skoze
Jun 16, 2014 17:28:56 GMT
Haha, cheers dude! If ever it's up for grabs, you can join the queue...
It's not gonna see any fibreglass unless the bodywork catastrophically sh*ts itself, it's not the best up close but these really are a dying breed - would be a shame to chop it.
Besides, not doing that saves my money for other things! With the new tyres and the rear suspension fitted, i'll be done underneath bar some eccentric top mounts and eventually an LSD, then it's time to introduce the Essex to some proper shed-tuning!
skoze
Jun 18, 2014 18:40:30 GMT
NEW TYRES DAY! I've been looking forward to this day for a really, really long time. Headed in to the trusty Uncle Tom's garage to get everything swapped and balanced today, after a little wait and a flick through some 90's Fast Car mags, I had this: I'm now running some 185/60/13 Toyo CF1s. Initial impressions are very good - they're comfortable, fairly quiet and most importantly have a nice amount of grip. After taking those pictures I tried to Bodie and Doyle it away as I used to, only to be answered with a groan. Turns out it takes quite a bit of boot to get them loose in comparison tot heir predecessors. With them being slightly smaller, this became even more of an issue: 40mm clearance on the clamp - not ideal... Luckily, I have the world's most frequently adjusted coilovers to save me. I've added 15mm or so the front end. Still really boody low. but a bit less drastic. After a fiddle, it looks like this: Fit's not bad, i'm reckoning it needs to see some spacers. What do we think RR, 10mm on the rear? 10mm up front, or dare we go 25mm? They'll take going a lot wider, but i'm a little dubious on ruining the steering... And a little comparison: The 185s really do look small compared to the 205s, especially on the back (the old tyres might make their way back on the rear yet) but where on earth do you get good 205/60/13s these days...? I also got these through in the post: Which should hopefully mean I can get the new springs on, provided I can work out the adjustment issue on one shock. The screw turns, feels like it loads up a bit, but no click. The adjuster seem to be the source of all manner of trouble from what i've read, but does anyone have experience of this issue or any idea on how to fix it? If they don't work out it's no biggy, cost me £20 to my door! That's the latest, anyway - i'm happy with how it drives and mostly happy with the look - just weird seeing it looking so skinny compared to the fat, bulging 205s it had this morning.
Last Edit: Jun 18, 2014 18:41:39 GMT by skoze
Jun 18, 2014 20:36:09 GMT
I reckon the wheels, height and tuck are all exactly where they should be right now. Even the shape of the new tyres is nice and looks just right on the car. It's not often a thing looks so right to me, so I'd definitely encourage you to leave it as it is, this is one of the nicest looking Capris I've seen right now.
ToolsnTrack
Homebrew Raconteur
Club RR Member Number: 134
It might just be the image focus, but those fuel lines do not look too clever dude. I'd think about replacing those joints, better safe than sorry!
Ooh, nice one mate. Like the stance of your Capri. I have a same set of rims under my Capri too. Not sure if I can lower my Capri, as I have DIY side-exit exhausts and a bit larger diameter pipes...
Last Edit: Jun 19, 2014 6:29:00 GMT by hessu75
Ford Capri Mk3 -79 2.9EFI turbo, summer ride Ford Sierra 4x4 STW aka "GABy", winter ride Kawasaki ZX14 Project 2.9 EFI engine for the Sierra 4x4.
skoze
It might just be the image focus, but those fuel lines do not look too clever dude. I'd think about replacing those joints, better safe than sorry! I think it's just the picture (and they're covered in ming). I had them all apart when we did the footwells and they're all good despite appearances. With it being a standard carb engine too there's not a lot of pressure there either, I do keep an eye on it though! When it starts getting engine love it'll probably see some nice braided numbers the whole length just for peace of mind, but for now they're alright Cheers Hessu, good wheel choice! What engine's in that for the side exit? And cheers Vulgs, glad it tickles your pickle. The more I look at it the more it's growing on me, I think it's just the before and after difference that i'm not quite used to yet.
My Capris engine is the 12V Cologne 2.9 V6 from a Sierra. Proper EFI injected. Had some issues to get her running and got my major help from Capri power forum. Tranny is the Type9 5spd manual one. Open diff atm with std half shafts. Did my DIY exhaust like this: Cheers from Finland -Hessu-
skoze
So, today I found out all about the weaknesses of the nylon timing gear inside Essex V6s. Fark.
>.< fingers crossed that not too much damage has happened!
See the positive , the engine can be messed with !!!! Plenty of cheap essex's on ebay , you could swap another in while you build up the original engine [ so you have a nice numbers matching car ]
Ian
Bum hats.
I had this with my astra last week.
I feel your pain
skoze
That's my plan bobble! I could fix this up, but it deserves more really being the original engine. I'm on the look out for a used 3.1 or something to tide me over - it's not all bad, just gutting and money I don't really have!
Will have it apart next week or so hopefully, will see what's taken the hit.
dbdb
That's bad luck. Hopefully it can be repaired. I agree - the car is such a nice one it is better to have the original engine in it.
Darn...!!!
Grab a useful 'spare' Essex for the short-term whilst you think of a cunning plan to get more beans out of the original unit... I know that is easier said (written!) than done but that would be the best course of action I reckon!
I am so sorry to see/hear about this but I'm sure all will come good in the end... When I had my 3-litre Capri the manky fibre timing gear went and I replaced it with an alloy one, luckily the engine was ok so yours might still be fine also...
Let us know what happens sir...
***GARAGE CURRENTLY EMPTY***
meltdown
South West
Isn't letting old age get the better of him, still making the same bad decisions with vehicles.
Well that's a bit pants, I hope it all works out for you.
Powered by biscuits
skoze
Cheers guys, appreciate the sympathy!
I spoke to my mate at Burton this morning, the worst-case parts list is utterly eye-watering to say the least. Hopefully i can get it stripped next week to see what the damage is, but i've had a few offers of parts including a full cam and follower set and some new heads with big valves in - will see what I can scrape together cash-wise and see where we end up.
There are a few Essex v6s on eBay around the £200-£300 mark. If it was me, I'd replace it with a runner so you can still use the car and rebuild the original motor with more power! That way you don't have to rush a rebuild and you can do it over a bit of time so it's financially less crippling! Maybe even super charge i?!
skoze
That's what i'm thinking Dave, I'm really not keen on buying something i've not seen running though - (almost all on eBay seem to have been sat for an eternity)
I've been offered some ported and polished big valve heads and some degree of lairy cam for £200, so that's part of it sorted - add in timing gear, followers, new push rods, a bunch of bearings and seals, and if the pistons are alright we could be good to get going with a re-build.
One thing though, i've also found a guy who can supply a 3.1 block and pistons... It'll increase the rebuild cost a fair bit in both parts and time, but what do we reckon on building onto that?
As for supercharging it, some forced induction is on the cards. Part one of that was due to come over the winter with a conversion to ITBs and Injection... Might still happen, but more than likely something for next year now!
Jul 10, 2014 10:38:51 GMT
The best way would be to get one from a someone who deals with reliant scimiters , then you might be able to hear one running . What about reliant reviver on here ?
ToolsnTrack
Homebrew Raconteur
Jul 10, 2014 17:01:37 GMT
OK, I guess it's up to me to be that guy.
Can we discuss the V8 option?
