Nov 15, 2013 20:48:45 GMT
Just picked this up today after a nightmare getting it insured, initial plans are a good compounding and polish, LPG install with 200l plus capacity, followed by ply lining and removing the side windows to return it to van spec, then paint. Running a sweet sounding 2.0 pinto which is surprisingly torquey in such a big vehicle. Steering is nice and light too even when parking - i wasn't expecting that! Once its prettied up it'll be going out to work full time and being signed up in as period a artwork as I can manage. Photos are poo as it went dark before I took them....
Nov 15, 2013 21:52:21 GMT
Cool. Nice useable machines them. Serious potential there.
Nov 15, 2013 22:02:13 GMT
Its eventually going to be my main vehicle and it's got to work for it's living so can't do too much with it, if I can find a set of inexpensive euroliners for the wheels they'll be going on - along with some zoomies just because I can A big alloy aussie style roo bar wouldn't go amiss either...It'd look 'ard as nails then.
Nov 16, 2013 18:00:19 GMT
fordtransit.org get signed up there most of the boys have the knowledge with mk2`s so should be able to buy some spares etc, there is a few reversion threads as well were campers have been returned to vans, mk1 and mk2 transit forum as well lassie fred runs it and has a world of knowledge and vehicles lol last count she had 30 odd mk1 and mk2`s lol get parts on there plus specific mk2 threads.
Nov 16, 2013 18:50:52 GMT
Thanks am on Fred's forum (this was actually advertised on there)
Nov 16, 2013 20:51:37 GMT
Love it, wow brings the memories flooding back. I used to be a mechanic at the NCB , we had literally hundreds of these & I mean hundreds. Greatest van EVER
Nov 16, 2013 20:51:54 GMT
Nov 24, 2013 17:25:12 GMT
Started polishing up the rather faded paint, stopped when it rained, well worth it though Have started ply lining too but no photos of that yet.
Nov 24, 2013 18:21:36 GMT
Book marked can't wait to see more progress of this !!
Loads of photo's please?
Last Edit: Nov 24, 2013 18:22:17 GMT by usedabused
Colin
Nov 24, 2013 20:11:30 GMT
love this
LambDrover
Fuelling up the Firebird...
Nov 25, 2013 18:10:04 GMT
This looks really good, gotta love an old Transit!
Nov 26, 2013 19:09:36 GMT
Thats some difference!
kilroy
Suit you sir...
Maybe some signage..?
Mar 26, 2014 19:49:51 GMT
Quick update as the trip to New Zealand over December delayed things a bit, The van is now my main transport and working everyday, polishing is finally finished and it looks a lot better, MOT'd again fine in January, wooden bulkhead, ply lining and shelving now fitted in the back and all the bits are here now for the LPG install. Priority this week is to get the windscreen sealed properly as its leaking and I don't want the top of the dash rotting out. Although its got plenty of go when its only carrying tools its noticably lacking in get up and go when loaded up with materials so i'm looking at getting more go from the pinto for the time being, I've sourced another 205 block pinto with an EFI head so that will be going onto my bottom end (want to keep my low compression pistons) along with a 4 branch manifold and eventually a custom pipe going to zoomies on the drivers side basically just because I can. Worked out it was averaging 16mpg running about which hurt a bit so i've fitted a K&N copy cone filter which seems to have improved matters, not sure why as the emisions were ok on the test. Signage will be happening once its prettied up and I decide what to do about the windows.
After that and assuming I can make it work with the BLOS lpg carb its going to be turbo'd - I may go gas only at that point i'm not sure it depends on what I can find to control it all, if that doesn't yeild decent amounts of torque then longterm I'm on the scrounge for an overdrive box and a buggered v6 duratec to see what I can make fit to it, alternative power plans involve an Aussie Ford 4.1 straight 6 assuming I could find one over here.
Oh and it get masses of attention, although people seem to assume its much older than it actually is, I also got waved down to see if i wanted to sell it the other day!
Last Edit: Mar 26, 2014 19:59:40 GMT by dodgerover
Mar 26, 2014 20:09:35 GMT
Wow, I am insanely jealous! I would love an old transit like this.
Does it have the twin opening side doors?
Mar 26, 2014 21:17:24 GMT
Wow, I am insanely jealous! I would love an old transit like this. Does it have the twin opening side doors? Thanks, nope just a single side opener (luckily for me as i only need the one), they were available as an option though - they're hinged not on runners like the modern vans
steveg
Mar 26, 2014 21:41:54 GMT
I've still got my 4x4 but it's really suffering from rust now. I used to go on the Transit forum but having not used it for so long lost interest a bit. One day I will get it going again. Yours looks pretty tidy.
hamps
www.medwayrscentre.co.uk
Mar 26, 2014 22:50:20 GMT
Awesome bookmarked
That is awesomely awesome...!!! You just cannot beat an old Transit wagon...
***GARAGE CURRENTLY EMPTY***
Got a little bit of time so managed to get some work done First 2 of 3 LPG tanks fitted, need some more straps for the big one the new ones I bought were too short, ordered them today, still need to set the correct angles of dangle for the multivalves, I'm hoping to fit another where the standard spare wheel goes, should be over 200 litres with luck so i'll have a decent range. Additional gauges fitted, hopefully I should be able to get the fuel gauge to show the LPG level, all still to be wired up. Additional temperature gauge is a temporary measure as the standard one doesn't work for any apparent reason. Trying to work out if I cut the dash insert to fit a modern DIN stereo cage or not
