psycho83
East of England
Rhythm and Booze
Need to have a car day soon dude. Not seen you in ages Yes mate, that would be good! definately want to be on road for the nats this year. Got some lowering blocks to fit on the rear , springs to chop on the front, and on last start up it seems the carb is not shutting off so is curse word out of the overflow. other than those minor things, and barring any disaster I should be well on track.
Davenger
It's only metal
Club RR Member Number: 140
1961 Rover P4 100 - Davenger
@dminifreak
Club Retro Rides Member 140
Jun 21, 2016 22:37:14 GMT
Barbecue and bump stops
is it the same engine as the landrover?
If so I have a fairly new Weber single choke carb from my old land rover in the loft you can have , probably needs a clean out (progression holes can block up) but it ran Ok when removed.
psycho83
East of England
Rhythm and Booze
Jun 23, 2016 14:24:20 GMT
is it the same engine as the landrover? If so I have a fairly new Weber single choke carb from my old land rover in the loft you can have , probably needs a clean out (progression holes can block up) but it ran Ok when removed. I 'think' I have the issue sorted , but that is a very kind offer kevins. It is the same 2.6 straight 6 as landy. How much do you want for it out of interest? as it would potentially make a nice upgrade.
Jun 23, 2016 20:55:50 GMT
I don't want anything, I need to thin out my collection of "usefull one day stuff" but it came off a 2.25 so might be a bit undersized.
While I am at it anyone want a radio / cd player for free? I have a couple of these which are no longer needed as we replaced them with blue tooth ones (they are cheap single din ones but worked fine).
psycho83
East of England
Rhythm and Booze
Jun 24, 2016 13:11:23 GMT
ah yeah, undersized for my needs. But thanks very much for the offer! I don't want anything, I need to thin out my collection of "usefull one day stuff" but it came off a 2.25 so might be a bit undersized. While I am at it anyone want a radio / cd player for free? I have a couple of these which are no longer needed as we replaced them with blue tooth ones (they are cheap single din ones but worked fine).
Davenger
It's only metal
@dminifreak
Jun 25, 2016 14:36:10 GMT
Can't be too difficult to re jet it though
colnerov
Jun 25, 2016 15:24:10 GMT
Hi, I don't want to rain on your parade but the inlet manifold is part of the head casting. If you're having reliability problems with the existing carb try putting a HIF6 or HIF7 on, they're a lot more reliable.
Colin
The later 'Weslake' head from the 3 litre has a seperate inlet manifold, and is a straight swop onto the 2.6, there was also a twin carb head available for them (I think for one of the higher powered variants) which is again a straight swop.
Both types are in the genuinely rather than ebay rare categories though.
colnerov
Jun 26, 2016 16:09:07 GMT
Hi, They're quite an efficient engine for their type and don't really respond to better fueling. Although the 105R, 105S and 110 were fitted with twin carbs and had increases of power over previous model most of it was from increased compression ratio's as better fuel became available. Plus of course the Weslake head flowed better. They did test a 3 litre P5 engine with three carbs it did make for a very smooth engine, they could stand a coin on edge on the running engine, but it didn't produce enough increase of power to be worth the cost.
Colin
Last Edit: Jun 26, 2016 16:10:45 GMT by colnerov
psycho83
East of England
Rhythm and Booze
Ignoring the flat tyre, the arch gap on these p4's stock is huge, so as we all know, it had to be hit with the stick. So it was out with the suspension, which aside from two bolts all came apart remarkably easily Then came the chop - in hindsight perhaps a touch too much, but hey ho , it still rolls and turns Then back together and back on the ground to see how low I'd gone - answer LOW! Looks meaner from the front now, and has a fairly impressive rake, I think the back will need to come down too, I've not seen it out of the garage yet to see how far though. Elsewhere on the car I've started to smooth the bootlid after a bit of help form Dez to knock in the high spots starting to get somewhere with it now I think. cheers for looking.
Last Edit: Aug 22, 2016 7:37:10 GMT by psycho83
logicaluk
Nice work i like the smoothing, what are you planing on doing with the bumper slot
psycho83
East of England
Rhythm and Booze
Cheers, I'm planning to fill all that in and smooth it off too. Nice work i like the smoothing, what are you planing on doing with the bumper slot
1961 Rover P4 100 - Mercdan68
@forddan68
Club Retro Rides Member 68
Aug 22, 2016 17:40:50 GMT
I love these old things in standard form....but that's top work liking it!!
logicaluk
Cheers, I'm planning to fill all that in and smooth it off too. Nice work i like the smoothing, what are you planing on doing with the bumper slot Sweeeet
psycho83
East of England
Rhythm and Booze
Aug 28, 2016 19:58:51 GMT
It's out, looks pretty good I think. Got ready for a show on Sunday morning . . . Then the servo failed so no brakes and no show for the car. Arsehats!
psycho83
East of England
Rhythm and Booze
Aug 28, 2016 20:08:26 GMT
Aug 28, 2016 20:36:12 GMT
bumhats about servo, but it looks the dogs, does it drive ok in the weeds?
logicaluk
Aug 28, 2016 22:36:08 GMT
Begging for a 300tdi conversion
Davenger
It's only metal
@dminifreak
Aug 29, 2016 13:23:28 GMT
Back needs to be lower dude
