Mar 15, 2013 19:03:31 GMT
Mar 15, 2013 20:54:51 GMT
Good work
Mar 27, 2013 21:36:41 GMT
Well I have started to cut rot from drivers side floor and have started to weld new plates in. Rot cut out. Then welded parts in managed to do one plate and dress up the other I have managed to tack but unable to fully weld yet as I dropped something on my auto darking welding lens so have a new welding mask coming.
Mar 28, 2013 12:41:22 GMT
Hi
Awesome little car.... Huge project mind, I don't think my last 3 205's had that much rust combined....
Dimma 205 wheels make me do a sex wee
Good luck with the project
Alex
Mar 30, 2013 16:45:47 GMT
I have not done too much of late due to no time but I have managed to source a good boot floor and a really good floor at a local scapyard so going over there in week or so to cut out parts.I have been getting my spit sorted out and hoping that will be complete in a couple of weeks then I can really make a start on the floor. I have managed to make a start on the roof panel I have that I'm using as a template to fit vaccum sunroof to my car I have removed the support beams just got to strip roof to skin and use as template. I had a little play with the front wings and they line up quite well but will need some adjustment for a really good fit.
Vern
Lovely motor, good luck with it.
Project Uno Turbo begins!
I have not done as much as i would have likes due to no spare time I have had my heart set on removing a mint floor from a car i found ina scrapyard this has turned in too big a job so now just going to cut out parts i need and carry on patching mine. I have had a play with the headlights i picked up from scapyard to see how they line up as i have carried out major repairs to the front really happy how it looked.
aws
Just smile and wave boys. Just smile and wave.
Love those wide wings.
mr
Apr 22, 2013 11:59:32 GMT
this is the only pug ive ever looked at and thought, oooohhhhhhhhhhhhh,thats nice. superb work going on and i cant wait to see it all finished.
Got the car from 105 bhp at the crank to 152 at the wheels.nitrous going on next.....if it ain't broke,keep bolting on go faster parts until it is........ www.fordgranadaclubuk.freefo.de
Jun 17, 2013 14:50:03 GMT
Jun 17, 2013 15:08:10 GMT
Some great work there!
You are MENTAL though, your repairs to the floors are spot on, you should keep that spare floor for the future!!
bnptrs
Jun 17, 2013 15:19:25 GMT
Been reading this on Pistonheads - as above, replacing the whole floor is mental (but should stop it rusting again for a good few years! . Can't wait to see the finished product.
Last Edit: Jun 17, 2013 15:19:42 GMT by bnptrs
Jun 17, 2013 15:26:31 GMT
+1 to dezshearer there, your repairs to the existing floor are perfectly fine, if you decide to replace the entire floor that is gonna be a massive amount of work and you're also risking bending the body!
Thanks for the comments the new floor is nearly stripped and the repairs to it nearly finished I have thought about if the body will move but I belive that with inner sills and sills and the rear boot floor and bulk head not being removed that movement would be reduced
bnptrs
Jun 18, 2013 10:01:16 GMT
Thanks for the comments the new floor is nearly stripped and the repairs to it nearly finished I have thought about if the body will move but I belive that with inner sills and sills and the rear boot floor and bulk head not being removed that movement would be reduced It would still be worth jigging / bracing the body. With the current floor in place welding cross members between the pillars should stop the body from twisting when the new floor is welded on.
Jun 18, 2013 10:10:40 GMT
Yeah may do that as it would not get in the way of fitting new floor
bnptrs
Jun 18, 2013 10:17:14 GMT
Last Edit: Jun 18, 2013 10:18:14 GMT by bnptrs
Jun 18, 2013 10:32:17 GMT
Big difference with that mini is that it looks to have had the inner and outer sills removed for repair but will still prob run a brace hardest bit I feel will be getting the kick up at bulkhead in position with the chassis rails there.
Jun 28, 2013 11:17:52 GMT
