Hello Retroriders!
I have converted my automatic Capri to manual, and have everything you'll need to convert your Capri/Sierra/Cortina/Pinto Engine to Automatic.
The auto box works perfectly, and I have reciepts for a very expensive rebuild that was less than 8000 miles ago.
Has come off a 69000 mile 1979 Capri GL
Comes with:
Gearbox & Bellhousing for Pinto
Crossmember
Torque converter & flywheel thing
Propshaft (same as 5 speed prop)
Vacuum take off for inlet manifold
Reverse/neutral sensor switch
automatic pedal box with accelerator/brake
automatic gear selector lever
All nuts & bolts needed (except bellhousing - engine)
Not really sure what this is worth, £200?
I'm located in Epsom/Kingston and can deliver if you're local!
Will not post as it's too cumbersome.
I'll stick some pictures up if anyone shows interest.
Thanks,
Jimmy.
Comes with:
Crossmember
Thanks,
Jimmy.
