1974 Mercedes Benz 230.4 W115Dez
@dez
Club Retro Rides Member 34
Aug 22, 2013 18:23:43 GMT
mine had something like 4 coils off each end rear bumper is held on as BB says, 4x captive studs in end of chassis rails that stick through the valance and have a nut on em. oh and the headlights use 7" units. ive still got the ones off mine which are converted to angel eye H4 units.
Aug 22, 2013 18:39:58 GMT
As Dez just said, this is how much mine were cut too.... That gets you here... Cheers, Joe
Aug 23, 2013 10:35:44 GMT
nice Merc guy, brings back memories of the 220d my cousin had in that shape.......cloud of soot followed us wherever we went..luckily in those days there was no such things as emmission testing Haha thanks! Yeah wanted a Diesel but the ones I looked at was to far gone rust wise...
1979 Toyota KP37 - (Under the Knife) 1964 VW Type 3 Notchback (For Sale) 1991 VW MK2 Jetta CLi (Current Daily) 1994 Nissan SilEighty (Heart Transplant)
Aug 23, 2013 10:44:34 GMT
The nose does look a bit high! I'm not used to looking at a standard height one but my guess would be that the front is high rather than the rear sitting low. Maybe someone put 280 or diesel springs in it at some point? There are different thickness spring pads available that sit in the top spring mount. It could be that those have been changed for thicker ones perhaps? I'd check that nothing else is making it sit high first, but if it does turn out to be the front springs, I'd cut one coil off the bottom and try that. Be aware that regular spring compressors won't do the job on these cars - you either need a proper Mercedes spring compressor that works from inside the spring, or unbolt the inner bolts on the lower arm and remove the spring that way, with a jack stopping the spring firing off and killing you (dangerous... I've done it this way but it's not ideal) Oh last question for the night... Does the W123 powersteering and steering box work on the W115? As mine doesn't have powersteering and I can get a complete W123 setup for around R850 (80 pounds) Not sure about that to be honest! Your car seems to have the later (wider) grille and slatted tail lights, but the early steering wheel and front bumper. Maybe the South African cars had different spec or something! Yeah was wondering about the whole nose in the air thing... I've got a set of springs from a 280 that has one coil cut on both the front and rear. So I will replace them with the stock(donno) front ones to see if it makes a difference. I'll also have a look at the spring pads maybe I can swap them out for thinner ones? Side note: I have a complete 280 W115 that was moddyfied for a roadster so basically have all the suspension drive train motor etc etc. left. so will swap parts to see what makes it look better Yeah I've see you need a special tool to remove the springs, my problem is the tool will cost more than what the car cost me so will need to do it the unsafe route. I'll just use some nice thick cable and tie it around the spring and the car so that if it does want to pop out it'll at least get cuaght on the cable. I'll be getting the power setup at the end of the month so will see if it fits. I changed the steering wheel to the ealier model one, I had the big ugly one on but the bumper is stock. Must say would love the flat tail lights. The slotted ones just doesnt do the car justice. thanks for all the info
Aug 23, 2013 10:47:38 GMT
mine had something like 4 coils off each end rear bumper is held on as BB says, 4x captive studs in end of chassis rails that stick through the valance and have a nut on em. oh and the headlights use 7" units. ive still got the ones off mine which are converted to angel eye H4 units. oooohhh love the stance... but with our manhole sized potholes it'll be a bit difficult to go that low... Think I'll see what the one coil drop will do to the front. and then maybe rip out another coil aha. Thanks. Gonna try and get it sorted over the weekend. Otherwise I'll just macguyver something together to hold the bumper in place ah and thanks now I can go measure if the vw golf lights will fit. Otherwise I need to send my set in to get chromed again... :?
Aug 23, 2013 10:52:59 GMT
As Dez just said, this is how much mine were cut too.... That gets you here... Cheers, Joe Awesome! thats like half the coils gone 0_o hahaha love it!! thanks for the pics and inspiration cant wait for the weekend!
Aug 23, 2013 14:48:26 GMT
Ok so benz licence paid up Not a nice feeling... Anyhow... Now I can drive her legally Laters Riekert
Last Edit: Aug 23, 2013 14:51:47 GMT by reap3rza
Aug 24, 2013 20:36:46 GMT
I have the same situation in Natal with potholes,police can identify drunken drivers because they drive straight whilst the sober public weave all over the road. Measured the pothole outside of work just for giggles 50 cm 20inches wide by 10cm 4inch deep killed many a tyre rim and even suspension
No my car is not modified its just had an update!!!!!!!
I have the same situation in Natal with potholes,police can identify drunken drivers because they drive straight whilst the sober public weave all over the road. Measured the pothole outside of work just for giggles 50 cm 20inches wide by 10cm 4inch deep killed many a tyre rim and even suspension Hahaha sounds about right! Ok so gave the old girl a couple of new bits for the engine. New plugs,leads,points and distributor cap. Now she's purring like a kitten. Need to do a oilchange still but no more monies left after the license has been paid up. Also my one fuse I think no 8 keeps on blowing... need to find out why. Still need to try and fit the rear bumper too. Oh and seems my alternator isn't charging my battery....
Last Edit: Aug 25, 2013 20:11:03 GMT by reap3rza
Aug 31, 2013 16:03:18 GMT
Bump...!
1986 Mercedes 200 (W124) (Standard and daily) 1976 Peugeot 404 1800 Stickshift (Standard - awaiting complete resto, engine done) 1984 Ford Cortina (P100) LDV - Cab and chassis restored, interior and glass not fitted, brand new 3 liter engine (last 110kw Sierra XR6 engine fitted and married to 5 speed Toyota Gearbox), load body needed.
djefk
dubbelduwwel, has your post got deleted or have you found this thread and been rendered speechless? it is a cool Benz, do you still have it reap3rza?
@dubbleduwwel djefkNo unfortunately due to financial and space restraints, I had to sell
