work?
Last Edit: Aug 5, 2015 20:00:22 GMT by farhad702
same deal on mk2 astras, sunroof into sills. there is a "bus stop" kink in the sill and wing to let it out just below. but that gets mucky and exasperates the issue
dikkehemaworst
Club RR Member Number: 16
1987 BMW E28 M5 Bluedikkehemaworst
@dikkehemaworst
Club Retro Rides Member 16
The front window draintubes of a fiat 500 and fiat 126 , end in the frontwings at the lower part of the ( structual) a-post , were the bottomhinges are and from the factory there is no hole in the bottom of the fender... :-) my biggest catch was 4 liters of water....
nze12
Sunroof drains - always start at the top! The link below takes you to some photos of a 635 donor car in my possession that underwent a comprehensive rebuild 15-20 years ago but had since degraded rust-wise to the point it was no longer economical for me to restore. The moral of the story in some ways is that the drains may appear to be working but in actual fact could well be "diverting" a considerable portion of the water to the inside of your car! retrorides.proboards.com/post/2057141/thread
Last Edit: Aug 7, 2015 19:46:22 GMT by nze12
1986 BMW E30 refreshed to original spec 1973 BMW E12 520 converting to Motorsport 530 1982 XJS V12 converting to 5 speed manual
Many landscaping projects overriding above!
Cogito cogito ergo cogito sum!
The front window draintubes of a fiat 500 and fiat 126 , end in the frontwings at the lower part of the ( structual) a-post , were the bottomhinges are and from the factory there is no hole in the bottom of the fender... :-) my biggest catch was 4 liters of water.... I bet you started exploration after hearing the water splash sound when breaking
Nov 17, 2015 20:59:50 GMT
great work!!!
