LOCATION
Telford Westmidlands 10 minutes from junction 6 on the M54
CONTACT INFO
Ideally text only due to work hours XXXXXXXXXXXXXXXX
email - XXXXXXXXXXXXXXX
Or PM me on here
PRICE
£2500 with 12 months mot and i am open to offers on it
I have owned this T25 for the last year after buying it from my work (vw garage) after it had been stood for 8-9 years, before it was put away it was painted in red oxide primer and stone chipped which has helped preserve the pickup a fair bit
By no meens its perfect but it does look really nice
Below is a list of Items i have replaced over the last year of ownership;
Front upper ball joints
Front lower ball joints
Track rod ends
Anti roll bar D bushes
Disks and pads front ( upgraded to passat vented front discs and calipers)
Front wheel bearings
911 bearing lock nuts
Upper control arm bushes
Front radius rod bushes
Front shock absorbers
Steering rack boots
Steering rack Powerflex bush kit
Lower control arm bushes, powerflex
All solid copper brake pipes and flexis
Rear wheel cylinders
Rear brake shoes
Master cylinder brakes
Brake servo upgraded to BMW E30 unit
Master cylinder clutch
Slave cylinder clutch
hydraulic Clutch pipework
Drop link bushes
16mm heater hose front to back
110hp AFN engine, ECU, wiring, pedal, sensors, intercooler
Inlet gasket, exhaust gasket, rear crank seal,
Timing belt kit and new aux belt
Water pump and 80degree thermostat with seals
Service kit for engine
Mk3 golf solid flywheel and new LUK clutch kit
TDI starter motor adaptor
TDI input shaft, shaft seal, bell housing gasket and morris gear oil
Radiator and L brackets
Merc E class 15" steel wheels
There is bound to be more items that i have forgotton but there is more ive done like cleaning the parts that come off then stone chipping them all
There is also a few spare parts that come with the pickup that i had accumulated over the year;
Spare AFN engine complete
ECU keys code box clocks and wiring for above engine
Set of spare drop sides
Both treasure chest doors
Rear engine cover
Front valance and slame panel
Spare driver side door
L35 "syncro" mirrors along with 2wd mirrors
It currently has No mot or tax but i will Put an mot on the pickup
Now for the pictures
2 dents in roof and it had a light at some points
Front, upper grill is in the shed
passenger side
driver side
passenger side
driver side
Damaged area with replacement panels
Some crust, pretty much same on the other side
number plate and the green stuff
picture of my daily and the pickup together
A few underside pictures
The ecu, wiring and the N75 items put onto a loom board
The spare engine
Few pictures of the spare items
Thanks
Ash
CONTACT INFO
Or PM me on here
PRICE
Track rod ends
Steering rack boots
Rear brake shoes
Drop link bushes
Rear engine cover
passenger side
driver side
passenger side
driver side
The spare engine
Thanks
Ash
