Thanks for the link re-posting Xenoside, thanks ChasR Quite a lot of little jobs done now. The sidelights had to come off so that the wings could go to the sprayshop. However all the wires had been soldered so that held things up. As the rear wheels were off I took the opportunity to treat (clean and condition) the leather gaitors covering the leaf springs. One of the grease nipples was loose so I had to untie the string underneath, refasten the grease nipple and rewrap the spring then relace the string........The welding wire loop acts as a suitable needle to pull the string through! I think that, with the spring leaves covered in grease, it makes them flex easily ( no "Stiction" compared to dry leaves?) to give a very good ride and the friction shock absorbers can work to their best effect.
neat solution actually, and yeah i agree its to make the ride more supple
Hi Darren Well I did quite enjoy my session with tight leather and lacing..... Anyway ..... I also had the chassis reinforcement plates cut and bent at a local fabricators, so I drilled the bolt hole and put a coat of paint on them - I'm doing both sides even though only one side had cracked. They are just placed on the chassis rail for the paint to dry.
More done today as I put on the new axle straps, then ground out the chassis crack and welded it. Inside the top edge I fitted the reinforcement plate and got two good long welds either side of the engine mount. I took off the lower engine mount on the other side and discovered the beginings of a crack on that side, so the reinforcement plate on that side was certainly needed! The chassis can now go into the paint shop for prepping and paint.
Feb 10, 2014 19:36:06 GMT
Back in action after a short holiday (Iceland is very nice!). One little job was to remake the seat adjustment blocks as the originals were a bit tatty. A block of wood with 6 large holes, cut in two and covered in leather, then the top plates screwed in position ready to go onto the floor. Taken to Moss - and the bodyshell is half trimmed.
Feb 10, 2014 20:02:12 GMT
Beautiful. So much 'handmade' in one of these cars (even when they were new i guess).
Great that you and your team have the skills and the contacts to put it all right.
Thanks BMW Nice things sometimes come in brown paper parcels!
Feb 15, 2014 15:20:06 GMT
With advice from Moss a bit more has been done on the chassis reinforcement. The weld has been run right up to the engine mounting block and the ground back to flush. two holes have been drilled through the chassis rail each end of the plate and big plug welds put in place and smoothed. Now getting ready for paint. Apparently the factory Le Mans racers also suffered from chassis cracks under the engine mounts - so they put a long piece of angle iron inside the chassis - hot riveted it and gas welded along its length - however they also needed to alter the lower mounting block. I wonder why they didn't "Box" the chassis rails?
Last Edit: Feb 15, 2014 15:26:10 GMT by flyingphil
Feb 15, 2014 17:02:42 GMT
I wonder why they didn't "Box" the chassis rails? W.O wouldn't have allowed such scandalous radical thinking! hehehe
Feb 17, 2014 17:02:46 GMT
I wonder why they didn't "Box" the chassis rails? W.O wouldn't have allowed such scandalous radical thinking! hehehe Well the chassis is now in primer so there should be a pretty picture soon.
Not sure if the pictures will reappear because there is a technical problem on the website (Rodnsods) that I use for hosting. Anyway the chassis has been mostly painted and the bodyshell is nearly ready for collection - Progress!
Frankenhealey
Club RR Member Number: 15
Classic Bentley RefurbFrankenhealey
@frankenhealey
Club Retro Rides Member 15
Feb 21, 2014 10:11:22 GMT
No pictures
Feb 21, 2014 16:50:09 GMT
Pictures back up again...... I can see on my computer.... anybody else?
Frankenhealey
@frankenhealey
Feb 21, 2014 17:18:24 GMT
nope
Feb 21, 2014 21:41:53 GMT
No here as well. Been a couple of days now.
Mark
Problem with the pictures is that they're hosted on rodsandsods and probably can only be viewed on that site/if you're a member of that site.
Last Edit: Feb 23, 2014 0:33:26 GMT by Mark
Feb 23, 2014 22:41:53 GMT
[img src="http://i.imgur.com/eBWQhDO.jpg" src=" " alt=" "]Has this image appeared? Well I'm trying Imgur as a host but I cannot get the transfer to here correct ----grrrrr
Last Edit: Feb 23, 2014 22:46:12 GMT by flyingphil
IDY
Feb 24, 2014 10:24:58 GMT
Has this image appeared? Well I'm trying Imgur as a host but I cannot get the transfer to here correct ----grrrrr You have some extra code in your image code stopping it working, when I deleted the extra bits your image works fine With the [ ] removed it needs to look like this img alt=" " src="http://i.imgur.com/eBWQhDO.jpg" alt=" "
I will get round to finishing it at some point
Feb 24, 2014 17:47:44 GMT
Thanks IDY.....needless to say I'm more of a spanner twirler rather than a Bits and Bytes ace! Hoping that others can now see the last picture - and don't worry about the smoke effect - the trimmer was puffing on an E Cig! The bodyshell is now back next to the chassis and once the last bit of painting is done re=assembly will start.
Feb 24, 2014 20:04:08 GMT
Glad the pics are back in action, makes more sense now! Trim looks fantastic, especially the contoured 'B' on the door panels
