While the hayfever hits me mainly during the day, it means I prefer to be up during the night so a lot.
I start looking at different threads and started researching the brake upgrade qustions on the neon.
Which ahd me looking at the PT cruiser brake option which most people go for! Then at the 300c
calliper option, which as I am am member on LX forum had me looking at their big brake options(yes
even though they have what would be way to big for the neon but still very good info)
forums.neons.org/viewtopic.php?f=48&t=343569
forums.neons.org/viewtopic.php?f=48&t=266137
www.lxforums.com/board/showthread.php/349259-8-Piston-Brakes
www.lxforums.com/board/showthread.php/274935-My-Journey-for-bigger-brakes-on-an-SRT8-on-a-budget-(DIY-SRT8-Big-brake-kit)/page2
www.lxforums.com/board/showthread.php/330480-AMG-Big-brake-upgrade
So considering thar Chrysler was owned by Mercedes and there are some interchangeable parts
between the marks. Add that some people are using or experimenting between the different parts
available to them it is conceivable that there are more options available to those of us outside the
USA than was previously thought Just with the wrong brand written on them, and a few of those
a brembo! And as pointed out in one of the threads I have posted a link to above, to save money
brembo made the same caliper for a few different marks but put the marks name on them and gave
them a different pn (part Number) for each mark. The same 4 pot calliper used by Aston Martin on
the DB are used on the Jag xj6, xjs and other models. I can't be sure but it looks like MG tf, alfa r
omeo, Subaru impretsa to be very similar too but with the bolting tab built in where the jag/Aston
ones I've seen have it so the brackets can be change for further vehicles or used in the bremebo's
own kits!
The XJ6 (40?) uses 11.44 inch (290.8mm)brake discs, just forgetting the bolt pattern for the minute
but think about it for a minute. If the other marks using the same 4 pot brembo caliper have a similar
size brake disc to that it's not far off the standard PT cruiser disc 11 inch(280mm)isn't it!
Could it be possible to do only a little work on the standard mk1 neon hub so it takes a 4 pot calliper
with a standard 11" pt cruiser brake disc, rather than have to go through a full pt hub swap?
Jaguar XJ 12 H.E. Saloon 1981 -1992 Front Brake Disc
Brake Disc Diameter :284mm
Brake Discs Height :60.5mm
Stud / Holes : 5
Disc Type : Vented
And the funny thing is when I looked at the caliper for it was the same as brembo but labled LUCAS!!!!
www.ebay.co.uk/itm/JAGUAR-XJ-12-H-E-75-92-Front-Right-O-S-Brake-Caliper-Lucas-Brake-System-/290996267560?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Car+Make%3AJaguar&hash=item43c0baaa28
Will I be raiding the jags at the scrap yard, no because they aren't any in the local one but there usually
get one or 2 mercs, a good supply of European produced stock but very few if any american cars. But it
might be a good topic for discussion.
own kits!
Stud / Holes : 5
Disc Type : Vented
