Just bought an Accuspark SP8000 timing strobe. The type you can dial the advance into. The instructions are useless - so just wanted to ask if anyone on here has used one, or similar. I am right that when you dial in the advance then the timing mark on the crankshaft pulley ought to show at its TDC position on the pointer?
I knew I ought to have stuck to my steam powered old one.
