mt2man
The mobility scooter curb idea is fantastic! I may have to acquire a spare scooter from my Aunty and attack some curbs for ideas! Also interesting ideas regarding jacking up vehicles haven't seen it done that way!
I'm not sure how relevent this idea is but, how about some sort of roof box mounted hydralic arm that picks up a folded up wheel chair and stores it in the roof box? Controlled in a similar fashion to a hiyab. There might be something out there already but i thought id would throw it out there
Sent from my GT-I9505 using proboards
I'm not sure how relevent this idea is but, how about some sort of roof box mounted hydralic arm that picks up a folded up wheel chair and stores it in the roof box? Controlled in a similar fashion to a hiyab. I've seen one similar that did this - the whole top of the roofbox slid sideways on rails, to above the driver side of the car, then some cables dropped down. Attach the cables to the (flattened) wheelchair, lift it up, and slide back across. Again, a superb project, as would you use gears, chains, or individual motors to lift each of the cables? Are cables the "best" way? Could you make it automatically fold the chair? Could you adapt it to also use a general storage tub, for moving heavy loads? (maximum weight load of 75kg for most roof racks, including the lifting mech)
Jul 22, 2014 14:58:08 GMT
When I did my HNC in CAD/CAM, we had to sort a nuclear reactor rod carrier for BNFL's machine shop! With all there £billions, you'd thing getting spotty oiks to do it for free was the last thing they'd have wanted.
How about a device for making lacing up a bike wheel a piece of the proverbial?
eBay Rare
Jul 22, 2014 20:54:08 GMT
The hydraulic jack (1st problem) would be the best one for you to do for your HNC. It ticks lots of boxes seeing as there are calculations you can do for the leverage and hydraulics involved along with the research into available ones! It will also be alot cheeper than your 2nd solution so you don't have to worry about funding it along with the actual work making it and writing it up. I'm currently doing my HNC, so I know how awkward it can be sorting out a project!
James
Too many projects, not enough time.
doobie
Jul 22, 2014 21:03:10 GMT
Now we have cheap ways of instantly heating water to boiling point how about designing a small modern steam engine that doesnt need a boiler.....
mt2man
Sept 25, 2014 9:51:06 GMT
I'm still researching into HNC project ideas, I'm also thinking about maybe making my classic mini into my project, I am doing an engine conversion and will be fabricating the subframe so there will be a lot that I can document!
Sept 25, 2014 11:50:23 GMT
Why not work on the idea of design & development of an ultra low profile jack that can then be used on numerous cars rather than a system for just one car ? ..with a safe, mechanical way of locking it off, negating the need for axle stands? You would have to make sure it was at least as stable as an axle stand (retractable wheels so it sits flat?), but that would be no biggie.
'03 Porsche 996 C2 3.6 - Sort of Retro '84 Porsche 924 - Definitely Retro!
mt2man
Hmm that's also an idea, ive had a couple hydraulic jacks give up on me in the past and slowly lower cars to the floor so a lockable jack would be good haha
