Now thats a decent bit of engineering and a great result.
That's dead handy!
Perhaps add a tab of steel inside as a "stop" so you can just push the end of the pipe up to it and it keeps you lined up as you go round?
Mar 18, 2012 10:12:38 GMT
That's dead handy! Perhaps add a tab of steel inside as a "stop" so you can just push the end of the pipe up to it and it keeps you lined up as you go round? Yep I agree, that's what I'me going to do later. EDIT:
Last Edit: Mar 18, 2012 10:33:07 GMT by claymore
Mar 18, 2012 14:08:56 GMT
That does a real neat job for something so simple.
Mar 18, 2012 14:22:11 GMT
Very nice. I tend to run a bead of weld around a boost pipe if I have to make one myself, but thats much neater and should seal perfectly.
Mar 18, 2012 16:47:17 GMT
Very nice. I tend to run a bead of weld around a boost pipe if I have to make one myself, but thats much neater and should seal perfectly. I used to just flare the ends of the pipes with a pair of pliars, but I thought it was about time I redid all my pipework.
Mar 18, 2012 21:43:03 GMT
Better than my method of going round with the ball end of a hammer.
what a result!
@ CRX_IN_SCOTLAND
