task
More updates! Done a few bits and pieces, new MGC bonnet arrived so a trial fitted it along with the carb and air cleaner to see if I had enough bonnet clearance. I didn't. This has hopefully been rectified with a much lower engine mounting rubber on the L/H of the engine bay, won't know till I've re-fitted the bonnet. Prop shaft was fitted, hole extended in the transmission tunnel for the gear lever, bonnet stay fitted. Fans/Rad/Hoses/Distributor/HT leads etc arrived and are awaiting the end of painting before being fitted. Speaking of painting the front and rear valence also arrived, so they were fitted. Rear valence took a lot of blending to fit. The whole body was then covered in several thick coats of high build primer-filler before being rubbed back with wet-n-dry, it's now sat awaiting some top coat! More by the end of the weekend I hope
adam73bgt
Club RR Member Number: 58
Great progress Just been having a read through again and I noticed you've done polybushes at the front, can you remember how hard/easy it was to do the top wishbone bushes at all? I'll be doing the front suspension on mine soon, I've already pushed the bushes into the lower arms, but am going to have to do the top ones on the car
Coming along very nicely!
task
Great progress Just been having a read through again and I noticed you've done polybushes at the front, can you remember how hard/easy it was to do the top wishbone bushes at all? I'll be doing the front suspension on mine soon, I've already pushed the bushes into the lower arms, but am going to have to do the top ones on the car Pretty easy from what I remember, just pressed them in with the vice. Not sure how easy they will be in the car, might be do-able with a G-clamp. Cheers Flyingphil
task
May 10, 2014 19:32:13 GMT
Now with added colour... The holes you can see in the bonnet are for the bonnet pins, the bonnet was only sprayed at lunch time so still drying, I'll add them soon.
niwid
May 10, 2014 22:58:18 GMT
I'm thinking this is going to be rather lovely when finished. Loving the colour choice
May 11, 2014 11:51:38 GMT
Can you paint mine please!!
72 MGB GT 88 Daimler Double Six 89 Rover Mini 91 Nissan Figaro 95 Lotus Esprit S4S 18 Discovery
task
May 18, 2014 22:03:19 GMT
More updated! Rear lights fitted Tailgate painted and fitted Tailgate screen fitted Rear spoiler painted and fitted Side lights fitted Bonnet fitted correctly along with seals Bonnet pins fitted Bonnet release cable fitted I also did a load of behind the scene's stuff; Radiator fitted along with the majorly uprated cooling fans. Wiring loom fitted back in and the loom for the rear re-ran inside the car rather than underneath. I hate running wiring under cars. Dashboard fitted, need to modify the tach to take the 8cyl input not the 4 cyl. (twice as many pulses). Managed to remove the steering wheel finally, with the help of a ridiculous hydraulic puller. It wasn't very "round" when I'd finished. Windscreen was fitted but I need to fettle the fitting slightly, so more work required there. Thanks for reading
Ian
Great colour choice! Coming alond nicely.
task
May 26, 2014 21:25:47 GMT
Bit more progress; Bit of an odd jobs weekend this time, I kept pushing the car outside to work in the sun and then it would start raining so inside it'd go. Trimmed the side panels and fitted the brightwork so I could fit the rear windows. Removed the windscreen as I'd forgotten to trim the front of the roof in headlining, refitted the windscreen and added the spreader insert. That's a job I don't want to do again. Fitted the headlamps, which didn't take all that long but visually made a massive difference, see the photos at the end. Repaired some of the damaged wring loom, wired the headlamps, side lamps and cooling fans. There are only a few cables that need plugging in now, the end of the wiring is in sight! Fitted the new switches to the dash, cleaned up and repaired the column stalks and fitted a new ignition switch. Modified the new throttle cable to fit and attached it at the accelerator. Fitted the new fuel filler and plumbed it in. Finished plumbing the remote oil filter. Probably a few other jobs I've forgotten to mention A few photos taken as I was moving the car back into a different garage bay, it's getting a little heavy to push now so I should probably think about getting some life into the engine.
adam73bgt
May 26, 2014 21:57:54 GMT
you're making great progress on this, looks really good Got any plans for wheels?
task
May 27, 2014 10:11:04 GMT
you're making great progress on this, looks really good Got any plans for wheels? My wheel choice is a little boring, just gone for minilights with a slightly different offset to standard, I can't wait to fit them though as the wheels currently on there are really starting to look shabby!
adam73bgt
May 27, 2014 10:22:41 GMT
Ah well they may be a common choice but they do suit the look of the B very well If you got ones with the dark grey centre with polished lip it would give a very nice contrast to the orange but should look great whatever colour Need to get that ride height down a touch though
task
May 27, 2014 10:39:51 GMT
Ah well they may be a common choice but they do suit the look of the B very well If you got ones with the dark grey centre with polished lip it would give a very nice contrast to the orange but should look great whatever colour Need to get that ride height down a touch though They are actually silver with a polished lip I know what you mean about the ride height, they are supposed to be lowering springs but they don't seem to be living up to their name! Once it's all built and on the road I can play with ride height and roll bars etc. though. It does currently sit very high, however the Range Rover sat quite high for a week or so and has now dropped a fair bit.
adam73bgt
May 27, 2014 10:57:44 GMT
Ah well they may be a common choice but they do suit the look of the B very well If you got ones with the dark grey centre with polished lip it would give a very nice contrast to the orange but should look great whatever colour Need to get that ride height down a touch though They are actually silver with a polished lip I know what you mean about the ride height, they are supposed to be lowering springs but they don't seem to be living up to their name! Once it's all built and on the road I can play with ride height and roll bars etc. though. It does currently sit very high, however the Range Rover sat quite high for a week or so and has now dropped a fair bit. Ah nice, they do look good (when they're clean mine were forever covered in brake dust haha) Mm given a bit of time they should settle down somewhat, ah I forgot the later B's have the rear anti roll bar also. I've seen a few pics of B's with lowering springs on the rear and they all look higher than mine which makes me think I should just stick with my tired old rear springs aha
May 27, 2014 12:07:34 GMT
Coming along Very nicely now....
May 27, 2014 12:17:54 GMT
Got to love a nicely put together B. Have a pic of my mates recently completed B.
crahel
that's one crazy looking manifold.
1973 Lancia Fulvia s2 coupe (sold) 1998 Audi a4 sedan (sold) 2000 Nissan maxima (sold) 2007 Audi convertible.
Sept 4, 2014 14:16:30 GMT
Have you sacked off the idea of using the Mk1 arches then?
Do you want rid of yours - as I'm looking for some for my MGB roadster V8 Conversion.
All the best,
JB
task
So, this happened at the weekend... you'll want headphones for the video Lacking photos but; Brakes bled and working All lights working Gauges working with exception of oil pressure Sunroof fitted Seats fitted Dash finished off Cooling fans wired Heater valve plumbed Ignition wired Washers wired/working A minor setback, I wasn't happy with the steering so stripped the column out and found it was not as it should be, too much slop. I've ordered a new one along with a new UJ.
