lae
Film Photography.lae
@frinkmakesyouthink
Mar 12, 2013 22:56:24 GMT
Lucky doesn't use C41 process? I've been C41'ing it for ages, with nice results. Accidental cross-processing, then!
Those composite images are absolutely stunning. I have done one of my own using a digital camera - I'll try to find it.
Last Edit: Mar 12, 2013 22:59:22 GMT by lae
Currently: Mk1 Focus blandmobile
Formerly: 1969 MG Midget 1972 Avenger GT 1981 Datsun Cherry 1989 Corolla 1979 Mercedes W123 200D 1995 Ford Falcon 1996 Ford Telstar (bet you had to google that one)
dugong
One Of Us Will Live To Rue The Day We Met Each Other (Wire : 2008)
Mar 12, 2013 23:04:11 GMT
Lucky doesn't use C41 process? I've been C41'ing it for ages, with nice results. Accidental cross-processing, then! Lucky 100 [B&W] doesn't use C41. Lucky 200 definitely does use C41.
The latter I can get on a 45 minute turnaround, the former I can get done in Rodinol but it still takes a few days from my bloke in Crewe.
lae
@frinkmakesyouthink
Mar 12, 2013 23:09:05 GMT
Yes I see. I bought Lucky because I got a whole batch on the cheap (cheaper than normal, which is already cheap). It's fine for my level of photography. Aforementioned composite image: I will have to do some with film when I get the time.
Last Edit: Mar 12, 2013 23:10:34 GMT by lae
ZXRob
Mar 17, 2013 15:20:21 GMT
I went out again yesterday with the T70 and managed to do another roll of film just practicing landscape shots of Cologne. I pick up the disc tomorrow so hopefully I will have some more photos to display. I really love using the T70 and I seem to put more effort into taking the photographs with it than I do with my Olympus digital, maybe it is because you can't check, delete and try again.
Rob
ZXRob
ZXRob
Hi there fellow film folk. I am after a little bit of advice really. I am wanting to take some shots at night without the flash as I love these kind of shots. My question is what kind of shutter speed would I be needing to use for such a photo? With the T70 there is a function where you can just hold the shutter open for as long as you want. This is the kind of shot I want to achieve (taken with my Olympus digital) PB050031 by Bowling Racecar Driver, on Flickr Thanks for your help.
awoo
Mar 24, 2013 11:30:58 GMT
depends on the lighting situation of where you are. if you have an iphone there is a pretty good light meter app which i use - something like that would help.
but to be honest i would try just leaving it open for 30sec+ and see what happens. it would be hard to overexpose so just try a few and keep not for next time. colour neg film is pretty good for exposure, its rather forgiving
ZXRob
Mar 24, 2013 11:46:37 GMT
Cheers for the help dude, I don't have a smartphone I have an old 7 quid Nokia! But I will try 30sec and work from there. Excuse my ignorance but what is colour neg film? I am totally new to this!
awoo
Mar 24, 2013 12:42:57 GMT
colour negative film is just regular colour film. you get slide (positive) film which is slightly different and more fussy to exposure.
LowStandards
Mar 27, 2013 23:18:21 GMT
Not sure if anyones interested in this but I fancied a bit of proper vintage photography, a quick eBay later netted me this 40's Ensign Ful-Vue. Lovely little thing, waist level view finder, single 1/30 shutter speed, as basic as they come. The problem is its medium format film which is a 6x6 negative, now this film is still available but its not cheap, processing again aint cheap and you get 8-12 shots per film. As it was cheap and would be an orniment anyways, I converted it to 35mm First up I cut a black plastic mask, started with a 6x6 square the cut a 24x36mm rectangle in the middle - I then cut this wider to expose the sprocket holes incase I wanted to scan them. Now you don't need a mask, but without it you'd be exposing the width of the film by 6cm, which would make nice tall portrait shots. You can see its just glued in and I added some foam inside to keep it light tight. Next up, the film. Most cut up and old 6x6 spool and butcher it to wedge inside the 35mm spool, I decided to solid mount one side, the use a sturdy spring on the other. This works great and will aid rewinding the film as it has to be done in a dark bag. And there we go, next step is to measure a frame and mark the frame winder knob so in don't waste film or double expose. I have no idea how well it will work, I see no issue why it wont, but its been fun
Do post up some results, i have that exact camera, got it for a quid at a car boot!
zx9
Kinda New
I had to give up my dark room last year so do less film photography than I used to but still develop my own B&W then scan the negs. As Cologne is featuring heavily, here is one of mine taken on a Leica M2 (the camera was made two months before I was born!) shot on Agfa APX film. Köln Dom and Rail Bridge from the river bank. by ZX9 - Keith H, on Flickr
I might have some enlargers for sale in the near future if anyones after any
the ensign full-view <however they chose to spell it lol> is a good little box camera, The only problem <and it may not even turn out to be a problem..> is that loading it with a much more sensitive film compared to what was available when the camera was new will result in large over exposures. 400iso was, if at all, seldom available back then, 100iso-200iso was the norm.
So I'd expect in good lighting, from 1/30 shutter speed, an over exposed photo, however there is one saving grace that may aid you and that is that that these fixed focus box cameras usually had a fixed aperture of around f11, which is relatively small... so that will control the amount of light coming in... you may just get away with it.
Film is SO much fun and still used in huge quantities, by amateurs, pros, and commercially!
I would recommend that whatever you wish to take a photo of is kept in the centre of the frame, since you've loads a much slimmer film than intended, the sides will not get exposed.
120 film is well worth the money imo, lovely big negs,... and you can get c41 process compatible these days which is well within the scope of even the worst branch of photo developers.
LowStandards
awoo
holy moly! thats a nice score, if youre not using the slide i would make use of them if you want to part with some for beer tokens? this one of yours totally has the film vibe, stuff like this that keeps film going i reckon
LowStandards
I just went to the local Boots store (read that as dragged by the missus, i'm not one for moisturiser) and scored 25 rolls of fujifilm c200 for £2 as the date was march 2013, happy times.
Whats the crack with the slide stuff? Different processing, positive or negative types, i'm confused, can you have it proccessed and printed like normal?
I'll happily give some up if you can use it, obv its all expired
Ive only just stumbled across this thread. thats the canon ae1 with a 70-210, 50mm and a speedlite given to me by my gf's nan. its absolutly mint and still working after a new battery and roll of film, I have just finished my first roll in it, does anyone have any recommendations on places to get it developed and where to buy new film? maybe mail-order/internet? I may hit upthis thread for some advice and info on fim photography as i go along, would be useful. thanks
LowStandards
Large asda stores process to negatives for £2 a roll, then its a quid to have them shoved on a cd, they're scanned at an awful resolution, but it lets you see which ones to scan properly later on.
don't expect any thoughtful processing though, its all the machine so its never going to be the best, still, its how the ones above were done (these are straight off the cd)
Smiler
I no longer own anything FWD! Or with less than 6 cylinders, or 2.5ltrs! :)
Apr 18, 2013 22:06:17 GMT
I was recently loaned my old mans Canon A1 set-up to play with when he learnt that my compact digital thing had died. Learnt a lot just from reading the manual! Problem is the length of time it takes to see the results and forgetting in the mean time all that I had done and try'd. Particularly as the only shop nearby that processed film was a Jessops ten miles away. D'oh!
www.Auto-tat.co.uk'96 Range Rover P38 DSE (daily driver) '71 Reliant Scimitar SE5 GTE 3.0ltr Jag V6 Conversion '79 Reliant Scimitar SE6A 3.0ltr 24valve Omega Conversion '85 Escort Cabrio 2.0 Zetec - Sold '91 BMW 525i - Sold '82 Cortina 2.9i Ghia Cosworth - Sold '72 VW Campervan - Sold '65 LandRover 88" - Sold
