Jan 25, 2015 20:09:53 GMT
Thanks Guys and just to confirm the reason for using 3mm plate on that section of chassis leg, and not the regular 1.5mm
David wants to be able to use those points to jack the car up in the future without fear of the legs getting damaged
DMS
Jan 26, 2015 10:58:16 GMT
Any more detailed photo's of where the rollover things are attached to? They look simple and easy to work with.
I believe they are of the sort that mount on to your hub/disc.
Speedle
Jan 30, 2015 10:01:09 GMT
As always I'm simply in awe of your metal skills! I mean those chassis repairs are invisible! A true artist at work in my humble opinion! Love seeing your work!
Any more detailed photo's of where the rollover things are attached to? They look simple and easy to work with. Yes they bolt to the hubs
vulgalour
Club RR Member Number: 146
I don't know what's more exciting, seeing the Celica all bodywork-finished or the prospect of a new project incoming.
bstardchild
Club RR Member Number: 71
So just need to arrange to get that collected and then start on the next project 1980 BMW E12 M535i Black beomes Toyota Celica becomes E12 M535i again?
A testament to fine craftsmanship. If the rest of the work is carried out to this standard, that should end up a very tasty Celica.
Waits patiently for the next project.
bstardchild
Waits patiently for the next project. I don't do patient............
A masterclass. Keep them coming, Did you weld the chassis leg repair panel together from three separate pieces? If so was this because the 3mm sheet was so hard to bend?
Last Edit: Feb 1, 2015 21:29:09 GMT by Beershed
Only the base section was 3mm with a 20mm flange folded on, this was done in a vice with a big hammer, and my arms still hurt
The sides were then welded on in 1.5mm, there was no need for the whole section to be 3mm, the 20mm flange will add lots of stiffness more than suitable for jacking up on
Feb 11, 2015 20:58:28 GMT
It's not connected to anything, I suspect that there should be some sort of clamp or support that goes round the strut, but I got these secondhand so I'm unsure about that bit
Feb 14, 2015 18:31:12 GMT
Well thats the Celica away I think the plan is David will continue the thread on here, but in the meantime I'm back on with Brians E28 M5, Click here
Apr 28, 2015 10:26:42 GMT
Apr 28, 2015 14:27:25 GMT
Looks factory fresh! Glad to know we'll be able to see the build up. Might be worth a separate build thread now, though, if Tony is going to continue on with the BMW. Might get a tad confusing! D:
eurogranada
Apr 30, 2015 13:58:21 GMT
Looks excellent!
Jul 30, 2015 19:01:33 GMT
frosty
It's looking so good. Can't wait to see it in finished paint, although the pink guide coat doesnt look too bad!!
Have you got any engine bay shots?
Cracking car though mate!!
1970 MGB GT 3.9 V8 efi Sebring
2007 Audi A3 Sport (Diesel)
Apr 13, 2017 12:22:34 GMT
did a bit of work on the 28, decided had to go down the power steering road as the steering box is just to much like hard work, went for ae86 member ps rack, 2jz pump but had to get a new forward sump as the one i had was rear facing also needed new engine mounts and a new weld on universal joint thingy from the rack to the column , while the egine was out gave it a clean up
Last Edit: Apr 13, 2017 12:27:30 GMT by elbak77
