johnd
Jul 27, 2014 18:51:24 GMT
Looking for some steels to band for my imp, need to be 4x4 pcd and i was hoping to find 14" or at a push 15".
Its will be wide arch with custom wells so rubbing isnt a massive issue...
Any help appreciated as google is failing me
Jul 27, 2014 19:58:21 GMT
Morris Minor is 4" PCD and 14"rims
johnd
Jul 27, 2014 20:34:01 GMT
Thanks thats great, any more?
4" PCD means you are very limited. AFAIK that means Austin A30 / A30 / A40, Mini, Metro, Reliant (Regal, Rialto, Fox, Kitten, Robin etc), Viva, Morris 1000, Midget / Sprite, Imp, Jensen Healey & numerous trailers. Out of all those only Morris 1000 is 14" - the rest are smaller.
Paul H
johnd
Think ive secured a set pretty cheap, its just an experiment.
Hopefully ofsets ect will all be ok
Jul 28, 2014 10:13:10 GMT
Might be easier to swop the centre of a Minor wheel (some are riveted in) into an existing wider rim, such as 14" Mondeo, item than having them banded. That way you can have the offset / inset fine tuned to your requirement.
Paul H
johnd
Jul 28, 2014 11:11:22 GMT
They will need to be around 8" wide front and 10" rear so that wouldnt work mate.
Jul 28, 2014 11:13:16 GMT
I have some stag steel wheels lying about. 14x5.5J 4" PCD IIRC
'73 3.0CS '81 Golf Gti 1.6 '83 Golf 20VT '87 M535i '86 Escort RS Turbo
VIP
Jul 28, 2014 11:51:40 GMT
I have some stag steel wheels lying about. 14x5.5J 4" PCD IIRC Stags were 4x4.5".
Last Edit: Jul 28, 2014 11:51:53 GMT by VIP
johnd
Jul 28, 2014 14:56:13 GMT
Think ive sorted a deal for some minor jobbies nearby anyways, thanks
johnd
Jul 28, 2014 17:35:56 GMT
These have fell through
