Up for grabs is pretty much a full 1600 Zetec engine set up including looms, starter motor, rad, clocks (proof of mileage), standard inlet manifold / exhaust manfiold and part of the downpipe including lambda sensor and all associated bits (even the front brakes!)
only thing I don't have is a gearbox as I was going to mate it to a 1300 4 speed in my MK1 Fiesta.
Pulled from my old mans 2000 W plate MK7 escort which was to be crushed due to rustyness. Car was owned from nearly new (circa 2002/3) and engine was well looked after
approx 117 thousand miles, clocks come with as proof.
Also have a 1 x 1600 EFI manifold, which is just the manifold, no sandwich etc and 1 x 1800 EFI complete set up (needs a clean) but includes everything needed to get engine running with an EFI set up.
Only reason its for sale is I have sold my MK1 fiesta so just have this lying around, need to make some room.
Can pretty much be put into anything with a but of custom work, use your imagination
£180 notes collected from Carmarthen, South Wales.
PM me on here or drop me a text: 07950999488 (may not reply straight away as I don't get my signal at my girlfriends house)
Pictures:
Pictures:
