Hi there
i'm assisting one of the young lads at work fitting a 90'spec 16v Kjet engine to what was a 88' Golf Mk2 1.8 driver with a carb
The conversion itself isn't too bad as he got the full running gear from another car complete with fuel lines etc but the issue we have is the the Driver is CE1 wiring and we only have the engine loom and fuse box from the CE2 donor with no hope or retrieving the rest as the car is now a cube
I'm confident of making a small fuel pump loom but the main engine wiring is there a way of deleting the CE2 fuse box?
The lad who he got it from labelled the CE2 box not very well with red paint and said to run the 2 side by side but it's tight as it is with the CE1 fuse box being there for the lights etc hence why I'd like to delete it if possible
thanks for now
thanks for now
