v8jim
Aug 19, 2014 10:47:11 GMT
Has anyone put a 300tdi in something RWD? I have an engine and an R380 LDV gearbox but my engine is from a disco and the bellhousing is too long to just swap over? Anyone got any good suggestions as to what bellhousing to use? It's going in this
Max sig pic size: 80px
Aug 19, 2014 11:22:17 GMT
I've got Rovers.
sowen
Club RR Member Number: 24
Landrover 300tdi RWD gearboxsowen
@sowen
Club Retro Rides Member 24
Aug 19, 2014 11:34:11 GMT
You need a short Defender bellhousing off any early 4 cylinder upto the 200tdi, going by Sam1990's link 300tdi bellhousings are too long like the Discovery
v8jim
Aug 19, 2014 12:09:49 GMT
Sowen Thanks for that, is that yours? Any more info on how it fitted length etc So I need one from a defender with the old 2.5 lump before tdi?
sowen
@sowen
Aug 19, 2014 13:46:56 GMT
I put that together for a mate on his project, but it never happened in the end. I think all 4 cylinder Defenders upto and including the 200tdi are short bellhousing, so you only use the standard off the shelf clutch etc. The only difference is you need to make a new spigot bush to replace the large Land Rover pinion to the small rwd LT77/R380 type pinion. I think the rwd R380 should drop straight on, but you will need to check the end of the pinion does not bind in the end of the crankshaft, a common issue when going from LT77 to R380. All you need to do is make a spacer shim to go between the bellhousing and gearbox. I think that should cover it from memory!
v8jim
Aug 19, 2014 14:06:37 GMT
Thanks for the info that just what I needed to know
v8jim
Aug 19, 2014 14:33:13 GMT
I don't suppose you have a bellhousing for sale do you?
sowen
@sowen
Aug 19, 2014 15:49:37 GMT
No, not got one spare, quickly looking through ebay earlier I was suprised not to see any!
Aug 19, 2014 19:47:01 GMT
Depends on the yr of manufacture.
v8jim
Aug 19, 2014 22:11:49 GMT
I'm pretty sure I need a defender LT77 bellhousing now all I need to do is find one
Aug 24, 2014 19:35:21 GMT
The LT77 bellhousing from a defender is shorter. Land Rover used a longer bellhousing in the Discovery due to the depth of the bulkhead compared to the defender one. When they changed to the 300 Tdi, they used the same bellhousing in both discovery and defender so they didn't have to produce two different ones.
1964 Saab 96 two Stroke 1971 Hillman Avenger 1500 GL (Tuned 1600 fitted) 1976 Saab 99 2dr EMS (Project of very slow progress) 1978 Saab 99 2dr EMS (Awaiting reshell) 1981 Saab 99 2dr Turbo (Awaiting reshell)
Aug 26, 2014 18:36:45 GMT
It's going in this Awww hell yes! Please tell me there's a build thread!?
Koos
v8jim
Aug 26, 2014 20:02:30 GMT
No but I might start one sometime
Aug 26, 2014 22:22:18 GMT
Any reason you wanna use the tdi?
Something like a Merc om. 606 would really make it shift!
Koos
Aug 27, 2014 16:24:36 GMT
Last Edit: Aug 27, 2014 16:26:07 GMT by colnerov
v8jim
Aug 27, 2014 17:46:51 GMT
I've just won one on eBay for £5
I did think about a merc lump and I'd love one but it would be a bit long to fit under the bonnet and I still have to leave room for my feet in the cab
Aug 27, 2014 17:52:16 GMT
That looks spot on. Full-height cab ftmfw.
*n
Aug 27, 2014 21:28:58 GMT
No but I might start one sometime I think it's safe to say, you'd have a LOT of followers if you did!
Aug 27, 2014 21:45:14 GMT
the landy LT77 box was fitted to 2.25 petrol,2.5L petrol,2.5 N/A diesels,the Turbo diesel and the 200tdi, the 300Tdi had R380s. All defenders, had shorter bellhousings and discos had the longer ones as stated earlier due to bulkhead. The bell housings from all the LT77s are the same stud pattern and should be ok to fit the 200Tdi straight to, now the interesting bit is the 2 wheel drive side. This could be overcome by using an LT77 from a MGB and using the bell housing from a landy LT77 as they should bolt together from memory, nothing a good old bit of "improvising a temporary,permanent solution" wouldnt sort for you I hope that helps you out some more.
'88 Cadillac Brougham hearse (white) '91 Carlton GSi 24v '72 Dodge dual cab pick up '99 Mercedes S55 AMG
v8jim
Aug 27, 2014 21:48:50 GMT
Thanks for all the advise I'm sure I'll be able to get it sorted now and I might even start a build thread
