retrolegends
Winging it.....Since 1971.
Club RR Member Number: 94
So the power supply came this morning for the sound system. Some classics here folks! Ultimately the tapes are for decoration and this is a bit more practical, if only we had these in the '80s eh? Mind blowing stuff!
1974 Hillman Avenger 1500DL1992 Volvo 240SE1975 Datsun Cherry 100a flying custard1965 Hillman SuperMinx Rock N Roller1974 Austin Allegrat Mk1 1.3SDL1980 Austin Allegro Mk3 1.3L1982 Austin Allegro Mk3 on banded steels2003 Saab 9-3 Convertible 220bhp TurboNutter1966 Morris Minor 1000 (Doris) 2019 Abarth 595C Turismo (not retro but awesome fun) www.facebook.com/DatsunCherry100a
vanpeebles
I am eastbound in pursuit of a white Lamborghini, this is not a recording.
Mobile disco
retrolegends
Rack and surfboard on, just a shame the nearest beach is 105 miles away!
retrolegends
Aug 11, 2016 15:20:02 GMT
So I have priced a recon 1275 gearbox up from a place at Nuneaton and it comes out about £460 service exchange, this will be a job for the winter I reckon so I am going to chance the 80 mile drive to RRG16 with the car as it is. I have AA relay cover so if the worst does happen I can always get relayed back and pick the Saab up. Not even considered how I'm going to get the other 80 miles back home yet! 😂 All ready (even if it is a bit premature!).
Needs a big searchlight on the roof with the bat symbol or sommat. Looking good.
retrolegends
Aug 24, 2016 18:24:22 GMT
Well I went out to give the Allegrat the once over before Friday's epic 80 mile journey, it started first turn which was good but on closer inspection it seemed to be suffering from a lack of electricity. No horn, no heater, no hazard lights, no main beam and no cigarette lighter! curse word!!!! So must be a fuse eh? No the heater is on a different fuse! So after twenty minutes or so the dashboard looked like this! ^^^^^^😆 So I swapped a few fuses around one of which broke in two while I was trying to remove it. There then followed a trip to the local motor factors "Shepherd and Wilson" who luckily still stock glass quick blow fuses at the princely sum of 15p per fuse. So I decided to swap the lot! After another half hour or so of changing fuses and wiggling cables the heater motor started working, then the horn started, this was swiftly followed by everything else! Not sure if it was the inverter that caused this or just dodgy '70s Leyland electrics but I could certainly do without his kind of problem with RRG16 looming large! Better make sure I've got my AA card in my pocket! 😳
edk83
Aug 26, 2016 12:32:15 GMT
Dirty connector, probably many!
I keep welding round the ultra high tech wiring strip that goes to the boot trying not to damage it, might as well replace it anyway lol
vulgalour
Club RR Member Number: 146
Aug 26, 2016 22:54:55 GMT
This is terrible. I love it.
retrolegends
Aug 30, 2016 11:10:08 GMT
So I set off on the road to Shelsly Walsh and RetroRides Gathering around midday on the Friday and by the time I had got to Measham service on the A42 which is about 8 miles the car was already smelling quite warm, I stopped at McDonald's and considered my options. 1. Return hope and go in the Saab 2. Press on and see what happens So I opted for number two. On the motorway the car sat quite happily at 60 and the temperature gauge sat around halfway. All was well until I got to the section of the M42 that runs into the M5 and the matrix signs were flashing for delays into the roadworks. So I thought I'd try and be clever and go off onto the A38 and cut through Bromsgrove, BiG MISTAKE as it turned out! I probably added an hour to my journey as the traffic was solid, the car was clearly not happy with this turn of events and the temperature gauge soared as I sat there with the heater on full in the baking sun! I managed to get to Droitwich where I met justanotherhigh with his huge Ford LTD and his mate Adam with his Allegro and we pressed on down the lanes to Shelsly. By this time the Allegrat had about had enough and I was struggling to get more than 40 to 45mph, not good on those hills! We eventually made it in to the camping field at around 3:30ish and set up.
retrolegends
Aug 30, 2016 11:24:28 GMT
Saturday afternoon after the previous nights ale had worn off we decided to take the old nail on a run to try and iron out a couple of the issues, I had Louis with me who had owned this Allegro at some stage along with around ten or twelve others he has had, we got around half a mile from the camping field and it just died! We called for back up but the damn thing would not start so I suffered the indignation of being towed back into the camping field to much applause, thanks folks! 😂 So after much fiddling the car fired up but under any kind of load just died, not having any spare points or a spare condenser, we messed about with the timing to try and get is to run a little better but by then though the heavens opened to a pretty torrential downpour so we gave up and got back on the ale!! 😆👍🏻🍺
vulgalour
Aug 30, 2016 12:12:21 GMT
Congratulations on making it, not so much on it breaking down. What fuel pump do you have on this one? I only ask because I've been afflicted with an aftermarket electric in the past that wouldn't pump enough fuel under load and the car would die as a result, going to a mechanical pump fixed the issue.
retrolegends
Aug 30, 2016 12:42:48 GMT
Congratulations on making it, not so much on it breaking down. What fuel pump do you have on this one? I only ask because I've been afflicted with an aftermarket electric in the past that wouldn't pump enough fuel under load and the car would die as a result, going to a mechanical pump fixed the issue. Hello Mr Vulgalour, it's a manual lift pump mounted at the back of the lump under the carb, there was plenty of fuel, but a lack of spark.
Aug 30, 2016 12:51:37 GMT
Looks like an awesome piece of the 70s! Guess it never made it into RR parking on Sunday as I don't remember seeing it?
1979 Mk1 Passat Estate 1.6 LS 1996 Mk3.5 Fiesta 1.3 Classic 1997 Mk1 MX5 1.8i 2005 Mazda 3 TS
retrolegends
Aug 30, 2016 13:07:20 GMT
So Sunday show day dawned and after another half an hour or so messing about I decided to try and get the car off the field through the mud, I made it as far as outside the gate where a kind gentleman helped to push me back in. I managed to get running again and this time made it to the hill just before the entrance of the hill climb, damn it!! Louis pulled in front in his VW T5 and towed me up to the show field where I could at least get a mobile phone signal if I needed to call the AA. Ah well at least I made it into the show field even if it was on a rope!! 😆😩 So I had a root about and found another condenser to fit, by this time I was getting a few people looking at the car and offers of help, Jonny69 offered some assistance amongst others, I took the old condenser out and then went and dropped the screw in the grass, this was about the last straw for me tbh, my self and justanotherhigh or Nick as he is really called grubbed around in the grass trying to find it but by this time it was becoming very apparent that it was only going to end one way. So I called the AA. The AA guy was great as were the very understanding staff on gate 'C'. So a big thanks for that. The journey home wasn't too bad either as the AA patrol man told me all about his 1959 Morris Minor he had just bought and his 1978 series 3 Landrover he has. So after leaving the car alone on the drive for a couple of days I've managed to get it running again today with a tie wrap holding the condenser down, the points are absolutely shot on close inspection and it's hardly surprising tbh as all the engine had was an oil and filter and a new temperature sender, nothing else and don't forget it had been standing since 1995 so it's testament to how strong these 'A' series engines are. So with that in mind it's time to spend a bit of money on the old thing and get it running properly, who knows maybe I'll make the Midlands stand at RetroRides Gathering next year!!!
retrolegends
Aug 30, 2016 13:12:51 GMT
Looks like an awesome piece of the 70s! Guess it never made it into RR parking on Sunday as I don't remember seeing it? It was lurking about for a while but by about 1:30 the AA had towed me away.
Aug 30, 2016 13:13:32 GMT
makes for a good adventure that you wont soon forget. looks like with a bit of fiddling, it will be much more dependable....did you find out why it is overheating in traffic?
neat car...looks like you can modify it to your hearts content and any choice you make will be great fun!
JP
retrolegends
Aug 30, 2016 13:36:33 GMT
makes for a good adventure that you wont soon forget. looks like with a bit of fiddling, it will be much more dependable....did you find out why it is overheating in traffic? neat car...looks like you can modify it to your hearts content and any choice you make will be great fun! JP Thanks, I think the first modification will be electronic ignition, not sure about the overheating but I'm going to flush the radiator out and see if it helps, not use to warm weather over here, that's me and the car! 😀
vulgalour
Aug 30, 2016 14:45:38 GMT
You don't have to fit electronic ignition, you just need to find someone selling decent condensers. I'm yet to have a problem with any points I've bought but condensers are another story. I'm told you can fit a capacitor in place of the condenser which does the same job, it's something I'll be doing with the Princess in the near future, and that should cost in the region of £2 and provide decent reliability. I've not done it yet but I'll be sure to post results when I do attempt it later this year.
For the overheating, check the state of the thermostat as well as getting the radiator cleaned out properly. It's been stood a long time so the antifreeze that was in there could have started to do weird things and gum up the internals. If you're really unlucky it's will have jammed up the waterpump. All the parts are easy to get at least, one big benefit of the A.
retrolegends
Sept 1, 2016 16:56:25 GMT
Thanks vulgalour it's something I'll definitely look into although a complete electronic distributor is only about £40 and it should give me a very welcome power boost. As for the cooling I need to take the rad off and give it a good flush out or maybe even a recore.
Sept 1, 2016 19:17:12 GMT
i'd recommend electronic ignition, my old bug had a set up scavenged from a later VW, never let me down no matter what the weather and i'd trust it to go anywhere
