rld14
Wait, just looked at the pics again.. It's a 4cyl (doh!) so its a 2.3. Those engines really like boost ya know... Looks MUCH better with the new paint! You said problems with carb, what's it doing? Some electric fuel pumps can supply too much fuel, did that car originally have a mechanical pump?
88 BMW E28 M5
62 Vauxhall Velox
60 Vauxhall Velox
60 Lincoln Premiere Coupe
60 Lincoln Continental Mark V Convertible
54 Ford Customline Fordor
32 Ford Roadster
its a 3.3 straight 6 mate, it has general problems starting from cold as the choke is not operational but I can live with that, the mechanical fuel pump was on its way out and would periodically stop supplying fuel which was what I thought the problem was, but it has done the same thing several times over the last few days, it will suddenly lose all power start coughing and spluttering and eventually die and like flicking a switch it'll suddenly be fine again, in the past it has taken 20 minutes to run again but now within a minute its ok and drives off fine.
I know it has the useless holley 1v carb so i think replacing it with something else is in order
Its not broken, its resting! Max signature image height: 80px
looks a lot better now in paint. nice one.
New paint looks good, but those wheels completely missed the mark IMO.
as said the wheels aren't finished and suspension needs sorting yet
I'm prolly in the minority here but I like those wheels- just needs the ride height brought down so the tires fill out the 'wells and it'll look great.
Did Ford build it RHD or was it converted later? I'm always intrigued by RHD versions of otherwise familiar American cars.
Great job on the paint by the way.
Brian
rld14
Why am I thinking these were V6s? That or I did post after drinking...
Anyways, I've seen instances where the electric fuel pumps can put out too much pressure, IE, the mechanical one was 4-5PSI, the electric throws out 6-7 and you need a pressure regulator to fix things.
Anyways, that's probably not the case here as it's doing the same thing.
I'm thinking ignition.. that car should use a Duraspark setup, next time it does it and won't start try gently tapping the duraspark box, see if that does it. RockAuto probably has them for $10-20 but the shipping to the UK isn't cheap..
88 BMW E28 M5
62 Vauxhall Velox
60 Vauxhall Velox
32 Ford Roadster
this one was sold new in the uk as ford tried selling them over here for a short while. i did think ignition but we'll see as it usually doesnt die in a convenient place to get out and play with it
May 18, 2013 15:34:45 GMT
did a bit on the springs today ended up with this hopefully I'll get the wheels painted asap oh and it runs lovely now, finally found the vac leak on the inlet manifold and fixed it,
Joe T
May 19, 2013 10:04:48 GMT
You've done good with that. Well done!
May 19, 2013 15:36:41 GMT
thanks mate, still got to paint the wheels and flat and polish the paint, but it is an absolute joy to cruise around in it now, the ride is so much better and way less bouncy and it runs like a dream at last
May 19, 2013 22:09:36 GMT
Looking good dude
1982 mustang 3.3 fox stealthstylz
@stealthstylz
Club Retro Rides Member 174
May 19, 2013 22:41:08 GMT
That looks pretty cool, and I usually hate those wheels but they seem to suit it really well.
Saw you going through bexley the other day it looked nice
mine will go v8 if i can get the bits cheap enough, not fussed about overall speed but i want the noise and the rising tyre bill they come with
finally got round to flatting and polishing it, looks so much better now.
Wow, flatting and polishing has made it look a million times better. Good job.
