Steve
Aug 26, 2014 18:04:15 GMT
Hey everyone!
Trying to find out what off-the-shelf coilovers will fit for certain onto a Skoda Felicia....any thoughts??
Cant be sure which but possibly golf or polo based suspension
Cheers Steve
Club RR Member Number: 160
Coilovers for Felicia??Rich
@foxmcintyre
Club Retro Rides Member 160
Aug 26, 2014 18:44:21 GMT
Seat Ibiza 6L should fit all round
Felicia has Favorit based suspension - i.e. pre-VW design. So nothing fits off the shelf.
You can make some using Nissan Bluebird or Primera inserts, chopping the Felicia strut up.
craig1010cc
Club RR Member Number: 35
Coilovers for Felicia??craig1010cc
@craig1010cc
Club Retro Rides Member 35
Aug 27, 2014 11:12:27 GMT
Don't know about the rear end, but the front end options I found when I had my pickup version. GAZ do make coilovers for the front (but not cheap) but mk4 golf fronts work as do Focus coilies, but you need to get either the hub opened out by 1mm or the bodies skimmed (or get them pressed in). the VW caddy forum has lots of info on teh options
Rears I would have thought(guess) mk1/2/3 golfs would do the trick
pepe
Sept 9, 2014 17:50:19 GMT
i know the skoda pick up uses mk1 focus front coilovers but the where the strut goes in needs boreing out, mk4 golf rear springs (not 100% sure on rear shocks) and down you go! but that depends if the rear is a different setup in the car as apposed to the pick up!
craig1010cc
@craig1010cc
Sept 9, 2014 21:28:05 GMT
the rears are different, they are a coil over shock rather than a seperate spring
pepe
Sept 9, 2014 21:34:22 GMT
ahh no worries, at least he can find the fronts for now while he finds out what the rears are
pepe
Sept 9, 2014 21:34:33 GMT
qwerty
Club RR Member Number: 52
Coilovers for Felicia??qwerty
@qwerty
Club Retro Rides Member 52
Sept 10, 2014 8:19:56 GMT
Seat Ibiza 6L should fit all round You might be onto something there. They're similar to mk4 Golf setup but the bodies may be a bit narrower.
Seat Ibiza 6L should fit all round do they actually fit? Have you done it?
@foxmcintyre
Seat Ibiza 6L should fit all round do they actually fit? Have you done it? No. As I said on your first thread I lowered mine on 1.3 petrol springs and I ended up using Nissan 300zx front springs on the rear because I had some. Mine wasn't the kind of truck I wanted to slam so I never bothered getting coilovers, it had to move heavy things sometimes and the sump and ARB was very low on the diesel.
do they actually fit? Have you done it? No. As I said on your first thread I lowered mine on 1.3 petrol springs and I ended up using Nissan 300zx front springs on the rear because I had some. Mine wasn't the kind of truck I wanted to slam so I never bothered getting coilovers, it had to move heavy things sometimes and the sump and ARB was very low on the diesel. mine is a diesel and dropped 40mm at the moment but the shocks are just so curse word I want to put coilovers on it to get the ride better the sump and arb are fine at that height atm but don't really want to fyck around chopping up sets of coilovers. The 6l ones do look close I think I'm just going to have to get the verniers out and have a measure
@foxmcintyre
Nov 10, 2016 13:25:55 GMT
No. As I said on your first thread I lowered mine on 1.3 petrol springs and I ended up using Nissan 300zx front springs on the rear because I had some. Mine wasn't the kind of truck I wanted to slam so I never bothered getting coilovers, it had to move heavy things sometimes and the sump and ARB was very low on the diesel. mine is a diesel and dropped 40mm at the moment but the shocks are just so curse word I want to put coilovers on it to get the ride better the sump and arb are fine at that height atm but don't really want to fyck around chopping up sets of coilovers. The 6l ones do look close I think I'm just going to have to get the verniers out and have a measure 6L front struts are 45MM, same as the Felica
Nov 11, 2016 13:34:02 GMT
They are 50mm not 45 so will not fit
@foxmcintyre
Nov 11, 2016 13:39:05 GMT
They are 50mm not 45 so will not fit Huh. Sure the Seat I measured was 45MM. Back to the drawing board. As mentioned, Focus fits it seems.
