hario
S202 C300STD
Feb 26, 2015 12:54:16 GMT
Very impressive work. I've been waiting for ages to see someone experimenting with Mercedes engines, I have an old 1981 camper van that I want to put a more modern engine in, I just want to fit the engine as standard (without super chargeretc) but was given the impression that there would be a load of electronic gubbins to go with it. I'd like a standard turbo charged engine and I don't want to chop the cab about to get it in so I think I'll probably need a 4 cylinder. Can you suggest one of the merc engines and what I'd need to do to make it work? Cheers The easiest Mercedes lump to buy and get running mechanically is the 5 cylinder, using Ssangyong Musso 2.9 injection pump, or the complete Ssangyong 2.9 5 cylinder engine. Sorry but my interest in any of the 4 cylinder diesels just doesn't exist anymore, too small and rough in comparison to a straight 5/6 or V8 You'll want the 4 cylinder version called the OM604 fitted to the (pre-cdi) Mercedes C220td / C200td, and then the Bosch mechanical IP from a Sprinter or Vito which was fitted with an OM601 (SOHC version). And make 350hp like this guy.. www.superturbodiesel.com/std/showthread.php?tid=6138Beers, H.
rob
Very impressive work. I've been waiting for ages to see someone experimenting with Mercedes engines, I have an old 1981 camper van that I want to put a more modern engine in, I just want to fit the engine as standard (without super chargeretc) but was given the impression that there would be a load of electronic gubbins to go with it. I'd like a standard turbo charged engine and I don't want to chop the cab about to get it in so I think I'll probably need a 4 cylinder. Can you suggest one of the merc engines and what I'd need to do to make it work? Cheers The easiest Mercedes lump to buy and get running mechanically is the 5 cylinder, using Ssangyong Musso 2.9 injection pump, or the complete Ssangyong 2.9 5 cylinder engine. Sorry but my interest in any of the 4 cylinder diesels just doesn't exist anymore, too small and rough in comparison to a straight 5/6 or V8 I have acquired, but not collected, a musso TD car. I'm going to need to fit a sprinter sump with the main oil pan at the front and a suitable gearbox, any ideas? Ta
May 26, 2015 15:00:40 GMT
Any chance of a pic of this and the blue one together ?? You could have some sort of " badass " off.....
sowen
Club RR Member Number: 24
May 26, 2015 22:11:58 GMT
The easiest Mercedes lump to buy and get running mechanically is the 5 cylinder, using Ssangyong Musso 2.9 injection pump, or the complete Ssangyong 2.9 5 cylinder engine. Sorry but my interest in any of the 4 cylinder diesels just doesn't exist anymore, too small and rough in comparison to a straight 5/6 or V8 I have acquired, but not collected, a musso TD car. I'm going to need to fit a sprinter sump with the main oil pan at the front and a suitable gearbox, any ideas? Ta Missed this! If you want a front bowl sump then the C250 OM605 lump is front bowl, just get the sump, oil pump and dipstick, should in theory fit Any chance of a pic of this and the blue one together ?? You could have some sort of " badass " off..... Patience
benjy_b
Yorkshire and The Humber
Aug 29, 2015 15:03:54 GMT
Eventually, once the car hits the road I want to send one of my spare pumps to Dieselmeken and have a pukka superpump built, probably 8mm as that's what most people want Look what's just popped up on eBay: clicky
2005 Subaru Forester 2.5XT 1999 BMW E36 318i Touring with OM605 Mercedes Engine 1996 Lada Riva with Honda S2000 Engine
Eventually, once the car hits the road I want to send one of my spare pumps to Dieselmeken and have a pukka superpump built, probably 8mm as that's what most people want Look what's just popped up on eBay: clickyThey're Dieselpumpuk pumps, he sends them to Dieselmeken.... Get into contact with him, very very helpful and knowledgeable bloke!
bigrod
Fantastic project! Loving your fab'ing skillorz and your ability for lateral thinking.
I'll be bookmarking this I think.
If I have to explain, you won't understand. Maximum signature image height = 80 pixels
sowen
Look what's just popped up on eBay: clickyThey're Dieselpumpuk pumps, he sends them to Dieselmeken.... Get into contact with him, very very helpful and knowledgeable bloke! Luke Dale I think the name is? Got a mountain of welding to do on the car and a few other projects need work immediately before I'm ready for that, plus side is that he does give prices on his website in £££'s
They're Dieselpumpuk pumps, he sends them to Dieselmeken.... Get into contact with him, very very helpful and knowledgeable bloke! Luke Dale I think the name is? Got a mountain of welding to do on the car and a few other projects need work immediately before I'm ready for that, plus side is that he does give prices on his website in £££'s That's him.. good bloke.. They've built some good cars!
Aug 20, 2016 19:20:06 GMT
Any updates on this Sowen??
