Following my Morris 1000 build, my next project is a Ronart. It uses a Jaguar XJ 6 as a donor vehicle This provides the rear suspension The engine - Classic XK straight six 3.4 litre. The gearbox will be changed to a manual 5 speed. It also provides the front suspension components.
The chassis is nearly finished - it just needs powdercoating. And I built up the induction system ........ Which is...... Wait for it!.......... Pure automotive porn!!!!
The Doctor
Club RR Member Number: 48
wow, i had to google Ronart, but that is one nice looking car!
Jul 13, 2013 17:52:05 GMT
I remember reading about these in old kit car mags, bit of a beast IIRC!
Keep the pics coming pls! :-)
Koos
Jul 15, 2013 18:22:22 GMT
I remember reading about these in old kit car mags, bit of a beast IIRC! Keep the pics coming pls! :-) Yes the Ronart Company has been around for quite a long time - they now also make a mean Electric car called the "Lightning". Anyway more Pics - the last couple of days has been spent working on the rear hubs and suspension, cleaning off the filth, scraping the rust and then smoothing for paint or polish. The starting point Getting better
Jul 16, 2013 20:28:21 GMT
Nearly there with the refurb of the rear suspension.
Jul 18, 2013 22:04:47 GMT
Picked up the shortened propshaft today so prepped it, primered it, sprayed it and put it with the rest of the bits. However there were two bits of timing chain vibration damper floating in the front timing chain cover so the engine will now need to be stripped and checked.
Last Edit: Jul 18, 2013 22:05:59 GMT by flyingphil
omega
Jul 18, 2013 22:08:21 GMT
very nice bookmarked
Jul 19, 2013 14:32:08 GMT
Stuffs looking shiny! :-)
When will you start bolting it to the chassis?
Koos
Jul 19, 2013 17:00:03 GMT
Thanks Omega and mdh. The chassis is at the powdercoating company now so I expect to collect it, together with the body panels and all the other parts, from Ronart in the next ten days.
Jul 20, 2013 14:45:38 GMT
Any chance it'll be ready for RRG 2014? I'd love to see it monster the hill.
Koos
dbdb
Jul 20, 2013 15:24:03 GMT
Superb project, this.
Picked up the chassis and body panels together with a big box of "bits" Put the panels on as a trial to see what it will look like..... And yes I now have the luxury of a two post lift!
Aug 12, 2013 17:47:24 GMT
I am still waiting for some parts but I was able to loosely put the diff in place to check for fit and then I put the drive shafts and wishbones in as well. (There is a strut taking the place of the coil-over shocks.)
Last Edit: Aug 12, 2013 17:48:00 GMT by flyingphil
Just been working on the steering column and cleaning parts for the front suspension, nothing too exciting....
Aug 15, 2013 13:32:12 GMT
looks good with the panels on! :-)
Koos
Aug 20, 2013 20:03:43 GMT
Thanks MDH A bit more progress with the brake pipes loosely fitted, steering column assembled and mudguard struts in position - all done loosely as I need to collect quite a few more parts.
Last Edit: Aug 20, 2013 20:06:35 GMT by flyingphil
Aug 28, 2013 16:38:48 GMT
More bits done - the wing supports are in place with small bits cut out of the bodywork. The wings themselves will need bolts fibre glassing in place to fix them to the struts. Another job was to put the hinges on the boot lid and I also got the handbrake in position
More brackets attached for the bonnet and I trial fitted the nice alloy radiator.
Sept 17, 2013 16:09:19 GMT
More parts collected but only nuts and bolts. Still I can now put more bits on with the correct fasteners - like the diff plate. I have done some work on locating and labelling the electrical loom.
