Jun 26, 2013 18:56:32 GMT
Thanks a lot, Marten! I'm not an expert, but I know my way around those cars; I earn my money with working on them Funnily enough, RR does seem to know me as a 'Merc guy' - but in reality I'm a 'Mini guy', owning my Mini almost 10 years now. Which was my first car and until 2 years ago my daily My job takes a long commute - and so I finaly got realy into W124s and W123s, but the interest started a bit earlyer. Also a reason for adding the Turbodiesel to the car - it's a better commuting engine and those big capacity diesels - I find them very relaxing to drive Which is just what I need on the stuffed autobahn in the evening. Having said that; the coupé feels WAY faster than the TDT did It's 200kg lighter and the totaly clogged air filter probably seriously restricted breathing... Cheers, Jan
Jun 26, 2013 19:02:08 GMT
Since no update today, here's a quick walk around:
Jun 26, 2013 21:32:08 GMT
This has really come together nicely Jan, you must be pretty stoked with the fruits of your labour.
It's yours and Dave's cars that are stopping me from throwing the towel in on mine!
Joe
Last Edit: Jun 26, 2013 21:32:46 GMT by Deleted
mk2cossie
Club RR Member Number: 77
Jun 26, 2013 23:30:10 GMT
This is one of the most in depth engine swaps I've seen Is there that much different between the two models that needed the looms swapping over? Or was it done for the extra functionality that the diesel car loom has that the whole lot was swapped? Very nice project though, and the merc 6 cylinder dizzels do sound good
Jun 27, 2013 16:18:03 GMT
This is one of the most in depth engine swaps I've seen Is there that much different between the two models that needed the looms swapping over? Or was it done for the extra functionality that the diesel car loom has that the whole lot was swapped? Very nice project though, and the merc 6 cylinder dizzels do sound good Thanks a lot! I think it's interessting, that's why I document this in such detail... The wiring loom is completely different; whilst the petrol engine has like a dozent plugs & connectors, the diesel has - 4 1 of which is for the air con compressor (the blasted thing!!) - though I'm still in doubt if I actually swap the electronic idle controll over - the car doesn't seem to need it. But maybe in winter it does? And with aorking air conditioning, it certainly needs it - as the compressor draws so much power, it would stall in idle when you turn the steering That said - the looms are all separate systems and can be removed individually - one of the beautifull features of pre-CANbus era cars You can add and remove stuff pretty much "as it pleases you" without causing too much trouble. On the other hand it means: LOTS of wires... --------------- Today I didn't have terribly much time - but I got as far as taking apart the front suspension. And of course I found more stuff that needs replacing, like sway bar bushes, brakes and a thorough regrease of the wheel bearings... Which means; parts ordered, and I'm ordered to a break untill parts arrive. So much for the plan of visiting TÜV on saturday - don't think this is going to happen. But no need to rush it now... Always scaring; removing springs... *sweats* New ones are not much longer - but the extra coil means it's going to be tough to get them in... The old ones barely got out. But: almost flawless A-arms! Another sign of just how good this car is! Usually they'r total rotten and scared... Reason why they need removing: driver's side is fubard. Probably due to a leaky steering gearbox. Another thing on the list of stuff to sort out... Will try to get hold of a 3.1:1 Sportsline steering box, as the Coupé has a long-ish 3.6:1 and I feel it's a tad too indirect. Low priority, though. And naother pile of scrap... Cheers, Jan
benzine
Club RR Member Number: 87
I love reading this thread, great project!
Jun 28, 2013 17:16:46 GMT
Thanks!
At the moment I'm having a major tin worm, though - and I can't find any errors. I've basically reversed all electrics I did - problem persists... I'm out of ideas and will give this thing a break for now - I need to re-start my head. Electrics are bl00dy disgusting! I hate electrics, even worse if they don't work and I'm forced to tinker with them... Blargh! I need a break.
Cheers, Jan
rr69h
Jun 28, 2013 19:43:24 GMT
What's wrong with the electrics?
"Racing drivers never carry cash"
Jun 28, 2013 20:03:57 GMT
If only I would know... They don't work. Indicators, heater, horn(s), half gauge cluster... I've checked everything - no faults. Need a mental break. It all worked just 2 days ago - now dead. I'll find it, I'm sure. But catching tin worms is such an incredibly annoying work... And worst of all, there are no proper, complete wiring diagrammes in the workshop manual. Which makes it even more frusttrating to find the needle in the hay stack. Horrifying!
jpsmit
Jun 28, 2013 20:36:07 GMT
If it is that big a failure, either it is a ground issue, a fuse issue or (hopefully not) you`ve let the smoke out of the wire harness in a big way issue. Is there a `main`fuseÉ
I know how you feel mate... just ignore it for a week and as Joe put it, let it ignore you back. I´m sure you´ll get it sorted Jan
Well - against my theory, current does not travel through fuses in both directions... *WTF!?* I probably confused the terminal (=end of fuse) when I put the pre-glow relais in. Changed the terminal to the other side of the fuse - all working again. Hnngh. What the...!? BLACK MAGIC!!! (or I'm probably just severly incapable of electrics :-> )Now - engine wiring loom Also dropped the A-arms by at a local garage to press in new ball joints (neither do I feel like playing Hulk, nor do I have the right tools) which will be done tomorrow. Set of new brakes, sway bar bushes and two BIG tubes of Castrol LMX arrived with the post - that's the front suspension done for the next decade And I'm at a point where I realy can't sell the car anymore - eventhough some people allready felt like putting they'r hand on it "If you sell it...!" "erm - nope". Next thing after TÜV will be the rear suspension, mainly the subframe mounts. And then I can hopefully eat some miles
With sh!t working again, I was motivated to tackle the engine wiring loom. Most surprisingly - wiring the ELR took the grand big sum of - 2 wires TWO! Only the air con relais is missbehaving and switches the fan on with ignition - but I still have a couple of wires left there It looks like the ELR is working!! Idle is very low without ELR, with the pump's magnet plugged in idle shoots up and is immediately catched and brought to a slightly higher idle which does sound about correct. I've not yet wired the rev counter in - by ear it is fine. And much smoother than without ELR! Sound positive, eh? And tidyed the engine bay up a bit after installing the engine wiring loom. Also new sway bar bushes, the old ones were far beyond use... Surprisingly, the sway bar is in very good nick, no deep rust scars - which is a first! A-arms with brand new Lemförder ball joints - soaked in Owatrol oil to do something against the surface rust. As the spring seats were a bit rusty. I soon realised though, that a "set" of bushes is indeed a set "for one side" and contins 4, not 8 bushes. Duuuh... Ordered another "set" - more waiting. Sigh. Oh well... So instead of putting the front suspension together I removed the remains of the bonnet insulation (ice scraper works well!). And realised I had no suitable glue. And skipped this work as well Ok, so maybe TÜV will see me next week - by now the car also need a regular inspection (MOT). At least I can do all at once then. But this means inspecting the car a bit closer for possible fails - and perhaps welding the rear wheel arch before I drive it to the TÜV station. Cheers, Jan
It looks like the ELR is working!! Idle is very low without ELR, with the pump's magnet plugged in idle shoots up and is immediately catched and brought to a slightly higher idle which does sound about correct. I've not yet wired the rev counter in - by ear it is fine. And much smoother than without ELR! Sound positive, eh? I've just checked the workshop manual - and that's indeed the proper(!) test procedure Take plug off injection pump - wait a bit - put it back on. If revs shoot up briefly and idle is lower without the plug connected - all is in perfect order That was FAR easyer than I ever thought it would be. Amazing! Cheers, Jan
Still waiting for a-arm bushes... They were sent out today - if they don't arrive tomorrow, they'll do so,as the company they are shippedwith doesn't deliver saturdays. Hrmpf. I want this thing back on it's feet now... Anyway - a eBay bargain arrived today, at least. A spare radiator. And the main reason I bought it was the oil pipe that's attached to it. Mercedes wants over 75€ for it. This was 59€ to my door and came with a very good spare radiator. Win or what? Oil line was installed propmtly - MUCH better! It's a bit awkward routing, but looks a lot better than my bent gaser pipe... Before: After: Next job was the belt damper. I soon realised that the water pump pulley had to come off. Which meant: removing the viscous fan clutch. Which meant: break your fingers and try to get a hex bit to the bolt holding it, there are like 5cm space between the radiator & bolt. But I managed it and even managed to put it back. And all that, because some engineer decided he'd make the lower bolt holding the damper 1mm(!) too long to get the damper out. ARGH! Overengineered cars my a$$!! And unfortunately, that's all for now... Cheers, Jan
Several things arrived in the post today. Rudolf Diesel's, what he thought it was, most important work; "Solidarismn" (ISBN-10: 3875124162). Then: the last pair of bushes for the a-arms arrived - finally! Which were promptly installed... Then my exhaust arrived from Poland - 85€ to my door. Incredible... And for that it looks rather good! I cleaned up the welds, gave them two tick coats of zinc and then painted the backbox dark grey to hide it a bit undertha car. I didn't fit it, as the axle stands were still under the front end - which I assembled today, bar the spring on the driver's side, as I felt too tired to play with it... Getting there... Other side looks the same, bar the spring. So no pic of that.
Took some kilometers on the odometer today - all working well! And... It's fast! Not as fast as before, but differently fast, from low down. Which is very enjoyable! And the purr of the engine when it revs at 1500 to 2000 - aaawwwww! However, one think is not working. Which is the kick-down. And I soon knew why; it's controlled by the air-con relais which with the diesels with auto box is also a kick-down relais. So... I took a piece of cherry pie and dug into the wiring diagrammes. And realised: THIS is going to be the real PITA wiring! I thought it would be the idle controll - but no, it's this. Anyway, no way to avoid it, except pass on air con & kick-down Also the front end is a little too high. But there are the thickest available rubber pads on the springs - the thinnest will bring it down 15mm which should be enough. And I think it'll settle a bit anyway. Well I hope it does. As far as the stiffness of the springs is concerned; the ride is spot on! Sooooo... Two jobs left: put interior together, kick-down wiring - and then TÜV. Oh and bleed the ASD & SLS. That's three, actually. I'll make it four, as there'S probably something I totaly forgott about Should learn to actually put 'to do' lists on paper... Cheers, Jan
MAIDEN VOYAGE! Took it for the first prolonged drive and a first fuel stop. All on private roads, of course In the second pic you can see that the exhaust looks as stupid as it always did. Sticking out a mile... This and the fact that the pre-silencer was more rotten than I thought led to the decision to fit a new exhaust immediately. Thsi is how it should sit! Finally!! Incredibly, the exhaust fits like a glove and is tight. No tinkering neccesarry. It only took me a while to realise that it had to be fitted in reverse order, backbox first and then the pre-silencer. Otherwise it didn't fit. Weird - but true... And - all lights light up! Cheers, Jan
Glued on the bonnet insulation - was easyer than I thought Amazing; when cruising with 30 all you can hear is the tyres... Awesome! And: kick-down works. And that's the last bit of wiring done. Apart from making it tidy again. Didn't feel well last couple of days, so not much done. But the car is coming together slowly. Only the hight at the front is bugging me majorly. I can maybe get 3cm with the thinnest spring pads - but that's it. It's close, but it might be just enough... If it isn't - well fcuk.
rr69h
Well done Sir! I bet you're well chuffed.
