BLU
I'm halfway through my current project and hope to have it finished by the end of this year. I'm in the planning stage of my next project and want it to be reliable and cheap to run (gonna be a daily) Anyhoos, what cheap and relatively easy to find diesel engines (turboed or not) are available that will couple up to a RWD gearbox? Make don't matter as long as its an in-line 4 cylinder jobbie
The future's bright, the future's BLU
Silver 1987 MK2 Fiesta Ghia White 2006 MK6 Fiesta ST150 Yellow 2007 MK6 Fiesta Zetec S Anniversary #279 Green 2007 MK6 Fiesta Zetec S Celebration #471 (diesel conversion) Red 2008 MK6 Fiesta Zetec S Anniversary #893
Isuzu TD from cavalier etc. Perkins Prima, Diahatsu 2.8 from fourtrak. There are loads plus all the peugeot ones. All can be mated to a rwd box.
Battenberg
Time for Cake....
Jul 15, 2014 10:20:06 GMT
How about a BMW e36 318td 4cyl diesel,,,,,
Current Fleet: 1968 Wolseley 1000 2022 BMW 430xd MHT Coupe 2007 L200 Animal - Dog walking transport 1998 318is Coupe 2007 Mini Cooper Supercharged 1989 BMW 530 - in storage
Jul 15, 2014 10:47:07 GMT
Isuzu 1.7 cav/corsa engine will bolt to omega gearbox. Then there bmw 318td e fine, Peugeot XUD will go onto an ldv gearbox. Escort/mondeo/sierra 1.8 TD (sierra is already rwd if you can find a setup)
Nobody dies a virgin, because lifes curse word us ALL
Jul 15, 2014 10:48:15 GMT
Disco engine can be fitted with a LT77 RWD gearbox from a LDV 400. Also late FX4 Black Cabs had a 2.7 Nissan engine and RWD.
Paul H
Stu_B
Investing in rust!
Jul 15, 2014 10:54:11 GMT
Why not a BMW TDS?
Jul 15, 2014 11:31:21 GMT
The of course there is the Ford lumps from Transit, Sierra & Granada.
THE_Liam
Yorkshire and The Humber
Jul 15, 2014 12:54:35 GMT
PSA XUD. Come in 1.8, 1.9 or 2.1 flavour, turbo or NA. Bolt straight up to an LDV Pilot gearbox (from an XUD powered LDV Pilot), often come with Bosch pumps which love SVO, and the 1.9 With a few cheap mods to the pump internals and a £50 TD04 from a Saab can make 160bhp+ with ease, 200bhp+ has been seen but not reliably. As for the 2.1, people haven't really scratched the surface of what it can do...
Loads of donor cars too:
Citroen BX XM Xantia Synergie
Peugeot 205 305 306 309 405 406 505 605 806
Then various Suzukis, Ladas...
Jul 15, 2014 17:44:36 GMT
Don't forget the Rover 'L' series lumps either. Plentiful and cheap and compatible with various RWD Rover, Landrover gearboxes.
RWD diesel engine for projectDez
@dez
Club Retro Rides Member 34
Jul 15, 2014 17:54:05 GMT
IVECO!!
Jul 15, 2014 22:41:20 GMT
^^^ That is so much win!
Contrary to popular opinion, I do have mechanical sympathy, I always feel sorry for the cars I drive.
BLU
Jul 16, 2014 15:23:06 GMT
Interesting suggestions there. Never thought about a gearbox from a van! Obvious really Quite liking the idea of a 1.9 TD PSA lump, quite nippy engines!! What about VW engines, any RWD boxes available for them? Also if the 1.7 Vauxhall TD engine fits an Omega box will the 2.0 DTi engine from Zafira/Vectra fit too?
Jul 16, 2014 17:02:49 GMT
VW diesel are used for Suzuki SJ conversions so adapter plates available to mount to both the 4 & 5 speed gearboxes. In case you didn't already know on the SJ the gearbox is a conventional RWD item with a short propshaft to the transfer box.
Paul h
Just check the vans don't have stupidly low gearing, obviously the final drive can easily be changed to suit, but keep it in mind
THE_Liam
The gearing on the LDV Pilot is a bit low, but not too low to cause a stupid amount of problems. Depending on wheel size about 3.8-4k at 70.
sowen
Club RR Member Number: 24
RWD diesel engine for projectsowen
@sowen
Club Retro Rides Member 24
Jul 17, 2014 14:01:33 GMT
I've got an LDV Pilot gearbox in my turbo'd Rover P6, does about 2300rpm at 70mph in 5th, far from being low.
bortaf
Jul 17, 2014 14:46:42 GMT
When it comes to commercial gearboxes 1st is uaually a fair bit lower than the car versions and 2nd is slightly lower as well but 4th is ni on allways 1 to 1 and 5th is overdriven, it's 99% the diffs on commercials that do the whole low gearing part of the equation. What vehical? engine bay size and ease of fittment can play a large role in deciding what engine/box you use, personly i'd forget the transit Di on weight, size and gearbox (B/H) size, i like the XUD and ford engines cos i know them but VW do a taisty TDi, just remember the later it is the more wiring it will have !
R.I.P photobucket
VIP
Jul 17, 2014 14:57:28 GMT
Apparently the earlier VAG 1.9TDi (1Z/AFN/AAZ) fit onto a VW LT gearbox.
THE_Liam
Jul 17, 2014 15:32:45 GMT
I've got an LDV Pilot gearbox in my turbo'd Rover P6, does about 2300rpm at 70mph in 5th, far from being low. I'm just basing that on the Pilot. Higher axle ratio?
@dez
Jul 17, 2014 15:46:00 GMT
apparently theres off the shelf adapter stuff available for the vag engines to fit supra boxes now too. not seen them myself but was talking to a guy who'd just bought one at pendine.
