Feb 23, 2017 20:15:11 GMT
I just looked them up, they look just like PEC.
Personally I would advise using someone like Robson, carillo etc, they'll cost a little bit more, but leagues apart in design and quality control.
Feb 23, 2017 20:23:56 GMT
There has been a lot of research in all the rods that are availale. Some are terrible, prob worse than stock which is pointless. The spool ones have come up trumps with xray testings and decent weigh matching. Some like the cheap ones ate so far out and roughly finished. I'm no skinlfint so will be doing my research fully before going ahead with anything as its a big outlay, but done the right way.
Feb 23, 2017 20:26:04 GMT
I hope you have SWMOB's Birthday and Christmas presents ready as you may be a bit short for the rest of the year at this rate.
Feb 23, 2017 20:30:22 GMT
Haha, shes well looked after thats for sure.
Feb 23, 2017 20:33:13 GMT
Good I would hate see you have your toy's taken off you LOL
Feb 23, 2017 20:55:04 GMT
Very nice project, The Manta A's are one of my favorites. I looked at couple before I bought my Monza but for the money I had to spend couldn't get a good A. Keep up the great work. Mine too! Came very close buying one when I was 16 back in the medieval times, the seller sold it 15mins before I got there to inspect the car. Have you posted any info about your Monza?
Feb 24, 2017 10:25:45 GMT
I went for Wiseco custom made pistons a bit more expensive than the Ross but you get what you pay for. I did hear a lot about tolerance issues with the Ross and that they were a bit too low compression to drive with no boost. If you are interested in Wiseco they should still have my design and they were either 9 or 9.5 CR. Rods wise i went for the Eagle H beam real Eagle not the knock off ones. I also went for the upgraded ARP 2000 bolts. It all came to about $1800 including shipping to the uk. I did see a company selling over here at a good price h-tune.co.uk/eagle-h-beam-rods-full-set/. £664.99 for the set
Last Edit: Feb 24, 2017 10:38:17 GMT by Bullstarz
“It Doesn’t Feel Pity, Or Remorse, Or Fear, And It Absolutely Will Not Stop, Ever, Until You Are Dead!”
Feb 24, 2017 10:37:38 GMT
yes, I have read up on the Ross being a bit tough when cold but once warmed up no probs. As I'm supercharged I'll be boosted constantly, so I figured ahouldnet be a prob be a problem.
Thanks for the link, I've been told eagle are another one not to go for!? Sometimes too may opinions, hard facts are ones I go by.
Feb 24, 2017 10:46:30 GMT
I was told that about the Eagle rods and they will bend and all mostly bad stories. However, they all were building V8 dragster engines knocking out over 2500bhp. when i mentioned that i was only going to use about 1.5-2 bar boost they said they will be fine, and very good valve they happily sold me them. One thing they said with the ARP 2000 bolts they will "only" be good for 200 bhp each. So providing you not going over 1500 bhp they should be fine.
Other wise the rods aren't that cheap.
Last Edit: Feb 24, 2017 10:47:57 GMT by Bullstarz
Feb 24, 2017 11:18:24 GMT
1200 hp haha. I wouldn't dare, that's well beyond the drivetrain limits. 800 is more than enough!!
Feb 24, 2017 12:56:24 GMT
Very nice project, The Manta A's are one of my favorites. I looked at couple before I bought my Monza but for the money I had to spend couldn't get a good A. Keep up the great work. Mine too! Came very close buying one when I was 16 back in the medieval times, the seller sold it 15mins before I got there to inspect the car. Have you posted any info about your Monza? Yeah, retrorides.proboards.com/post/1886878/threadnot updated for some time as I've done very little to it other than drive it and normal servicing.
Feb 24, 2017 13:48:57 GMT
mk2cossie
Club RR Member Number: 77
Feb 24, 2017 14:02:03 GMT
I can vouch for the Farndon rods, as that is what are in my BOA v6 They were purchased many many years ago and I think were something like 175quid a go. And they also drilled the side of the rods for the under piston squirters as per the original Cologne rods too
Feb 24, 2017 14:07:59 GMT
I have them in my own engine too, got a drawing for my personal rod spec was told to use them by a race engine builder, not a seller of rods, the guy that took the picture I posted as it happens.
Mar 10, 2017 17:31:28 GMT
Block back from honing, few more washes to carry out to be sure. Waiting on parts now. Still haven't recieved arp head studs and conrods.
heathrobinson
Broken everything
Club RR Member Number: 111
Mar 10, 2017 19:31:09 GMT
That's a thing of beauty right there
Mar 11, 2017 12:53:47 GMT
Are you using two of ARP 203-5407 shop.arrowprecision.com/toyota-1-8l-2zzge-dohc-4-cyl-main-stud-kit.htmlArrow is a great supplier but they should only cost you about £83 a set. You might have to machine one of the heads to get the cam nut clearance. Have you got a new water pump to put on. I got a full MLS heads gasket kit an pump from the States as it was cheaper, a lot cheaper. If you interested I'm trying to get a trade account from ASNu for injectors.
Last Edit: Mar 11, 2017 13:02:41 GMT by Bullstarz
froggy
Mar 11, 2017 13:34:29 GMT
I'm back on the Dyno Tuesday with the bigger injectors to try it at 12 psi with the water meth activated this time . Should be around 125hp per litre which I don't think is a big ask but I've got a spare block now if it goes tits up . I've used pec rods in a few Saab engines and apart from needing a good de burr and check over haven't had any problems running 200+ hp per litre up to 7000 rpm with them
Mar 11, 2017 14:17:46 GMT
My studs have been bought and paid for just waiting on them now. Ben Newell is supplying. Have a new gates pump with timing kit, bought from states a while back
Mar 11, 2017 15:25:00 GMT
Good luck with that ive had some ARP head studs on order with him for 7 months every 5 emails I send him I mite get one reply he may know his stuff but he has no business sense or customer service
1992 240 Volvo T8 1955 Cadillac 1994 BMW E34 M5 (now sold ) 1999 BMW E36 sport touring x2 1967 Hillman imp Californian "rally spec" 1971 VW bay window (work in progress) 1999 Mazda 323F 1987 Jaguar XJ12 All current
