Jan 26, 2012 22:52:45 GMT
i see what youre saying, and it makes sense. tbh the person who explained it all to me way back wasnt an engineeer, but knew what he was doing, and his advice has always served me well, nice to know its right but not neccessarily for the reasons he said! the 45 deg thing is still right for the torque thing though, he told me to imagine having a braker bar on the crank nut, and as it meets the mount it shoulf meet it flat, so theyll be at 45deg.
RobinJI
Jan 30, 2012 23:08:48 GMT
Yeah, that breaker bar analogy's pretty good. I was mostly just trying to say that the cylinder arrangement won't really effect the forces on the mounts.
It's also worth remember that it's actually rotating around wherever the output is, with whatever the torque at the output is rather than the flywheel torque, which like you say is usually in line with the crank nut on RWD stuff, but with FWD or rear/mid engined stuff it'll be around the diff outputs, and with a fair bit more torque because of being after the final drive. For instance my minis engine's getting mounted on normal RWD style mounts at about 30deg, but because of the transaxle the engine will actually be lifting up under acceleration rather than twisting.
Jan 31, 2012 20:05:33 GMT
78 Kadett C 2.0 8 valve turbo, holset, rust&other stuff..
roybo
sorry to drag up an old thread...but anymore in put on this subject?most the photos have gone and really interested as it's something i'm about to do
1975 vauxhall magnum 1800 work in progress
sowen
Club RR Member Number: 24
I really liked the look of the mount that Foose built for the Lotus Europa on Overhaulin.
my pics are still there, ive maxed out my account though, it will reset in 2 days apparently. ive got some more to add to this thread when it does
roybo
my pics are still there, ive maxed out my account though, it will reset in 2 days apparently. ive got some more to add to this thread when it does Some great work there Dez they wasn't there earlier though lol just loads of ?'s Straight 4 mount ideas would be great lads .in particular saab b234 lol
Here's a couple I knocked up last week for the Merc'. Inline 5, so close enough Roybo? Cheers, Joe
This was how I did mine, if anyone want's any ideas... Transferred the block mounting template to plate, bolted a hefty washer to the rubber mount on the chassis, then chocked the engine into position and tacked the block mounts to the washers. That gave me a pair of templates like this... I then used this to cut a card template to match the position of the washer, cut that out in plate and tacked it to the block plate with the washer still in place as a reference. This meant the mount was fractionally higher, but gave a little allowance for the squash in the rubber mount when all bolted up. That looked like this Then I simply cut some more plate and tube to create the stiffening ribs, as per my post above. Joe
roybo
That looks good joe simular to what I will need I think .good thing theres plenty of mounting holes to choose from So shouldn't need to be too complicated Thanks
heres a slightly simpler but also more complicated one on a zetec conversion i did. i couldnt move the mount on the car fore or aft, but the breather box was in the way of the mount plus id have had to extend it up or forward a long way to pick up on a third point rather than just use the two bolts at the bottom. so, i binned the breather, capped the hole off with the plate, which served to triangulate the mount up the block, then welded on a barb to act as the breather to connect a hose to, which runs up to the top of the engine bay and has a aftermarket filter on it.
roybo
thats a good way to get round a problem ,Dez top work
Made these to hold the v8 in my e30
Last Edit: Jul 12, 2013 8:42:24 GMT by carat 3.6
