Tepper
Jan 30, 2013 19:32:44 GMT
Seeing as it's warmed up a bit I thought I'd get on with changing the engine mounts. I'd been putting it off for a while because of the cold, got some new mounts for £18-ish each from GSF a while ago but hadn't gotten round to fitting them. This is also the first time I've really taken pictures of a job as I've been doing it - take a seat, they're pretty exciting. This is when I decided to take pictures, old and new mount: I think the mount that came out is the original, it's quite deteriorated: This is where I got stuck. The bolts that hold the mounts to the engine are quite tight and this one sits under the inlet manifold so you can't really get anything in there. I can get a 3/8" ratchet in there but I couldn't shift it, despite profuse cursing: The coil normally lives here on the inner wing, I took it off to try to get a breaker bar with a deep socket in there. No luck. So I left the car like this: And went to Drew's. Brilliant, old school ironmonger that happens to be round the corner from my house: To buy this: With a normal socket, I could just get the breaker bar onto the bolt, but there's not enough clearance anywhere to even crack the bolt off. By this point I was getting hungry and irate so I left it for the day. I'm going to borrow a beefier ratchet and try using that but if that doesn't work I'm out of ideas! Suggestions welcome
1989 Peugeot 205 GTi - stolen! 1983 Mazda RX7 1968 Rover P6 - also stolen.
Tepper
Well I managed to do the engine mounts and set about fitting the 40mm springs: Thanks to Paul/MrSpeedy for letting me hire the proper spring compressors for the job: Shiny! I didn't take a proper 'before' picture, I only really have this: After: I quite like the way it looks without the wheel trims, I'm tempted by a set of 16" steels either satin black or painted to match the darker silver around the bottom of the car. I'll be keeping an eye out in the scrapyards round here for something suitable!
macp
I like that its a sensible drop and keeps it looking fairly oe. Now I'm off to search AT & ebay goddamnit
Tepper
Do it! I really like the 190e's, this is the second one I've had. The owners' club is a good place to look for one and if you're not afraid to get your hands dirty they're pretty easy to get properly sorted with all the info that's on their website. Scored this lovely slice of 90s Alpine goodness on a popular auction website to replace the tacky blue/green/orange Sony that was in there:
Tepper
Just won this to go with the stereo: I'm thinking I'll probably be able to hack an aux connection into the cable between the changer and the stereo, which worked well on the factory stereo in my old 306.
Tepper
Feb 13, 2013 13:29:20 GMT
I've been spending plenty of time soldering tiny little plugs to make up the various cables I need for the stereo install. But in other news... Yay! Wheels! They're on their way from Germany, 16" 'Toliman' alloys apparently made by Fuchs. I'll probably just take the laquer off and polish them, depending on their condition. They should be with me next week sometime.
Last Edit: Feb 13, 2013 13:30:43 GMT by Tepper
Feb 13, 2013 16:17:51 GMT
I love a good 190e - I used to have a 2.0 auto myself in Almandine red and cream interior with regards to your hard to start issue and slight vibration when running, I had something similar - have you ever seen anything about the 10amp fuse somewhere? I'll have to do a google search but mine was so hard to start in the morning (needed lots of accelerator pressing and multiple key turns) until I read about a fuse somewhere (I seem to remember it wasn't with the other fuses - maybe behind the battery??) anyway, swapped this and boom, started first flick every time!
Tepper
Feb 13, 2013 18:29:32 GMT
Yeah, it's the fuse on top of the OVP relay, which can cause all kinds of weird issues. And you're right, it lives behind the battery next to the ECU. The fuse on mine is alright, but I think the OVP might be bad. I've got a replacement but it's got too many pins to fit in the socket, I'll get round to finding a proper replacement at some point. Almandine and cream is a really nice combination, especially in sportline flavour
Feb 13, 2013 19:59:54 GMT
good choice on the wheels - i was gonna say the same when i saw you said you liked the look with no wheels trims - then i scrolled down!
Tepper
Feb 14, 2013 21:34:46 GMT
While I've been waiting for the wheels, I decided to crack on with my period-ish sound system. The goal was to keep it nice and subtle, while also trying to keep it as cheap as possible. I had a bit of good luck with the CD changer - it arrived jammed with some rather awful CDs, so I contacted the seller and told them that it wasn't working properly. They let me have it for £5 and it took me all of 5 minutes to take it apart and un-jam it. Happy days! Next step was to go to Maplin and pick up some bits and pieces: The CD changer didn't come with a cable, but luckily it uses standard 8-pin DIN plugs. Which happen to be a complete curse word to solder: Maplin sells some cable that's ideal for CD changers: It's shielded, and has separately shielded cores within it - perfect for the audio signals. The plan was to make up a cable, but with a box of tricks in it near the head unit: As standard, the head unit won't accept an AUX-in. However, with a CD changer connected and playing, you can splice into the left and right channels and run your own audio into the head unit. That's precisely what the box does: I used a 6-pin DIN plug hooked up to a switch that will be mounted on the dashboard, so that the box can get tucked up behind the dash somewhere. Once it's all fitted, it will be completely hidden apart from the switch. This PDF helped me a lot when I did this on my old 306: www.fccuk.org/uploads/downloadfiles/ClarionC.pdfSo after much tiny, PITA soldering, I went out and tested it and it all works. I just need to finish wiring it up into the car and all will be well! I left the inside of the car looking like this for the time being: I didn't really get that many pictures, but I've probably made well over 40 solder joints to get all this done, so I'm pretty happy the electronic side of things is finished! If anyone is thinking of doing something similar with their setup I'd be more than happy to help, I've got Maplin part numbers as well if you fancy giving it a go.
squonk
Feb 14, 2013 23:39:56 GMT
Just won this to go with the stereo: I'm thinking I'll probably be able to hack an aux connection into the cable between the changer and the stereo, which worked well on the factory stereo in my old 306. I seem to recall that these use Alpine AI Net (M Bus) interface which is very difficult to 'hack' properly without the addition on external circuitry to provide the digital responses the head unit requires from the changer. I think I may have a link somewhere with a how to do it feature. I like your method but it is a bit 'dirty'!! I'll try and find the link for you.
Last Edit: Feb 14, 2013 23:44:35 GMT by squonk
squonk
Feb 14, 2013 23:41:31 GMT
Tepper
The CD changer I have uses M-Bus, which is the interface Alpine used before they switched to Ai-Net. The method I've used wouldn't work on an Ai-Net stereo, because as you say it's a more complicated digital interface. I suppose the method I've used is a bit 'dirty' but it's cheap and it delivers excellent sound quality. I was toying with the idea of using a Raspberry Pi to interface with the head unit but at the moment it's a bit beyond my capabilities, I can't write code to save my life
squonk
AI Net is a derivation of M-Bus. The link I have posted is for M-Bus adaptation so will work with your system. Some of the M-Bus systems can be configured to operate via the CD audio input without having the CD changer connected but I cannot remember how it is done. It's a long time since I was in that business!!
Tepper
Feb 15, 2013 19:55:14 GMT
I'm sure you're right but this method does the job, although it would be nice to have a more elegant solution. Came downstairs this morning to find a rather large box from Germany which contained a set of these: It's hard to tell with just the rim on the car jacked up, but I think they'll look good polished. The clear coat is peeling badly on all the rims so I think I'll strip them back to metal, sand away any corrosion then polish them up again without putting on another clear coat.
Tepper
Mar 13, 2013 20:03:26 GMT
Not much progress to report, just been doing little bits like replacing the fan belt and tension adjuster assembly. Stopped a weird noise that turned out to be the old belt flapping about all over the place! I do like working on these cars, the tensioner mechanism has obviously had a lot of thought put into its design which I appreciate. I've also given it a service with Shell oil, oil filter, air filter and fuel filter. While doing the fuel filter I was treated to a lovely faceful of petrol because I forgot to loosen the fuel cap to depressurise the fuel system. Oops. ECP has also supplied me with the wrong air filter which isn't particularly helpful... On the wheel front I'm waiting either for the weather to get a bit better or to save up some money to have them done professionally. I need to get some cash together for tyres too so I don't expect to have them on the car any time soon
Tepper
Won this sub and 4 channel amp after a sneaky eBay bid: It sounds good, having the rear speakers powered by the amp rather than the head unit seems to make a lot of difference. The guy even threw in all the cables for free which was nice. Apart from that I've managed to cure the high idle, I spent ages removing and cleaning the auxiliary air valve but in the end I gave up and used the idle air adjustment screw. We're now down to an 800-ish rpm idle which is a lot better than 1,200
Tepper
Just a quick update on the wheels, I bought a polishing kit: www.ebay.co.uk/itm/Wheel-Polishing-Kit-16pc-For-Alloys-SPWK-0002-/300390665792?pt=UK_Motorcycle_Parts&hash=item45f0adce40And today I had a quick go at polishing the parts of the wheels where the laquer would just peel off: I was surprised at how well the really corroded areas came up, I might not even have to sand them. Which would be nice ;D Before I start polishing them properly I'll need to strip the old laquer off, so I left it like this. You can see how much of an improvement there is on the areas that have had a quick go over: Might get the laquer stripped off tomorrow. I'm also thinking about changing the centre caps for some like these: I have to say that polishing the wheels is a pretty pleasant task in this sunny weather we're having at the moment. Hopefully they'll be on the car before too long.
Tepper
Jun 16, 2013 21:37:01 GMT
Nothing much going on with the car lately, managed to give it a good wash and wax today and made a bit more progress with the wheels. One's pretty much finished: It's a bit of a pain getting them all polished up and sanding away all the corrosion that built up under the laquer but I think they'll suit the car well when they're done.
