keithrg
Dame they destroyed 6 mk1 escorts making Fast and furious 6 :(
Jul 11, 2012 14:38:39 GMT
finally got to work on her today running really nice now exhaust isnt leeking and the eletrics are all sorted, on to the carb next then timing. alarms being shipped to me, canabilized a corsa winder handle to tix mine, refitted the stereo but not in dash. centred the steering wheel, seeing about getting the dash retrimmed. Fuel tank of fuel going in tomorrow, Now have eletric washer jets and manaul pumped ones too lmao. found leeak on rear windows to fix removed drivers seat belt. Coat hanger for arial. It coming slowly lol is it leaking from the top rail? or is it from under the seal, I had to remove the rear window in order to fix the window frame, strangely until I removed the seal there was no indication of the rust hole behind the seal! It is through the rear window sills.
keithrg
Jul 11, 2012 20:51:11 GMT
alarm got delivered today wasted no time getting it fitted shock and ultrosincs + Power drain need to fit Bonnet connector tomorrow. Also fixed the bonnet so it only a one person job to open and filled her up with petrol and fuel addative. Quick jet wash too
Davenger
It's only metal
Club RR Member Number: 140
Jul 15, 2012 21:03:37 GMT
Stuyizz is breaking his Avenger estate, and has a load bay liner, among other things if you're interested
keithrg
Jul 16, 2012 11:42:35 GMT
Stuyizz is breaking his Avenger estate, and has a load bay liner, among other things if you're interested Thanks
Jul 16, 2012 18:58:02 GMT
Cheers Dave, yep I'm now breaking my avenger estate after finding one too many previous bodges, I'll get some photos up and a full listing in the for sale section as soon as I can but if you want anything PM me on here
keithrg
Jul 22, 2012 10:45:32 GMT
Hi AL I sure will. done a few more bits nothing major as yet. new rota arm fitted home made panal for dash houseing a now working cigarette lighter and socket Adjusted and oiled the doors alarm sensor unit and didgitail clock. Steering wheel adjusted again but now needs tracking to get it straight 100% (I HOPE LOL) Another exhaust repair Home made silencer made and fitted Should aid back pressure. Past 50mph it was a head ache and car was struggling to do 70mph. checked reversing light bulbs all fine, checked reversing light switch, Its not there lol. Might explain why they don't work. Fitted some push on led lights in car as interior lights don't work. wired in manaul immobolizer Wired in a direct live to stereo so dant have to reset it ever time tidied up all the additional wireing and connected alarm positive trigger Black taped the damage dash for now fitted an air freshner and new tax disc holder Wired up rear are speakers and disconnected the original front one. Fitted a PA/SIREN/FOG horn system lmao, should be fun Couldnt fit dixy horns not enough room Always park with the back of car down hill so water that gets in drains out ( Flushed coolant replaced thermostate and refilled. order new distrubutor cap will fit tomorrow ordered and recieved some security widow film tint (mirror type) for rear load area pos rea passenger. not sure yet going to install this asap Going to get oil, oil, filter and flush next week and get that done Might fit the roof rack found out the switch on light stalk is the dimmer switch lol
keithrg
Jul 22, 2012 18:16:38 GMT
Well bit of bad news had to go over lots of speed humps and after a in succession the exhaust started blowing again think I'm gonna have to cut out a second section and can it
keithrg
Jul 24, 2012 19:58:24 GMT
The exaust is fixed with silicon yes silicon my freind suggested it I though he was made but for a £1 tube its not leaking and I have 2/3 of a tube left Fitted reflective tint to rear load area and rear door quarter lights today. NEW Dizzy cap fitted to. Sound system set up and decided I will remove chrome strips from Gutters and chrom paint the gutters instead. Going to try and chrome paint the rear window surround. Will tint out the rear passenger windows too Fitted a Sunstrip to could have been lower. never mind lol
Jul 24, 2012 20:53:09 GMT
This thread is seriously lacking in pictures! which bit of the exhaust did you bodge with silicon?
Jul 25, 2012 10:53:39 GMT
Have you decided if you are going to lower it and what wheels you want yet? Good work so far!
keithrg
Jul 25, 2012 14:26:27 GMT
This thread is seriously lacking in pictures! which bit of the exhaust did you bodge with silicon? Its a joint under the passenger seat. its all pretty bodged with exhaust needs a new one really from manifold back. Sorry I have real issues uploading pictures Got internet engineer due out tomorrow
keithrg
Jul 25, 2012 14:32:09 GMT
Have you decided if you are going to lower it and what wheels you want yet? Good work so far! lol no not goining to lower it if anything I wanna raise the back to match the front man. If someone buys my Orion ILL see if my alloy fit.
keithrg
HI ALL Hopeing to do oil and filter change tomorrow taking her of the road as I need to sort the exhaust and missfirer (arghhh) on a plus side I got 26mpg which I was well chuffed with considering how poorly she is. recon on 32mpg when sorted
Last Edit: Aug 2, 2012 22:45:26 GMT by keithrg
keithrg
oil and filter changed passenger rear door windows filmed (badly)
djefk
And his photography / spelling haven't improved much in the meantime!
keithrg
Feb 10, 2013 21:16:28 GMT
Last Edit: Feb 10, 2013 21:17:57 GMT by trigger
keithrg
May 15, 2013 19:15:19 GMT
went for a good price hope the paint job was good. Regrete selling but I couldnt get it to the standard he did.
