Hi guys, blatant copy and paste from Ebay, first good offer gets it! (need to pay rent...)
Model: VW GOLF RYDER, 1.6 5-speed, 5-door.
Year: 1992.
Mileage: 45000.
Tax: Can tax for buyer.
MOT: 1 years MOT, no advisories.
Location: CM11/RM18 Essex, Can deliver anywhere in UK or possibly EU!
Price: £1200 or offers/part exchange on anything interesting.
Contact details: Steve, 07585594586.
1992 MK2 VW GOLF RYDER 5-DOOR 1.6 5-SPEED
ONLY 45000 MILES FROM NEW!!!
OFFERS INVITED
1 YEARS MOT, CAN TAX FOR BUYER.
RECENTLY REMOVED FROM STORAGE, HAD BEEN SITTING SINCE 1996!
VEHICLE HAS BEEN FULLY RE-COMMISSIONED FOR ROAD USE.
THE FOLLOWING ITEMS HAVE BEEN REPLACED/REFURBISHED:
1. Fully serviced with new plugs and all filters.
2. Cam belt replaced inc tensioner.
3. Carb fully cleaned then re-built.
4. All brakes removed, cleaned and re-fitted.
5. Front brake hoses replaced, full brake fluid change.
6. New exhaust middle and rear.
7. Battery.
8. Cooling system flushed and correct coolant added.
9. Starter motor re-built.
10. 2x tyres fitted.
11. New wipers and washer system cleaned out.
12. Full new clutch kit.
Too much to list really!
AS YOU WOULD IMAGINE THE CAR RUNS AND DRIVES BEAUTIFULLY WITH NONE OF THE USUAL MK2 GOLF FAULTS.
GEAR CHANGE IS PRECISE AND HAS ZERO RATTLES INSIDE. IT REALLY IS A STEP BACK IN TIME!
EVERYTHING WORKS CORRECTLY INSIDE AND OUT.
INSIDE IS FITTED WITH A PERIOD BLAUPUNKT CD PLAYER WITH 4X SPEAKERS AND A FULLY FUNCTIONING SUN ROOF.
ALL SEATS ARE UNMARKED WITH THE REARS FEELING UN-USED. DASHBOARD IS CRACK FREE WITH ALL THE INTERNAL LIGHTS WORKING IN THE CLOCKS AND SWITCHES. ORIGINAL FLOOR MATS ARE PRESENT AND ARE PRACTICALLY NEW, DRIVERS SIDE SCUFF SHIELD IN THE FOOT WELL IS UN-DAMAGED. DRIVERS DOOR SEAL HAS WORN.
FOUND DOCTORS PARKING NOTES IN THE CAR SO BELIEVE IT HAD BEEN USED FOR A LOT OF STOP-START JOURNEYS.
BODYWORK HAS SOME SMALL SIGNS OF CORROSION ON THE FRONT LOWER PANEL BELOW THE BUMPER, FRONT SCUTTLE AND SIGNS OF A PREVIOUS REPAIR ON THE OSR ARCH. THE REST OF THE SHELL IS COMPLETELY ROT FREE. ALL THE USUAL ROT SPOTS ARE PERFECT.
THE FRONT END HAS A SPOT LIGHT FRONT GRILLE WITH MATCHING HELLA LIGHTS.
ALL SIDE TRIMS ARE PRESENT AND CORRECT.
THERE ARE SOME SMALL AGE RELATED MARKS IN PLACES, THE WORST OF WHICH IS THE NSF WING THAT WAS DAMAGED IN STORAGE.
MECHANICALS ARE FAULT FREE, BUT WILL NEED TIDYING. SOME SURFACE CORROSION ALONG THE TOP OF THE CHASSIS RAILS AND THE WIRING LOOM HAS LOST ITS INSULATION IN PLACES. THIS IS THE MAIN AREA THAT WOULD NEED WORK TO GET THE CAR 100%
NONE OF THE ABOVE AFFECT THE WAY THE CAR PERFORMS.
VEHICLE COMES WITH LOG BOOK AND OWNERS MANUAL, SERVICE HISTORY HAS BEEN LOST.
I HAVE INVESTIGATED THE MILEAGE AND BELIEVE IT TO BE CORRECT.
THE INTERIOR AND THE WAY IT DRIVES CONFIRMS IT.
THERE IS NO MOT HISTORY ON VOSA, SO WAS OFF THE ROAD WELL BEFORE MOT'S WENT ON-LINE.
LOTS MORE DETAILS AVAILABLE.
PLEASE CALL STEVE 07585594586.
DELIVERY CAN BE ARRANGED
INTERIOR HAS BEEN VALETED SINCE THESE PHOTOS WERE TAKEN.
