1978 FORD CAPRI 1.3L IN FORD DIAMOND WHITE
THIS IS ONE OF THE RAREST CARS IVE EVER OWNED IVE NEVER SEEN ONE BEFORE OR ONE FOR SALE UP UNTILL NOW
THE MAJORITY OF THEM HAD THE ENGINE PULLED AND REPLACED WITH BIGGER ONES
ILL SAY FROM THE START I BOUGHT THIS WITH NO LOGBOOK AS THE PREVIOUS OWNER HAD LOST IT IVE SINCE APPLIED FOR ONE AND HAD A LETTER FROM DVLA SAYING IT WILL BE PROCESSED FOR THE 18/8/14 THE AUCTION IS RUNNING FOR TEN DAYS SO IT SHOULD BE HERE BEFORE THE AUCTION ENDS PLEASE BEAR THIS IN MIND
THE CAR-
MOTED TILL THE 7th OF AUGUST 2015
CURRENTLY NO TAX WHEN THE LOG BOOK COMES AND THE NEW OWNER WANTS IT TAXING I CAN THE CAR IS INSURED OF COURSE AT THE BUYERS COST
ITS £79 FOR SIX MONTHS ROAD TAX
SHE HAS COVERED 52,961 MILES
THIS IS BELIVED TO BE GENUINE
ALL THE PANELS ARE THE ONES IT LEFT THE FACTORY WITH AND ITS TOTALLY STANDARD AND HASNTBEEN PLAYED WITH
HOWEVER THERE IS NO HISTORY WITH THE CAR SO I CARNT GARUNTEE THE MAILAGE
FITTED WITH THE 1.3 CROSSFLOW ENGINE AND THE TYPE 3 FOUR SPEED GEARBOX
SHE GOES THROUGH THE AS SHE SHE SHOULD AND FOR A SMALL ENGINE PULLS VERY WELL
THE ENGINE WAS REMOVED AND FITTED WITH NEW-
HT LEADS
SPARK PLUGS
ROTOR ARM
DIZZY CAP
ROCKER COVER GASKET
EXHAUST MANIFOLD GASKETS
FRONT CRANK OIL SEAL
TIMING CASE/WATER PUMP GASKET
BRAND NEW CLUTCH AND CLUTCH CABLE
NEW BATTERY WITH CONNECTORS
OIL AND FILTER
STARTER MOTOR SOLINOID
THE GEAR BOX WAS DRAINED AND REFILLED WITH NEW OIL AS WAS THE AXLE
SHE HAS JUST HAD-
NEW CALIPERS
NEW PADS
NEW FITTING KIT
NEW FLEXI HOSES
NEW BRAKE PIPES
NEW SHOES
NEW REAR WHEEL CYLINDERS
NEW HANDBRAKE CABLE
NEW NUMBER PLATES
NEW HORN
NEW HAZZARD RELAY
NEW BRAKE FLUID
NEW WIPER BLADES
SHE HAS HAD A LOT SPENT ON HERE ANYTHING THAT NEEDED REPLACING GOT REPLACED
SHE DOES DRIVE REALLY WELL FOR A SMALL ENGINED CAPRI
INSIDE SHE IS FITTED WITH THE STANDARD INTERIOR
THE DRIVERS BASE HAS SUNK A LITTLE IT WANTS SOME NEW STRAPS UNDERNEATH
THE PLASTIC SURROUND OS MISSING FROM THE GEAR LEVER I'm CURRENTLY ON WITH THIS AT THE MIN
THE ROOF LINING HAS A TEAR NEAR THE REAR VIEW MIRROR ABOUT FIVE INCH LONG
THE BOOT IS NICE AND CLEAN
IT HAS BEEN ZEBARTED FROM NEW IN THE BOOT FOOTWELL AND UNDER THE BONNET
ALL THE PANELS ARE GOOD AND ALL THE MAJOR AREAS ARE GOOD TOO
NOW I'm NOT SELLING IT AS A SHOW CAR ITS A GOOD EVERYDAY USUABLE CAR AND WITH IT BEING THE 1.3 ITS A BIT DIFFERENT TO THE OTHERS
THERE IS THE ODD MARK HERE AND THERE BUT NOTHING MAJOR
ITS IDEAL FOR THE NEW DRIVER WANTING TO GET ON THE CAPRI LADDER ITS CHEAP TO INSURE,TAX AND RUN
ITS A VERY VERY NICE LOOKING CAPRI AND AS I SAID IVE NEVER SEEN ONE FOR SALE WELL NOT IN THE LAST FIVE YEARS
THERE WAS A COMMENT IT COULD BE A CAMEO AS THEY DID THEM IN THE 1.3 AND THE 1.6 BUT UNTILL THE LOG BOOK COMES I'm UNSURE ON THIS
SO TO SUM UP ITS A BIT OF A RARE BEAR CAPRI WITH A FULL MOT AND PRETTY MUCH EVERYTHING ON IT IS NEW AND IT LOOKS WELL
IVE PROBALLY FORGOT SOME MORE NEW BITS OVE ADDED SO ILL POST UP WHEN I REMEMBER
steve £2400ono
THE CAR-
HT LEADS
SPARK PLUGS
ROTOR ARM
DIZZY CAP
ROCKER COVER GASKET
OIL AND FILTER
SHE HAS JUST HAD-
NEW CALIPERS
NEW PADS
NEW FITTING KIT
NEW FLEXI HOSES
NEW BRAKE PIPES
NEW SHOES
NEW HANDBRAKE CABLE
NEW NUMBER PLATES
NEW HORN
NEW HAZZARD RELAY
NEW BRAKE FLUID
NEW WIPER BLADES
steve £2400ono
