May 20, 2013 15:26:17 GMT
May 20, 2013 17:21:12 GMT
agree, was trying to post earlier, i got a retro tape player from ebay...
skoze
aaaaah now that's what's up! the kenwood in it at the moment really suits it (being a tape player with big buttons n' all) looks like ebay will be my friend.
i'd be happy to put something newer in but i'm yet to find something fresh off The Enterprise. It's got some decent 100w speakers put into the doors and some currently disconnected 6x9s in the parcel shelf, despite perhaps not having the power to run it loud enough for all the bwoiezz to hear it outside, if i were to wire all that up to an old head would there be any major issues?
mechanics i know, electrics i do not - this is a strange, scary new world.
skoze
*not fresh off the enterprise.
apparently i cant edit posts on my phone. Is a simple fascia without a laser show really too much to ask from a modern unit? Who knows...
May 21, 2013 12:05:15 GMT
I find decent old radios are more than up to the job and look much more at home in the dash board, plus why panic about amazing quality sounds when you have a bumping 3 litre V6 right in front of you!
Last Edit: May 21, 2013 12:11:55 GMT by trigger
skoze
May 21, 2013 16:49:30 GMT
TRUDAT! It's surprisingly quiet in there when cruising anyway, so it's not gonna need too much in the way of volume to be audible. Now it's time for some more exciting electrical troubleshooting! Old Ford with curse word electrics? Never! So, Sunday night I noticed the o/s side light's main beam was bust, as was the indicator. Much of this has happened today; Poked about, everything seemed fine, swapped a few bulbs around and the main beam was fixed. Exact same issue with the indicator, two new bulbs needed. You would have thought that'd be the end of it, but now the n/s sidelight won't come on, and the tail light's out as well. The indicators work on that side, as do the brake lights, the centre full beams work fine too. I've checked earths, fiddled with fuses, cleaned contacts and still, nothing. Strangely, the non-working radio and similarly non-working 80's-tastic airhorn arrangement are now in fine working order; Took the rear lens off, no blown bulbs or anything in there... But still, no lights. Anyone have any ideas? I'm doing a whole lot of head-scratching because everything is in places which should necessitate it working right. Planned a nice long drive for the weekend, but that's gonna be hampered somewhat if I'm limited to daylight hours
Last Edit: May 21, 2013 16:51:12 GMT by skoze
May 21, 2013 20:32:44 GMT
Could be a bad earth somewhere, try cleaning everything with a screwdriver.
skoze
May 21, 2013 22:56:34 GMT
This has infuriated me, what were good bulbs at the beginning of the day are now f'd. Just checked everything over with two known good bulbs and it turns out both bulbs had gone in the nearside side light which was working fine this morning. Also, I checked the headlight relay this morning and everything seemed fine. Checked it again and it had blown two fuses. I think some wires might have touched amidst my anger as the day went on, but either way I'm gonna keep a close eye on it and see if there's anything untoward contributing the the wiring woes. The tail light problem turned out to be fuse-related too, I think it's the 4th one down being the left-hand side of the car. It decided not to play ball anymore so a cheeky swap around and all was good again. Really is bizarre, I think it just wanted to give me the run around today. Trip to Halfords in the morning and all will be good in the world again! Did enjoy sitting and listening to a mixtape I got at our gig on record store day at long last, got the passenger side speaker wired up right and the 6x9s plugged in - sounds ace in there. Will make our trip down to Bournemouth this weekend very pleasant!
Last Edit: May 21, 2013 23:01:11 GMT by skoze
bortaf
May 22, 2013 12:55:17 GMT
The bullit fuse they use in that era of ford are cr@p, remove each one and clean the conntacts and fit new fuses with some contact grease on the ends, also make sure the fuses are tight (ish) in the sprung holders or you will get intermitant non working stuff Personly i'd also undo every earth wire, clean the ring terminal and around the body hole the screw goes in and re tighten again with some contact grease.
R.I.P photobucket
skoze
May 22, 2013 17:50:18 GMT
Have just stocked up on fuses and bulbs, should keep me going for a little while! Cheers for the advice, seems like it's something i'll inevitably have to learn to live with Today was a success; Hopefully, that\ll be the end of it for a while. I'm still yet to get the heater, rear heated screen, washers, or rear wiper working but they'll come. For now though, i have fully working lights, indicators, hazards, horn, radio and a handbrake that's GR9 4 SKIDZ BREV. All of which are vast improvements over what it was two days a go! Never really had any experience with electrics beyond stuff you can trace easily, so i'm quite happy things are starting to look up. It's not as scary as i thought!
May 22, 2013 20:46:05 GMT
That last picture is just so
skoze
Cheers, dude So last night was fun. Parked the car up just outside of town to meet some friends, then headed up to london with them. When I got back, no dash lights or rear numberplate light (I think these are all on the same circuit) and the red light above the ignition (assuming this is the ignition warning light?). Will it ever end?! Speaking of warning lights, does anyone know what they all are? I'm guessing one's oil pressure, one's a charge light and the one I've got on is an ignition warning, amirite? There doesn't seem to be anything anywhere that just straight up tells you this is this etc, would be nice! EDIT: answered my own question with a bit more research - the light that's staying on is the charge light. Oh dear.
Last Edit: May 23, 2013 10:56:05 GMT by skoze
Get a cheap multimeter from Halfords and check the voltage across the battery, when running it should be between 13 - 14 if the alternators doing its job properly. Sounds like you have some dodgy earth/fuse connections too, get the sandpaper out and clean the contacts on the fuse box and the ends of the fuses as well as all the earths. If you open the boot you'll see three copper squares on the body and three corresponding pins on the boot, sand these too as they are the connections for the rear wiper. Don't you just love electrics? There is a silver relay on the passenger side bulkhead that is for the main beams, unplug that and clean those contacts too! good luck mate, well worth it
skoze
May 28, 2013 10:29:15 GMT
If you open the boot you'll see three copper squares on the body and three corresponding pins on the boot, sand these too as they are the connections for the rear wiper. Don't you just love electrics? Aaaaaah, that could explain why nothing to do with the boot except the number plate light works, had no idea about that! I've cleaned up everything else, crimped a few slightly loose connections and it's been working pretty well since, no more blown fuses and all the lights etc have been doing their job nicely. Only things it doesn't have now is a rear wiper/ heated rear screen/ heater, but I'm guessing the heater itself is seized as per every other Capri in the world... Drove it down to Bournemouth on Sunday with my girlfriend, effectively just to have lunch with her mate and have a nice long drive. 200 mile round trip with a fair bit of 'round town, lots of traffic one-way and a general cruising speed of 77mph, 26mpg all in which wasn't as awful as I thought it would be! I reckon it'd return 30 if I drove it right, it just eggs you on to give it some beans ALL the time which is really annoying... Good day of enjoying power steering; Funky faces; And chillin' on sandy beaches; Thanks, car
Last Edit: May 28, 2013 10:29:50 GMT by skoze
MK2VR6
Mk2 Golf GTi 90 Spec
May 28, 2013 10:42:55 GMT
Great story, and excellent to see young guys like you having fun with a motor like that. It's always irked me that generally in life, it's only possible to afford the sort of car you really want, when you're too old to look cool in it any more! Keep us posted of updates; sounds like X pack is inevitable. I can see your reasoning, although the standard form of the Capri looks so good as it currently stands imho. Get out that waxoil!
skoze
May 28, 2013 12:51:13 GMT
Cheers buddy! I agree, always seemed like i'd go the same way, just got very lucky to have something like this to play with so soon. That journey would've been nothing in something modern!
X-Pack will come eventually, i've got the bodywork together more or less, with the wings and turbo tail all sorted. I've just got to get hold of the suspension so it all looks right and then i'll consider sending it on for the work. Just been on the phone tot he guy who i think will end up doing it who's quoted me just shy of one million dollars so i've got a considerable amount of saving up to do first.
Anyone got any good, cheap spray shops in mind? I can probably just about cover all the rest with a summer's work but that's gonna be the killer for now!
skoze
Jun 27, 2013 20:23:37 GMT
Jun 27, 2013 21:27:22 GMT
Now that is a lovely looking S! They certainly have character!
Jun 27, 2013 21:59:31 GMT
skoze
Jun 29, 2013 12:29:22 GMT
Cheers, chaps! Should be picking up the arches etc next week, then i'll be tackling the suspension and brakes when i get paid. The current head's doing good service for now too, ta! Got one of those tapes with a wire on it to hook up my ipod, it's surprisingly good.
