Feb 14, 2013 20:47:08 GMT
Yeah that was 12 years ago though, things have gone a bit mad since then! Mind you it is "only" a fwd HF Turbo so not really regarded as anything special next to the Integrales. 14/02/2013- Here's a photo of the layout of the system from the bottom of the downpipe, through the centre box and out of the polished tip. With its simple route and 2.25" diameter it should flow quite nicely for the approx 200bhp output of the engine- Guy
Mar 21, 2013 22:27:56 GMT
21/03/2013- With the low seating position the standard wiper setup got in the driving view so I decided to convert to a single wiper and park it over on the passenger side. I didn't want it parking in the 11 o'clock position so i'd need more travel, enter trigonometry and some rose joints- Now I need to find a wiper arm with just the right crank on it. Guy
Mar 21, 2013 23:33:30 GMT
What a great project. I'm a fan on the stock wheels, but your choice of rims do work .
Mar 23, 2013 14:43:38 GMT
What a great project. I'm a fan on the stock wheels, but your choice of rims do work . Thanks mate, yeah the 8v integrale alloys do look good but you can only get 195's on them, you can get 205's on the wider 16v alloys but they cost a small fortune which would kinda go against the budget ethics of the project. At least 205 tyres fit the Audi wheels, they're cheap and look period. I also like the fact that they'll be a bit different in the lancia circles, looks like i'll need hubcentric spacer/adaptors and therefore i'll need to flare the arches (maybe the JDM style ones in the for sale section). Guy
Mar 27, 2013 18:01:23 GMT
Mar 28, 2013 17:43:57 GMT
28/03/2013- For safety reasons I have to seal all gaps in the bulkhead and where the gear linkages go through still needed sorting. A piece of rubber sheet, a couple of bellows and some offcuts of silicone hose later.... Guy
Mar 29, 2013 22:00:07 GMT
29/03/2013- Fairly productive day today. Got the battery strap finished- Got all the loom supply wires armoured-up and also dressed in all the large positive wires to the distribution terminal and down to the starter motor- Negative wires are almost in now, I just have to modify the inlet manifold bracket to aid wire support and weld in the body earth point next to the battery. Guy
05/04/2013- Negative cables all in now- ARB locator clamps that i machined and had anodised are in place- Ultrasonically cleaned the injectors and gave them a lick of paint- Along with the fuel rail- Started lining up the fuel regulator- Started P clipping the fuel lines into place- Guy
Apr 26, 2013 22:04:34 GMT
Apr 26, 2013 23:58:13 GMT
Quality and Bookmarked!
Apr 29, 2013 17:01:28 GMT
Apr 29, 2013 22:05:26 GMT
some lovely fabrication work, always loved the Delta
luckygti
I need to try harder!
Blimey, some serious work going into that. Loving all the detail stuff, and just a bit jealous of the lathe ;-)
Scruffy
MG Maestro Turbo #496
Great work! Love Deltas!!!
*****MG Maestro Turbo # 496*****
Follow me at
FourNineSix
Thanks guys, getting worryingly close to the "big switch-on". Gotta finish the dump valve plumbing then prime all the fluids......then watch them all leak out when i start her up! Guy
Jun 30, 2013 10:46:31 GMT
Jun 30, 2013 18:09:31 GMT
WINNING! I understand Mr. Cook is going to do some high quality photography of the Lancia soon?
He sure is! I was meant to get him to snap it before i put the front bumper/bonnet back on so you can see all the coolers hanging off the front, but i got carried away and threw it all back together! MOT friday morning for the win! Guy
