owen
Jan 28, 2020 15:13:34 GMT
Just picked this thread again, and not had time to read up from where I left off, and it still makes me smile, I have a question about your prop, what pinion angle are you running? I never run more than 4deg down from the gearbox flange, you like you are running a lot more? Photo makes it look really bad, I measured the gearbox end angle and set the same on the axle but I can't remember what it was now
owen
Jan 28, 2020 18:04:36 GMT
Today I got new wiper blades and a piece of plastic mirror as interior mirror is broken. Got the handbrake cable fitted and working, then started on the exhaust. The original exhaust back box was smashed by the propshaft hitting it, I hot given a twin exit box but didn't like it and it was way to big. So I cut it in half and shrank it down. Welded quite well, my mig is still on 1mm wire and turned all the way down it was still a little to much, but I didn't want to buy and swap the reel to do this. This is the complete exhaust, just put a tip on the end to aim it out the side After this I ran supply wire to the fuel pump, put some fuel in and primed the fuel system. Battery is too flat to start it so it's now on charge. Tomorrow I am going to bleed the brakes and hopefully get it running, then I need to look at the heater fan and get coolant in it. Then it's ready to sort out getting it on the road, going to get a few miles under it and then do front brake upgrade, oil and filter change and a timing belt kit.
Last Edit: Jan 28, 2020 18:06:58 GMT by owen
owen
Jan 30, 2020 21:22:11 GMT
Yesterday I bled the brakes only to find the bias valve is leaking, so I got a little upset about that. Also found out the battery was had it, so a quick ebay search £29 with a years warranty. Today the battery turned up so I pressed the under bonnet start button and it struck straight up. www.dropbox.com/s/6dq0qi3ddv1dou2/VID-20200130-WA0001.mp4?dl=0Going to bypass the bias valve tomorrow until a new one arrives at least then i can turn it around under it's own steam and finish the last bit of welding
owen
The ten made it 60 miles before it broke photo sharingThe rivets broke and I don't really know why. Will get another plate and see what happens, I did adjust the clutch too much and it jammed on a few times so that may be the cause. But I'm taking out recovery just Incase
Feb 17, 2020 14:48:00 GMT
Would it be worth welding a couple of straps round the top of the transmission tunnel - maybe a bolt on one under...just in case?
1968 Mini MkII, 1968 VW T1, 1967 VW T1, 1974 VW T1, 1974 VW T1 1303, 1975 Mini 1000 auto, 1979 Chevette, 1981 Cortina, 1978 Mini 1000 1981 Mini City, 1981 Mini van, 1974 Mini Clubman, 1982 Metro City, 1987 Escort, 1989 Lancia Y10, 1989 Cavalier, 1990 Sierra, 1990 Renault 19, 1993 Nova, 1990 Citroen BX, 1994 Ford Scorpio, 1990 Renault Clio, 2004 Citroen C3, 2006 Citroen C2, 2004 Citroen C4, 2013 Citroen DS5. 2017 DS3 130 Plenty of other scrappers!
Feb 17, 2020 14:55:56 GMT
Thats a pain.
Such failures are usually either the clutch damper design simply not being up to the job or misalignment, does it have a pilot bearing?
owen
Feb 20, 2020 10:13:37 GMT
It has a brass insert in the crank so should stay aligned. Going to pull the engine and double check everything
owen
After a lot of head scratching, the only thing I can think of is when the prop came off it the whip has pulled the rivets through the plate. I didn't even think to check the clutch and I think they have slowly worked there way out, which would make sense why I had to keep adjusting the clutch.
New clutch is now fitted and I am just waiting on a water housing coming as mine has a crack in it and started leaking, quite a common fault on this engine from what I have read
owen
Well I have managed to pull the ten out the yard whilst we were in lockdown to give the kids some space and clutch feels great
Nov 25, 2021 15:26:06 GMT
Hello all . I have been the owner off this car for a while now and it is now up for sale if anyone is interested before it goes on eBay . Engine and gearbox is out off the car but everything is ther to put back together
logicaluk
Nov 26, 2021 19:41:03 GMT
Have you put together an ad for the for sale board yet? I'd be interested if it wasn't for the Bond
Last Edit: Nov 26, 2021 19:42:28 GMT by logicaluk
Have you put together an ad for the for sale board yet? I'd be interested if it wasn't for the Bond I’m daft enough to be interested, despite my house and Marlin projects.👍🏻
Hello all . I have been the owner off this car for a while now and it is now up for sale if anyone is interested before it goes on eBay . Engine and gearbox is out off the car but everything is ther to put back together ^See my preceding post.^
I'm messaged you both direct 👍
eternaloptimist
Mar 15, 2022 11:00:17 GMT
It’s on FB Marketplace. Seller is in Sunderland. Nothing to do with me.
sammy2999
Standard 10 106 gti recommission
Jun 26, 2022 20:13:59 GMT
Hi guys I have just bought the car looking forward to the drive to Scotland tomorrow in her
Hi guys I have just bought the car looking forward to the drive to Scotland tomorrow in her Welcome….. And hopefully you are back home to a bacon sandwich by now. Start a thread and tell us more, including the road trip.
sammy2999
Jun 28, 2022 13:27:40 GMT
The drive went well from Sunderland to West lothian we had to pump the brakes a few times in order to stop and adjust the throttle cable and stated to loose clutch about half an hour from home I think the cable is stretched and the clutch needs bled
Last Edit: Jun 28, 2022 13:30:46 GMT by sammy2999
sammy2999
Jun 29, 2022 21:20:51 GMT
Clutch has been adjusted and was driving well until I changed into third and it has thrown itself all around the bell housing by the sound of it so adrian flux breakdown as useless so local guy brought me home last night
Jun 30, 2022 15:29:34 GMT
Adrian Flux were messing me around with breakdown last year as well. Seems a common issue. I've been well put off using their services since and they charged me a lot for my policy as well. Doubt I'll be using them again.
