Mar 20, 2012 20:01:13 GMT
Evening all I've been a lurker here for ages, replying where I could help out but seeing as my daily was too modern for you guys I never bothered with a readers ride thread. Well today all that changed! A last minute ebay find meant a train journey to bristol to collect my new car. This is where I need your help, I cant find anything to get it closer to the terra firma. Does anyone know where I can buy a suspension kit from? Or even what else might fit? Have some pics as a thank you
Maximum signature image height = 80pixels
qwerty
Club RR Member Number: 52
corolla ee80qwerty
@qwerty
Club Retro Rides Member 52
Mar 20, 2012 20:46:11 GMT
Looks like a clean one. Anything that works on the RWD Toyota's should work on a FWD one with the added benefit that it won't have been done before.
japclassics
Your trip down memory lane begins here ....
Mar 20, 2012 21:05:11 GMT
Very Nice :-))))
1976 Colt Galant GTO GSR (project) 1984 Corolla AE86 1986Corolla AE82 GT 1987 Corolla AE92 GTI 1983 Mazda 323 GT (BD) (Project) 1998 Corolla E11 1.6 SR 1999 Corolla E11 G6R 2000 Corolla E11 1.6 SR 1997 Corolla G6 (1.3 6 Speed) 1999 Corolla E11 G6R (Project)
Mar 20, 2012 21:10:18 GMT
Looks like a clean one. Anything that works on the RWD Toyota's should work on a FWD one with the added benefit that it won't have been done before. So the ae86 bits should be a go-go! excellent news Japclassic, 50,000 miler and drives like it too. I'm well chuft and cant wait to start putting my stamp on it Thanks for the replys
Mar 20, 2012 21:17:10 GMT
Looks like a clean one. Anything that works on the RWD Toyota's should work on a FWD one with the added benefit that it won't have been done before. So the ae86 bits should be a go-go! excellent news I think what he's suggesting is that any look that works on a RWD Toyota will work on an FWD, not necessarily that the parts will Springs might swap over from model to model but the front struts will almost certainly be different from RWD to FWD.
1989 Peugeot 205. You know, the one that was parked in a ditch on the campsite at RRG'17... the glass is always full. but the ratio of air to water may vary.
Mar 20, 2012 21:47:29 GMT
Ah curse word, I thought it was going too easily. Time to start digging a little deeper. I can find some modified saloons via google but havent found any details as to what has been used and from where.
I've found a spring kit but its only -30mm which we all know isnt acceptable
Mar 20, 2012 21:53:10 GMT
Hey mate - look for parts for the ae86. They were available as a twin cam which had 4 wheel discs and some other goodies. You will probably have more luck finding suspension gear listed under the ae82 model number, and there are forums such as twincam.org and toymods.net.au (both Australian) that should have some good info for you.
Mar 20, 2012 22:39:41 GMT
Nice buy!
I was watching that one, glad someone on here bought it so it will get the treatment it deserves!
Good luck
1994 Mazda 323f 1.6i 16v GLX
Mar 20, 2012 23:16:05 GMT
looks a clean one, the rwd stuff wont work, use lowering springs from a gti ae92 corolla or ee90, i have gti brake setup that will fit this if you have any interest
corolla ee80Robinxr4i
@robinxr4i
Club Retro Rides Member 143
Firstly may I congratulate you on an excellent purchase, very cool car This is where I need your help, I cant find anything to get it closer to the terra firma. Job done! On a more serious note cut spring aren't the devils work and may well give you the ride height your after. As long as its done carefully and methodically it's fine. Plenty of RR regulars have run many, many cars on chopped spring, including myself.
ToolsnTrack
Homebrew Raconteur
Club RR Member Number: 134
corolla ee80ToolsnTrack
@overdrive
Club Retro Rides Member 134
Argh, beaten to it Robin!! All points above agreed with. If they are still seated when the car is in the air, it will go through an MOT. If not, there are still ways around this...
short springs "made that way" will sometimes unseat as well... I had one of these. Mine was the hatchback. Excellent little car, fond memories.
@robinxr4i
short springs "made that way" will sometimes unseat as well... Trufact, I remember fitting a set of -60mm spring to a mates E30 and the front springs dislocated worse than the cut spring in there already!
Thanks for the replies guys, it is appreciated I don't mind chopped springs, I've had them before but I thought if there was something available off the shelf I could keep the originals incase I ever felt the need to put the car back to standard (this will never happen but the thoughts there) Hmturbo, thanks for the offer but the brakes are surprisingly good and this one with is throbbing 1.3 is never going to break any land speed records Slow and low
if its the 12 valve its surprisingly lively. The car weighs next to nothing.
kevfromwales
Mar 21, 2012 11:28:47 GMT
what's the measurement between the bottom strut mounting bolts? as I've used golf coilovers on a variety of 80's nissans now
if you flick between the top 2 photos, it's quite amazing how close the 2 body styles are - I reckon some lows, some nice 14's or 15's (are these 4x114.3?) and a complete lack of any scene stickers and you're there!
berendd
why do I need 3 keys for one car?
Mar 21, 2012 12:13:34 GMT
friend of mine has one of these ni hatchback trim, it is the 1.2 12V automatic and has proved to be rock solid!
just check your oil level once in a while!
good purchase and have fun with it..
Mar 21, 2012 13:30:14 GMT
yep she's a 12v. Actually I was being hard on it, it is nippy and keeps up with traffic on the motorway without a problem.
According to a pcd list its 4x100 with an ofset of 32-35 and a centrebore of 54.1. Plenty of choice of wheels being 4x100 but you also end up paying a premium sometimes as its the same as alot of vw's
Kev, where abouts in wales are you? I'll have to get the tape measure out and have a look at the front struts. Coilovers would be perfect even if they were only on the front
berendd
Mar 21, 2012 13:40:00 GMT
if you run into some taillights for a hatchback or a decent interior, pls give me a pm
Mar 21, 2012 16:10:41 GMT
^^ will do
