Here's the Volvo 240 I share with a my mate Simon, bought from these very pages a couple of years ago we've just got too many cars and something has to go. Details here mostly lifted from his PH advert but I can answer your questions too. It's still in frequent use so the milage of 174,000 is like to rise a bit.
11 months MoT.
Tax until end of August
Part service history (the most recent 70-odd k)
Grey metallic
Leather Seats (Chesterfield style with buttons)
Electric front and rear windows
Heated Front Seats
Electric mirrors
Sunroof (or moonroof as I think Volvo used to call them)
Central Locking
Full service history below, but in the last 5k miles, it’s had:
New Discs and pads all round
Coolant change
Clutch fluid change
Clutch master cylinder rebuilt
Clutch Slave cylinder rebuilt
Clutch
Brake fluid change
Tyres (Michelin Energy front 4-5mm, Conti Eco Contact rear 6mm)
New front dampers (Volvo)
New inner and outer track rods
New wiper motor
We bought the car in 2012. It had been owned by a retired gent in 2007, who’d bought it as a classic project, but had hardly used it except going to the MoT station, though he’d been slowly titivating it and improving it. We put the car back on the road shortly after buying it and have continued to improve it to where it is today.
The car drives very well, the engine pulls strongly (Volvo advertised it in the day as being tuned for mid range power, which sounds like marketing curse word, but when you drive it, you can see what they mean – it clips along at a reasonable pace without ever getting flustered or needing to be thrashed). Nice gearshift and powerful brakes (standard 4-pot fronts and 2-pot rears) with loads of feel. The ride is comfy and controlled with the new (Volvo) dampers and it handles surprisingly well – very much not boat like as you might expect– it’s actually quite direct steering. Overall the car is very solid and clean with surprisingly little corrosion. Everything works with the exception of the radio, which occasionally buzzed into life as you turn it on, but mostly stayed silent (luckily it’s a nice quiet car and doesn’t need the radio to drown out the engine/road noise). Last night, however it worked for my whole journey home, playing my Dire Straits Money for Nothing tape at 90% speed, which is nice and relaxing and gives you more time to perfect your air drums/guitar. This evening, the radio function even worked, so perhaps it's doing that rarest of things and fixing itself!
The early history for this car is unfortunately missing (no original service book), but the good point is that the recent history/ invoices are all present and correct
2007-2012
Various invoices for MoT work
03/14 173900 miles
Oil Service
Air filter
New front dampers (Volvo) - converted to later twin tube type with spacer
Inner and outer track rods (Delphi)
08/13 173600 miles
New wiper motor
01/13 173400 miles
New battery
Clutch slave cylinder rebuild
Clutch fluid and brake fluid replaced
The mileage has barely changed during this time when it was owned by the previous keeper - the MoT history was as follows
The car came to me freshly serviced and with new brakes
12/01/2013 173370 miles (this is 2 months after I bought it)
23/11/2010 173344 miles (previous owner)
17/03/2008 173303 miles (previous owner)
24/11/2006 169349 miles
11/06 167237 miles
New clutch
New rear pads
New front pads
New rear axle bushes x 4
05/06 162095 miles
Replace both heater hoses
New front exhaust section
10/05 156895 miles
Fuse box terminals cleaned
10/05 156614 miles
Rewire horns
42k service
07/05 153064 miles
36k service
Spark plugs/air filter /coolant etc
and oil
04/05 149818 miles
New wiper cables
01/05 147753 miles
Strip and clean breather system
12/04 144261 miles
OSF lower ball joint
Electrical remedies
Windscreen leak fixed
07/04 142151 miles
Front brake pads
Headlight switch
03/04 138600 miles
Oil and filter
Fuel filter
09/03 133488 miles
New ignition leads
06/03 130538 miles
Cylinder head gasket
Timing Belt
Radiator
10/02 123387 miles
Front pads
Oil service
Air filter
New front calipers
Brake fluid
09/02 122997 miles
All brakes stripped and inspected (leading to above)
01/02 120096 miles
Ignition leads, dizzy cap, spark plugs
12/01 119866 miles
N/S headlamp reflector
wiper
Clutch
10/00 113982 miles
Oil service
Front and rear pads
Fan belts
Throttle body cleaned
04/00 103635 miles
New water pump
Oil service
Spark plug
fog lamp kit
wipers
The downsides
While the car is very solid overall, the arches do have some rust coming through on the undersides on the rear and there are obviously a few age related scratches here and there (particularly on the boot), but she polishes up well.
The driver’s seat has split along the sewing line - it just needs the cover taking off and re-sewing from the back, but should I attempt it, I fear it won’t look quite the same as it should (+ my mum lives too far away to give it to her to do – in any case she’d probably give me a hiding and tell me to sew my own seats) and there’s an old school mobile phone holder glued to the dash top pocket (handy though)
Price: 995 ONO
11 months MoT.
Grey metallic
Heated Front Seats
Electric mirrors
Central Locking
Coolant change
Clutch fluid change
Clutch
Brake fluid change
New wiper motor
2007-2012
03/14 173900 miles
Oil Service
Air filter
08/13 173600 miles
New wiper motor
01/13 173400 miles
New battery
11/06 167237 miles
New clutch
New rear pads
New front pads
05/06 162095 miles
10/05 156895 miles
10/05 156614 miles
Rewire horns
42k service
07/05 153064 miles
36k service
and oil
04/05 149818 miles
New wiper cables
01/05 147753 miles
12/04 144261 miles
Electrical remedies
07/04 142151 miles
Front brake pads
Headlight switch
03/04 138600 miles
Oil and filter
Fuel filter
09/03 133488 miles
New ignition leads
06/03 130538 miles
Timing Belt
Radiator
10/02 123387 miles
Front pads
Oil service
Air filter
New front calipers
Brake fluid
09/02 122997 miles
01/02 120096 miles
12/01 119866 miles
wiper
Clutch
10/00 113982 miles
Oil service
Front and rear pads
Fan belts
04/00 103635 miles
New water pump
Oil service
Spark plug
fog lamp kit
wipers
The downsides
Price: 995 ONO
