coupi
Gutter mounting, from a Pajero, could/should fit other 4x4s with gutters too. Made from ally, so light, but strong. Basket measures 75 1/2" x 46" x 8". Overall height including brackets and gutter mounts 14". £100
Last Edit: Apr 9, 2014 17:53:25 GMT by coupi
Just to add some further information for you, this is a JAOS roof crate. Very, very expensive new (this size is about £750 in Japan) and pretty sought after because they are so well built and light.
You might want to give the overall width measurement between the feet (distance from side to side where it would mount in the gutter) and also distance from bottom of feet to underside of crate (roof clearance) because if this fits low roof L300 Delica, most owners will bite your hand off for one of the at £100.
Little but of useless info: JAOS stands for JApanese Off-road System. These and Aiba Works roof crates are about the best you can get.
Good luck with the sale.
coupi
Thanks for that mate! I could never work out if it was Jaos or Aiba, or what, as they all seemed to have stamps/etching stating so. I'll get those measurements tomorrow, thanks for letting me know. And if you know anyone that might want it, point them in my direction!
coupi
Apr 10, 2014 12:53:35 GMT
Width between the gutter mounts is 1285mm (this is measured from the part that sits in the gutter itself).
Length between front end and rear end of gutter mounts is 1620mm (this is also measured from the part that sits in the gutter itself).
Bottom of the feet to underside of the basket is 6".
coupi
Apr 16, 2014 22:22:57 GMT
SOLD
