Jul 26, 2014 15:47:33 GMT
lowering kit for the back of a VW lupo- short gas shocks, spring, platform adjusters. could be used quite easily in various other applications i guess. SOLD. 4x delco-lovejoy lever arm shocks. again off the '33 dodge, don't know if they're original though as one pair has has the arms modded. one has been cracked a long time ago and welded up, but it doenst appear to effect operation. all 4 seem to work ok and not leak loads, all are a bit oily on the outside but its not obvious where its coming from if it even is out of the shocks themselves. £50 the set. stock frod pop/anglia front screen, £15. NOS halls gasket set from the '60s. small block chevy set, presumably for early models given its age, fitments again listed on box. ive opened the box, checked contents and resealed. £40. pair of pretty much brand new SAVA trenta LT 175/75 R16C light truck/van tyres. SOLD. type 9 5 speed ford gearbox from a ford transit. SOLD. set of 4, really good clean straight rims, fomoco stamped, off a '50s ford. 15"x5", 5x4.5" pcd, ford, mopar, amazon, J etc. SOLD. everything can be posted 'cept the screen, location manningtree north essex. 07746334088. not doing any more shows other than retro rides gathering this year. more to come, i'll do the fiat twincam stuff next...
Last Edit: Aug 19, 2014 21:46:44 GMT by Dez
Jul 26, 2014 16:03:15 GMT
Do you know if the screen will fit a 300e van? I don't know much about them but have a mate looking for a screen for his 300e van
Sent from my GT-I9505 using proboards
Jul 26, 2014 16:18:15 GMT
doesnt a 300e use a 100e screen? i happen to have one of those as well though.
Jul 26, 2014 16:49:20 GMT
mk1 golf heckblende/tailblazer/whatdayamacallit/reflective panel thingy. near mint condition, tiny crack around one mounting stud caused by the original bolt rusting- ive removed it and replaced it with a new stud. see closeup pic. its been repolished and has a nice shine, only very superficial marks. £100. RAID turbo '80s 4 spoke steering wheel. SOLD. fiat/lancia twin cam parts. first, a complete head. SOLD. magneti marelli distributor. labelled at 1600cc from a 132 gls, but they're more or less all the same i think. cap is broken but ive left it on for reference purposes, and youd be a fool not to replace the rotor and condensor. £30. exhaust manifold. known for cracking, this one is good. again labelled as from a 1600 132gls. all threads/studs good. £30. inelt manifold with carb. single plane inlet with weber 32ADF2 carb. again labelled as from a 1600 132gls but will be interchangeable with various models- my 2l 132 motor has the same carb. excellent condition, no corrosion or damage, but has been sat a while so would recommend some new gaskets. £85.
Last Edit: Aug 19, 2014 21:48:04 GMT by Dez
Jul 26, 2014 17:20:30 GMT
doesnt a 300e use a 100e screen? i happen to have one of those as well though. Ive just spoke to him and he has got a screen already, he is now looking for a pair of wings if you know of a pair for sale Sent from my GT-I9505 using proboards
tyres sold.
VIP
Jul 31, 2014 19:25:29 GMT
Hmm, I don't have any glass for the Anglia, but I'm in two minds whether to chop it or not...
Jul 31, 2014 19:35:01 GMT
Hi regarding the steering wheel how much posted to kent thanks Kev
Jul 31, 2014 20:57:38 GMT
depends if you want to fit in it or not i guess dan ive got a date with andy over some engines coming up if you do want it.... i can get glass cut to templates at good prices now anyways if you do decide to chop. kev, £6 to post just the wheel £8 with the bosskit as well.
Thanks just the wheel how do you want paying thanks kev
paypal gift is fine. i'll PM you the details.
Aug 10, 2014 11:15:27 GMT
bump, gearbag and wheels sold.
Aug 10, 2014 12:16:05 GMT
R.e steering wheel please check PayPal thanks kev
Aug 19, 2014 21:45:45 GMT
steering wheel, lupo coilies, and twincam head all sold. bump for the rest.
