woodenspatulas
Retro in ways you can't imagine
Apr 25, 2012 12:29:20 GMT
I'd be interested in some bits of trim.
Ive got a 1999 Vectra and i'd like to do the speedo surround, heater surround, cupholders and gear surround and coin tray.
But my speedo is custom, it has a astra digital dash bonded to it, so i cant remove the clocks themselves. Would you be able to do the surround with the lcd screens still in place?
also theres a small crack where a bit of filler has failed could you fix that up??
1999 Vectra Estate + 1995 Saab Engine = Good Times
Apr 26, 2012 11:22:32 GMT
pm'd!
prey
Apr 26, 2012 11:23:53 GMT
thanks for the replies chaps, just so you don't think i'm ignoring people i will reply to all enquiries tonite!
prey
Apr 26, 2012 23:08:44 GMT
Can I get a price for flocking my AX dash and steering coweling in black? i'd say that was about nova dashboard sized? if so then i can do the dash, glovebox etc for 90 if that sounds ok? al.
prey
Apr 26, 2012 23:10:15 GMT
hi - I could do the speedo hood, heater panel, centre console, ashtray etc for 60 - how does that sound?Cheap as chips!! ;D Ive gotta take the console out for a stereo fit, so I'll send it to you! :-) Whats your lead time? depending how much of a rush you are in - and if we can prearrange things i can get things back to you in 4/5 days if needed. al.
prey
Apr 26, 2012 23:14:22 GMT
I'd be interested in some bits of trim. Ive got a 1999 Vectra and i'd like to do the speedo surround, heater surround, cupholders and gear surround and coin tray. But my speedo is custom, it has a astra digital dash bonded to it, so I cant remove the clocks themselves. Would you be able to do the surround with the lcd screens still in place? also theres a small crack where a bit of filler has failed could you fix that up?? would you be able to send me a couple of pics? a quick google looks like the vectra changed over at 99 so i'm not sure exactly what i'm looking at! i would imagine the trim could be done with the screens in, it just makes it a bit more time consuming with masking etc and ditto for the repairs, no problems to do. if you can get me some pics i can give you an accurate price that takes all those into account. al.
prey
Apr 26, 2012 23:14:41 GMT
Apr 27, 2012 16:24:10 GMT
Can you flock a dash if it's still in a car? No interior to get in the way other than seats.
prey
Apr 28, 2012 11:20:32 GMT
Can you flock a dash if it's still in a car? No interior to get in the way other than seats. unfortunately not, it would be very difficult to get a good finish with the dash in place as you need to be able to move around the whole dash easily at the correct angle and distance. it's also a horrifically messy job so has to be done in a booth in protective gear. al.
prey
Apr 30, 2012 10:08:00 GMT
pm's replied to!
Can you give me a ball park price for a classic mini top and bottom dash rail, speedo binnacle, round bits that go behind the eyeball vents, steering column cowling and a couple of twin gauge pods? All done in black. You can see most of the bits in this auction: www.ebay.co.uk/itm/230777432453I'm only at Rotherham, so can pop down with them easily enough one evening/weekend.
prey
Can you give me a ball park price for a classic mini top and bottom dash rail, speedo binnacle, round bits that go behind the eyeball vents, steering column cowling and a couple of twin gauge pods? All done in black. You can see most of the bits in this auction: www.ebay.co.uk/itm/230777432453I'm only at Rotherham, so can pop down with them easily enough one evening/weekend. i'd say about 100 for all that matey if that sounds ok? if you want to know anything else just give me a shout! al.
prey
also forgot to add i can be contacted on prey@flockingfantastic.co.uk if anyone wants to email/send pics etc. cheers!
al.
bstardchild
Club RR Member Number: 71
Flocking (notts based)...bstardchild
@bstardchild
Club Retro Rides Member 71
also forgot to add I can be contacted on prey@flockingfantastic.co.uk if anyone wants to email/send pics etc. cheers! al. PM me your address details so I can send these two dash sections for your to evaluate - they are only small sections but should be enough for your to work out what you will need to do and as a result cost 1. Carlton dash section (off cut from making a Carlton GSi dash fit a Monza 2. Monza dash section with typical cracks in vinyl and 99% of the reason I want to flock the dash in the first place and why it was rejected in favour of a carlton dash
Can you give me a ball park price for a classic mini top and bottom dash rail, speedo binnacle, round bits that go behind the eyeball vents, steering column cowling and a couple of twin gauge pods? All done in black. You can see most of the bits in this auction: www.ebay.co.uk/itm/230777432453I'm only at Rotherham, so can pop down with them easily enough one evening/weekend. i'd say about 100 for all that matey if that sounds ok? if you want to know anything else just give me a shout! al. Thanks. I will pm you in a couple of weeks or so when the car is back from paint.
prey
also forgot to add I can be contacted on prey@flockingfantastic.co.uk if anyone wants to email/send pics etc. cheers! al. PM me your address details so I can send these two dash sections for your to evaluate - they are only small sections but should be enough for your to work out what you will need to do and as a result cost 1. Carlton dash section (off cut from making a Carlton GSi dash fit a Monza 2. Monza dash section with typical cracks in vinyl and 99% of the reason I want to flock the dash in the first place and why it was rejected in favour of a carlton dash pm'd!
prey
i'd say about 100 for all that matey if that sounds ok? if you want to know anything else just give me a shout! al. Thanks. I will pm you in a couple of weeks or so when the car is back from paint. sounds good, just let me know when you are ready to send the stuff, or if you want to know anything else etc. al.
bstardchild
@bstardchild
PM me your address details so I can send these two dash sections for your to evaluate - they are only small sections but should be enough for your to work out what you will need to do and as a result cost 1. Carlton dash section (off cut from making a Carlton GSi dash fit a Monza 2. Monza dash section with typical cracks in vinyl and 99% of the reason I want to flock the dash in the first place and why it was rejected in favour of a carlton dash pm'd! Got it thanks - Jiffy bag on route to you
prey
i'll get back to you asap when it gets here!
prey
